Old 09-10-2007, 03:13 PM   #5476
schreff's Avatar
Send a message via AIM to schreff
Hey guys...
I know some of you were looking for a carpet rubber tire setup. What Larry and I came up with is attached to this post. It's hard to say whether this setup will work or not at Vegas. The car had plenty of steering, but lacked a little rear grip. I'm sure the newer Jaco Greens will fix that as we had the older thin treaded version. I honestly think the car is an A Main capable car with the way it ran when we drove it. Now with Tags driving it, that's another story.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 09-10-2007, 04:45 PM   #5477
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by schreff View Post
Hey guys...
Huh, very interesting. I'm anxious to hear how it does for you guys at IIC. Are you both going to run foam and rubber? I guess I don't remember seeing you guys do rubber in the past.
So you went with the one-way low in front and the diff high in the rear? I think that's first time I've seen that on this car.
syndr0me is offline   Reply With Quote
Old 09-10-2007, 04:55 PM   #5478
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Neither of us are running rubber at the IIC, we're just doing the legwork for Tag. I will run rubber again at the Birds casue I'll be allowed to run 3 touring classes.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 09-10-2007, 04:57 PM   #5479
schreff's Avatar
Tags was having troubles with his car so he sent it to us. We ran about 10 packs through it in total. The tires on it are pretty much useless at this point. The high rear diff helped middle of the corner rotation. I think with new tires, the rear diff would end up being put back to low. Keep in mind, we had very limited time with Tags car and we were on pretty used up tires. Also, always keep an open mind about car setup.
-Jason Schreffler-
Old 09-10-2007, 04:59 PM   #5480
syndr0me's Avatar
Ah, cool, that's nice of you guys. Maybe you can win 'em both this time!
Old 09-10-2007, 05:02 PM   #5481
schreff's Avatar
Not if I have something to say about it.
Oh, wait, I'm running 12th scale at SnowBirds. Larry can have fun in stock rubber again.
-Jason Schreffler-
Old 09-10-2007, 05:04 PM   #5482
syndr0me's Avatar
Oh definitely, I'll always keep an open mind to what other people are trying. I'm just now getting to the point where I'm trying to understand how each adjustment affects the car, and how the changes work together. Martin Crisp's book has been a really good learning tool. I read it all the time and retain something new each time I do.
That's another thing I've been enjoying about rubber tire. It seems like small setup changes make more of an impact, and things seem to work the way I'd expect from what I've learned from the books. Foam tires, not so much. I find foam setups really frustrating to figure out, but everything has made sense with rubber so far.
Old 09-10-2007, 05:07 PM   #5483
syndr0me's Avatar
You guys have been way more helpful than the mutes in the old Corally thread. Appreciate it.
Old 09-11-2007, 12:00 AM   #5484
s13evo's Avatar
Hello, im new to the forum and just finished building the type R.
i got 2 problems with it so far tho. wondering if anyone could help me out?
#1.When using the 41T spool ,why is it the belt stays very loose. when using the stock diff i can tighten the belt very good but not when using the 41T spool.
is there a special smaller size belt when using he 41T spool? or any other modification needed to use the 41T instead of the 42T?
#2.why does my car swerve to the side when at full trottle, but goes very straight from slow rolling start to high speed. but when i torqe it it always swerves to that oneside again. forgot which side it serves too. is my diffs too lose? or is that normal?
s13evo is offline   Reply With Quote
Old 09-11-2007, 05:59 AM   #5485
Yeti35's Avatar
You really don't want the belt super tight anyhow, but it does work with the 41 since that is what I run in mine. It will be loose but not so loose that it will come off the pulleys.
I had this same issue with steering until I went completely through the steering and evened everything out. Mine is currently setup in such a way that I may be off 5 clicks to the right on subtrim and I am at 70% EPA on left and right. You just need to get the steering centered more from the start or you will experience this issue. The link between the servo and steering rack is an adjustment as well. It just does not say that really in the book.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 09-11-2007, 11:44 AM   #5486
Trader Rating: 71 (100%+)
My LHS just called me and said the Type R's are on backorder with Horizon. December is the tentative date if they become available again. Weird
RBLove is offline   Reply With Quote
Old 09-11-2007, 11:46 AM   #5487
syndr0me's Avatar
Uh oh. :-(
Old 09-11-2007, 11:48 AM   #5488
syndr0me's Avatar
Horizon's site is doing that weird thing where it says it's out of stock, but you can still add it to your cart. I think they've got issues keeping their web site in sync with the inventory for multiple warehouses. Anyway, it still says they're being shipped out of the California warehouse.
Old 09-11-2007, 11:59 AM   #5489
He doesn't order online. He was working with his Horizon sales person. Per my LHS neither location has them. Just seemed really odd. Maybe it is just a system error.
Old 09-11-2007, 12:17 PM   #5490
syndr0me's Avatar
I did notice they're out of one-ways. :-( I grabbed two from Stormer just to be safe.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
