Old 09-09-2007, 01:24 PM   #5461
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by schreff View Post
As Larry said, I've put about 3 one-ways together now.
I've only had 1 of the 3 have issues with one of the bearings. One of the needles fell out and it's gone. The one-way is in a car right now and it seems to work just fine. That's not to say an issue won't occur though. It's in Tags car and we ran it like 10 packs over this past weekend with no issues.
Looking over the instructions again, it looks like maybe I did something wrong with the o-rings. They go inside the housing? Also, is there a trick to getting the pins to seat inside the one-way bearing when assembling the whole thing?
I don't suppose there's any hope of replacing the one-way bearings? They seem to be in there pretty well.
syndr0me is offline   Reply With Quote
Old 09-09-2007, 01:33 PM   #5462
schreff's Avatar
Send a message via AIM to schreff
I think the one-way bearings are pressed in. I didn't try taking them out so ya got me there.
And as far as the o-rings, yes they go in the housing. That was one of the things Tags didn't put in when he first built his. He forget the o-ring and the one-way would fall apart in the car while running. That o-ring holds in the washer that holds the little axle piece that rides on the bearing. If you forget that o-ring, the whole assembly can float and eventually fall apart.
Basically, you put the small axle piece in, then the washer, then the outdrive bearing, and then the o-ring. The last part is bolting the outdrive to the small axle piece and you should be good to go.
Hope that helps.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 09-09-2007, 01:51 PM   #5463
syndr0me's Avatar
That helps quite a bit. It make sense now, but it sure isn't clear from the instructions. I had the o-rings installed wrong (outside). Hopefully that's all it was. I've got another one-way coming, so I'll be sure to get it right this time.
The bearings look forced in there. I imagine they could be drilled out, but I'm not sure if installing a new bearing is feasible. I think I can read the number on the existing one, maybe I can find a part number and some dimensions, and looking into finding replacements. Maybe even better bearings, if they exist.
Old 09-09-2007, 02:06 PM   #5464
syndr0me's Avatar
Okay, I get it now. I just practiced with the good half of my existing one-way and got it right. The hub bearing goes way down in there. Schreff, do you have any trick for getting it to slide down into the hub easily? Heating the one-way tube up on that end first seemed to help, but I don't want to damage the plastic parts of the one-way bearing.
Old 09-09-2007, 02:16 PM   #5465
schreff's Avatar
I didn't use any special tracks there. I just tapped the hub bearing in with the tip of a wrench until it was in all the way. I didn't try heating it as I'm sure the one-way bearing wouldn't like that very much.
-Jason Schreffler-
Old 09-09-2007, 05:38 PM   #5466
syndr0me's Avatar
Cool, thanks for the help. I'll be sure to get it right with the next one.
I'm building a new kit, and I opened a package of "new" front arms to replace the ones that came with the kit. I noticed it came with new locating pins for droop, they're silver instead of black. Any chance they're less brittle? I've cracked a few in the front adjusting droop, especially working the wrench around the outdrives for the one-way. The new rear arms still had the black screws.
Old 09-09-2007, 06:08 PM   #5467
schreff's Avatar
My latest kit and arms have silver screws too. I haven't cracked any of them. Maybe you need a torque wrench.
-Jason Schreffler-
Old 09-09-2007, 06:15 PM   #5468
syndr0me's Avatar
Hahah, maybe so! I don't know WTF I'm doing wrong, but I spent 5 minutes getting the last one out with a pair of pliers. It seems like an odd angle to get to the front screws with the one-way in. It's probably my cheap Integy wrenches. Every time I think I'm ready to get something nicer (XRay) they're out of stock.
Old 09-09-2007, 06:17 PM   #5469
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Anyone looking for a Type R I have a brand new one built for sale.
New JRXS-R and KO VFS-1 speedo for sale
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 09-09-2007, 06:58 PM   #5470
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Got a relatively full day of carpet practice today at our local spot, Bending Corners in Orange, CA. I was testing setups for Vegas and here's where I will be starting...
