Old 10-09-2007, 01:43 AM   #5701
jrxs-r's Avatar
Originally Posted by Slippery Dan View Post
OK. I guess I'm just slow.
I'm trying to figure out how to get 1degree "front pivot" on my car.
The manual is not very helpful though.
It mentions the vairious combinations about different arm lengths and "wide" or "Narrow" pivots but none of them are stated in degrees.
Since there are 3 degree choices on the setup sheet I'd assume that you have to use a combination of the different holes. But wouldn't that affect the spacing of your arms depending on whether you are using the long ones or short??
Can someone please help.
Thanks.
Order the 1 degree outer pivot block p/n LOSA9696.
http://www.teamlosi.com/Products/Def...rodID=LOSA9696
Most of the pivot angles on the R are set with the aluminium pivot blocks.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 10-09-2007, 06:12 AM   #5702
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Originally Posted by RussB View Post
diff pulleys are not the same from the old sedans and the type-r. the hole in the middle is quite a bit larger on the type-r as the outdrive passes through it.
the smaller layshaft pulleys are the same though.
you have to use these and they are a perfect fit!!
http://www.losipartshouse.com/servle...y-Pully/Detail
Old 10-09-2007, 06:48 AM   #5703
J@UNE's Avatar
Anyone know if I can use the drive pulleys from the old JRXS?
I'm using the XXX-S Pulley on my Type-R... I had to ream the center hole so it fit... Can be a pain to make it really centered but its a possibility...
J@UNE is offline   Reply With Quote
Old 10-09-2007, 06:51 AM   #5704
Super Moderator
Marcos.J's Avatar
you dont have to do that if you use the ones above!!
Old 10-09-2007, 07:58 AM   #5705
Trader Rating: 14 (100%+)
Thanks Marcos!
Slippery Dan is offline   Reply With Quote
Old 10-09-2007, 08:00 AM   #5706
Super Moderator
Marcos.J's Avatar
Thanks Marcos!
no problem
Old 10-09-2007, 10:30 AM   #5707
RussB's Avatar
Send a message via MSN to RussB
good call.
RussB is offline   Reply With Quote
Old 10-09-2007, 10:38 PM   #5708
syndr0me's Avatar
Trader Rating: 32 (100%+)
I tried Schreff's pre-Vegas Horsham setup tonight with Jaco Prism dblpink instead of Parma magenta and it felt pretty great. I don't think I'm cut out for lightweight bodies though. :-(
syndr0me is offline   Reply With Quote
Old 10-10-2007, 05:16 AM   #5709
schreff's Avatar
Send a message via AIM to schreff
FYI Guys...
Mine and Dumas' setups from the IIC are now posted on the Losi site.
http://www.teamlosi.com/Products/Sup...rodID=LOSK0256
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 10-10-2007, 05:37 AM   #5710
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
It's about time...
Dasupacat1 is offline   Reply With Quote
Old 10-10-2007, 06:25 AM   #5711
Yeti35's Avatar
I ran the same setup in LV other then I was using Cyan in the front but the older Parma's and it still felt pretty good and was easy to drive considering I had no carpet time until IIC. I was using a Parma Alfa body on mine also. I am not Schreff, but his setup worked for me.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 10-10-2007, 06:29 AM   #5712
schreff's Avatar
I wouldn't worry so much about a lightweight body. Larry ran a regular weight on his car and it didn't seem to have any ill effects on handling. It was more of an insurance item than anything else not having to worry about tucking.
-Jason Schreffler-
Old 10-10-2007, 06:39 AM   #5713
Trader Rating: 45 (100%+)
I know with all the tucking issues I'm surprised some companies haven't come out with a multi-thickness body keeping the higher parts of the body lightweight and the lower areas a little thicker keeping keeping the weight low and the body more rigid where it needs to be.
Apex is offline   Reply With Quote
Old 10-10-2007, 07:07 AM   #5714
jrxs-r's Avatar
Hehehe.... yeah... like make it thicker where it needs to be... That'll be the roof for me, with the amount of carnage that can occur in some finals, its not uncommon to get onto the straight on the roof and passing the transponder loop!!
Cheers,
Zack
Serpent S411
Old 10-10-2007, 07:54 AM   #5715
schreff's Avatar
I remember talking to Cuffs at the IIC and he mentioned that Andy Moore's body on his rubber tire car had bracing in it for the roof and sides. I guess they "Moorespeed" line of bodies is even lighter than normal light weights. He had to brace the roof and sides so it wouldn't collapse. Kinda defeats the purpose if you ask me.
-Jason Schreffler-
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
