Old 09-11-2007, 12:34 PM   #5491
schreff's Avatar
Send a message via AIM to schreff
Guys... Just a quick FYI
I just talked to Todd and he informed me that both the California and Illinois warehouses have Type R kits in stock. This is official as per Todd.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 09-11-2007, 02:53 PM   #5492
mojoman's Avatar
Originally Posted by s13evo View Post
Hello, im new to the forum and just finished building the type R.
i got 2 problems with it so far tho. wondering if anyone could help me out?
#1.When using the 41T spool ,why is it the belt stays very loose. when using the stock diff i can tighten the belt very good but not when using the 41T spool.
is there a special smaller size belt when using he 41T spool? or any other modification needed to use the 41T instead of the 42T?
#2.why does my car swerve to the side when at full trottle, but goes very straight from slow rolling start to high speed. but when i torqe it it always swerves to that oneside again. forgot which side it serves too. is my diffs too lose? or is that normal?
You also might want to make sure your spool is good and tight. If there is any slip on the pulley one outdrive will pull while the other takes a bit to catch up.
Peace,
C
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 09-11-2007, 03:41 PM   #5493
RBLove's Avatar
Trader Rating: 71 (100%+)
Thanks Schreff!
RBLove is offline   Reply With Quote
Old 09-12-2007, 01:33 PM   #5494
37 RACING's Avatar
Trader Rating: 43 (100%+)
what's a good rubber tire for a med bite carpet track
37 RACING is offline   Reply With Quote
Old 09-12-2007, 07:12 PM   #5495
RBLove's Avatar
RP30 is a great rubber tire for just about any condition.
FYI. Horizon did have kits in stock. They had a system error which still shows as mid-December, but they are indeed available..
Old 09-13-2007, 06:11 AM   #5496
mojoman's Avatar
The control tire at the Birds last year was a cs27. A little more grippy than a rp30. But both will work fine.
Casey Castleman
Old 09-13-2007, 11:42 AM   #5497
morris's Avatar
Trader Rating: 40 (100%+)
im in the build right now...had to stop due to the heat shrink that goes over the dogbone...well there was only one peice that was almost a perfect fit...so i got another peice today....whats up with having to take some plastic out of the caster block.....will this have to be done to say other caster blocks to get them to fit?hope not for it can be a time consuming project.....
back to the build a little later today...
matt
morris is offline   Reply With Quote
Old 09-13-2007, 12:31 PM   #5498
J@UNE's Avatar
I guess if you use rcd instead of lcd you will be fine. Shaving the plastic takes less than a minute with an exacto I don't think its an issue... I beleive customizing parts is one of the coolest parts of that hobby anyways
J@UNE is offline   Reply With Quote
Old 09-13-2007, 02:16 PM   #5499
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I was gonna say that exact thing.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 09-13-2007, 02:36 PM   #5500
Glowster21's Avatar
Trader Rating: 116 (100%+)
I don't mind shaving the plastic, but I did mind missing 1 piece of shrink tube, 1 battery foam strip, and 2 sway bars out of the sway bar set I got. Time to do a little QC training......
Glowster21 is offline   Reply With Quote
Old 09-13-2007, 02:36 PM   #5501
TheCoolCanFanMan's Avatar
I now have a Clonosi see this link Hot Bodies Cyclone
#9616 & 9617 & 9630 & 9631 Go The Clonosi
Malc The I cant keep myself from medaling Man
TheCoolCanFanMan is offline   Reply With Quote
Old 09-13-2007, 04:12 PM   #5502
RussB's Avatar
Send a message via MSN to RussB
what's funny about that is i've been using cyclone cvd bones with losi cvd stub axles on my car. for some reason i haven't had much luck with the lcd's or rcd's. i run on a track with some really heavy wood barriers and was probably breaking a driveshaft once a race day. once i went with the cvd's i've had no breakage.
RussB is offline   Reply With Quote
Old 09-13-2007, 05:27 PM   #5503
STLNLST's Avatar
Trader Rating: 19 (100%+)
stay off the boards.....ha ha ha ha How's the life of a new father treating you? Congrats again bro.
STLNLST is offline   Reply With Quote
Old 09-13-2007, 06:43 PM   #5504
Matt Howard's Avatar
don't you have a schumacher thread to fill up with your non stop blabbing
Matt Howard is offline   Reply With Quote
Old 09-13-2007, 09:14 PM   #5505
STLNLST's Avatar
WHAT'S UP 1/8 SCALE BOY....HE HE HE HE
Too bad you aren't here anymore. We are all going to norcal this weekend. Track is killer for mod sedan and the racing crowd is cool and laid back. All that's really missing is you, Alex, and Dujuan.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