Stock Foam TC
indoor/temporary Ozite track/medium bite/tight/90' straight
Front
0 toes
4mm ride height
-2 camber
0 kick/dive
6 caster
1mm over ride droop
0 pivot
low roll center
arms middle
#1 tower
#2 steering rack
#1 spindle
Standard Camber link
short + 0.030 ball stuf
no swaybar
front diff, 42 T
low diff
LCD's
0.225 Losi hex
60/56 piston
25 lb spring
Losi black bladder/nothing above
2 0.030 washers under tall ball stud/steering rack
1 0.030 washer under tall ball stud/spindle
Rear
3 toe
4.5 mm ride
1.5 over ride/droop
-2.5 camber
0 pro/anti
0 hub/standard
2 rear pivot
low roll center
arm forward
#2 tower/inside on arm
7-A camber link/tall ball stud w/ 2 0.030 washers
no swaybar
diff low
RCD's standard 0.165 Losi hex
50/56
20 lb spring
Protoform Pontiac G6 body, standard wing
Trinity Co27 motor/4499 brushes/purple pos/neg springs
126 PRS spur
36 PRS pinion
Jaco 26mm 2-stage foam, double pink front and rear
57.5 mm, Jack the Gripper sauce
2/3 front, full rear
I started with setup information provided by Andrew Gray, who developed a similar setup at the Vegas Warm Up event at Competition Hobbies last month. I made a few changes on my own to free up the rear of the car and by the end of the day, this setup was right on the edge of being too twitchy on a medium bite track. I think having a 'free' car, one that rotates quickly without scrubbing corner speed, is essential for stock foam sedan. I also tried the DNA and Parma Alfa bodies, but they provided just too much downforce. My fastest lap times of the day were done with the G6 body, which provides less intial turn-in, but more/faster corner rotation. I also felt like it was faster down the straight. I am sure many of you will scoff at my body of choice and who knows if it will work well at Vegas, but I will stick with what I learned today to start....
Good luck.
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 09-09-2007, 07:45 PM   #5471
morris's Avatar
Trader Rating: 40 (100%+)
i just got my type-r car tonight...i havent even started the build yet.
before doing so i was curious if any of you guys have been running rubber tires on carpet?
and which set-up should i try.
also i was reading in the book about adjusting the diffs?
i found that a little weird the way they were doing it.....hmmm....
anyways any help i would greatly appreciate it...
thx,
matt
morris is offline   Reply With Quote
Old 09-09-2007, 07:53 PM   #5472
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
once in the car you adjust like any other diff. Put wrench in and turn the wheel.
The directions just show how to tighten the diff when you build it.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 09-09-2007, 09:49 PM   #5473
syndr0me's Avatar
I've been doing rubber tires carpet for a few weeks now, with decent success. I believe Larry, Schreff and some others will have a few setups to share (rubber and foam?) after the IIC in a few weeks.
As for the diffs, Todd made an interesting post a while back about how the diffs are different, which may explain the odd adjustment. You can read it here:
Team Losi JRXS Type-R
Old 09-10-2007, 08:42 AM   #5474
Originally Posted by T. Hodge View Post
Using the LOSA3018 Thrust Assembly-His a key note on building your diffs on your JRXS. On the thrust assembly you will want to measure the outer diameter of the thrust assembly. You will notice that one of the thrust washers is larger in diameter. You will want to place this washer onto the diff screw first. Then put the caged ball assembly on the diff screw then slightly more lube around the caged bearing. Apply the next thrust washer (smaller diameter) next. Now you will want to use your 5 concaved washers in the opposite direction on the diff screw. You will want them in this orientation
instead of
Assemble the diff accordingly and you will notice a smoother diff.
Look at this. I know that the not-R is different from the R but I'm Help me
xtaiji is offline   Reply With Quote
Old 09-10-2007, 12:30 PM   #5475
morris's Avatar
i was told by some other peeps that the build was really easy....but im am usually the one having trouble with builds most of the time....i will just make sure that i take my time with it...and questions i will get on here and ask...i have met both fairtrace and schref and horsham and they both were cool...
thx guys,
matt
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
