Old 10-08-2007, 05:55 PM   #5686
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Originally Posted by smojoe View Post
what batteries have to tried, clearance wise? aka, do the orion 4800's fit? I believe losi took out material because of battery clearance but I am not 100% sure.
core r/c 5000's fit with no problems!
Old 10-08-2007, 07:11 PM   #5687
syndr0me's Avatar
Trader Rating: 32 (100%+)
The Trakpower gold brick has its connectors in a spot where they would be obstructed by the top deck without some modification. Pretty disappointing that they didn't push the connectors out to the corners like the other brick packs.
syndr0me is offline   Reply With Quote
Old 10-08-2007, 07:16 PM   #5688
Matt Howard's Avatar
nothing 30 seconds with the dremel can't fix You only need to take off a bit of material from the topdeck
Matt Howard is offline   Reply With Quote
Old 10-08-2007, 07:49 PM   #5689
J@UNE's Avatar
Originally Posted by vabroom View Post
J@une, if those are aluminum screws on that top deck, a hard hit in that area can easily shear off the screws. Leaving you with the main body of the screws still inside the bulkheads. A very expensive repair and/or replacement.
Have you had any bad experience with alu screws in the top deck? I dont think those screws will break at impact. I saw so many on Tamiya and tc4... I wouldn't use them to hold the bumper or suspendion arms. But I got your point on how hard it will be to remove them. Time will tell. Thanks for the advice
J@UNE is offline   Reply With Quote
Old 10-08-2007, 08:02 PM   #5690
vabroom's Avatar
It was a no no for sometime maybe they make the screws out hard aluminum (like 6065). Just don't crash too hard! lol
vabroom is offline   Reply With Quote
Old 10-08-2007, 08:18 PM   #5691
adamge's Avatar
The best Al screws, made of 7075 T6:
http://www.fastener-express.com/inde...S&Category=218
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 10-08-2007, 08:33 PM   #5692
PeteB's Avatar
Originally Posted by mojoman View Post
Here is a link for some XXX-S aluminum parts...]
Thanks Mojo, just what I was after. I've bought the part and will let people know how it goes.
I'll see how the 0deg caster goes and might have to shim up the front to get a bit of kick up.
Pete
PeteB is offline   Reply With Quote
Old 10-08-2007, 09:33 PM   #5693
Trader Rating: 14 (100%+)
Anyone know if I can use the drive pulleys from the old JRXS?
I can't find the type R ones (LOSA 3326) anywhere for sale and the guy I got my type R from only had the spool pulley installed (no holes for diff balls)
Slippery Dan is offline   Reply With Quote
Old 10-08-2007, 09:44 PM   #5694
R32GTR's Avatar
Default Fans
Hey guys, can anyone point me in the right direction to get the correct size fans for the R. I can't seem to find any anywhere.
Also what gearing do you reccomend for 19T on an open outdoor track?
Thanks.
R32GTR is offline   Reply With Quote
Old 10-08-2007, 09:51 PM   #5695
Trader Rating: 71 (100%+)
Diff pullies are the same size. Only difference is color (white on the old car and black on the new car).
RBLove is offline   Reply With Quote
Old 10-08-2007, 09:53 PM   #5696
Thanks.
Associated makes a nice double fan combo that is prewired and ready to go. I believe it was for their TC4. Check them out.
As for gearing. It depends on the motor and the track size and layout.
Old 10-08-2007, 10:09 PM   #5697
R32GTR's Avatar
I will be using a Brood Komodo 19T and the track is fairly fast and flowing.
Old 10-08-2007, 11:03 PM   #5698
I ran my "R" with a 10.5 BL at 5.4 seemed to be very good ,,, even on low bite surface .. when the dust hit the track ...
Mark Barden .
mb racer is offline   Reply With Quote
Old 10-08-2007, 11:37 PM   #5699
OK. I guess I'm just slow.
I'm trying to figure out how to get 1degree "front pivot" on my car.
The manual is not very helpful though.
It mentions the vairious combinations about different arm lengths and "wide" or "Narrow" pivots but none of them are stated in degrees.
Since there are 3 degree choices on the setup sheet I'd assume that you have to use a combination of the different holes. But wouldn't that affect the spacing of your arms depending on whether you are using the long ones or short??
Can someone please help.
Thanks.
Old 10-09-2007, 01:21 AM   #5700
RussB's Avatar
Send a message via MSN to RussB
diff pulleys are not the same from the old sedans and the type-r. the hole in the middle is quite a bit larger on the type-r as the outdrive passes through it.
the smaller layshaft pulleys are the same though.
RussB is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
