Old 08-29-2007, 08:30 AM   #5311
jrxs-r's Avatar
As Greg has mentioned before, try stiffer springs. Depending on traction, I have run up to a 25 on the rear, and a 42.5 on the front! I have run high and low roll centers, and for my driving style, I prefer the low RC.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 08-29-2007, 08:32 AM   #5312
mojoman's Avatar
Originally Posted by syndr0me View Post
I replaced all the ball cups that I normally pop off for maintenance (shock tower in rear, hubs in front) and that seemed to remedy it somewhat. I'll have to give it some more time and see how it goes. Thanks for the suggestions. It's good to know I'm not alone.
The one-way not spinning evenly from side to side didn't seem to matter. The car stayed straight off-power, which is where I thought I might notice it. I just had a heck of a time keeping the rear end planted, even with 10.5lb springs. I've got a lot of things to work with though.
I know the car likes 3 degrees of to in the rear with foams, but what about rubbers? I went from 2 to 3 and it seemed like the car wanted to square up too fast.
Get rid of the one way if possible. The spool has more than enough speed to carry you through the corners. That should plant your rear end and give you some more stability.
Peace,
C
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 08-29-2007, 08:43 AM   #5313
jrxs-r's Avatar
Just a quick question for all the guys who run spools...
Given a neutral handling car with fairly tight diffs front and rear (little slip as possible) with rubber tyres on carpet, what would the car handle like with a 42T spool assuming the suspension settings are the same?
The reason for my curiousity is that most of the guys run one-way pullies or diffs, and not a single soul runs a spool. I don't use the one-way as it does not suit my style of driving.
Thanks!
Cheers,
Zack
Serpent S411
Old 08-29-2007, 12:28 PM   #5314
I noticed in a photo from the KO GP at West London this weekend that David Spashett was driving a JRXS-R, Has he gone back to Losi??
Is there many people running this car in europe?? I used to run a jrxs, Loved the car but fed up of no UK shops carrying parts. Like the look of the JRXS-R.
Bryan D is offline   Reply With Quote
Old 08-29-2007, 01:35 PM   #5315
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Is Spashett not sponsered by Tamiya anymore?
Dasupacat1 is offline   Reply With Quote
Old 08-29-2007, 01:39 PM   #5316
I actually think he has retired from racing?? But might be wrong.
Old 08-29-2007, 01:45 PM   #5317
got a link to those pics?
C_Suzuki is offline   Reply With Quote
Old 08-29-2007, 01:59 PM   #5318
http://ali303.8.dtiblog.com/
About half way down.
Old 08-29-2007, 02:05 PM   #5319
Super Moderator
Marcos.J's Avatar
Trader Rating: 174 (100%+)
Old 08-29-2007, 04:55 PM   #5320
hamster778's Avatar
Send a message via MSN to hamster778
Yes David was there with the Type R.
He did retire after the worlds last year and been working hard for Horizon Uk.
Earlier this year he went to Eastbourne for their open day for his first run with the new car. This was to be his second running of it.
He Qualified 10th in the A and finished 5th, his car look very good.
Cheers
Tim
hamster778 is offline   Reply With Quote
Old 08-29-2007, 05:19 PM   #5321
mojoman's Avatar
Thanks!
What I would do is loosen up the rear diff if running a spool. The one benefit of running a spool is your front drive train is locked, giving you more on power speed and making the car lean in as you turn. A one way does the same thing but does not give you the stability that a spool will. The spool works like drag brake the more you let off the more it will slow down. So if you take an example like rubber on carpet where you are not getting as much traction as foams a spool is beneficial because you can still carry the speed through the corners without making the car loose exiting the turn. Three degrees is more than enough to plant the car if you have the right setup. Hope this helps.
Peace,
C
Casey Castleman
Old 08-29-2007, 09:20 PM   #5322
cclifton's Avatar
Send a message via MSN to cclifton
Default Starting Point
I just picked up my next JRXS Type R and had a few questions maybe someone can help me with. I will only be running it on carpet and I was wondering on whats good for a starting point setup. How is the Kit setup for starters?. Also I was wondering what are good parts to keep on hand. I am moving from my T2 to this. We run on foams and will be running either stock or 19 turn for the most part.
Chris
cclifton is offline   Reply With Quote
Old 08-29-2007, 09:48 PM   #5323
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
Chris
here is a setup that andrew gray gave me when i got the car, its fast and pretty easy to drive...
its not in any kind of setup sheet but most everything is there...if you have any questions im sure someone has an answer
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 08-30-2007, 03:49 AM   #5324
cclifton's Avatar
Thanks alot for the info
Old 08-30-2007, 04:36 AM   #5325
Send a message via MSN to Grindog001
Yeah mate, i think i will be there. i have got me another type r to play with as well as the TC5. Just need to find a speedo
Originally Posted by JRXS_chris View Post
Grindey!
I tried dying the white pulleys on my JRXS once, just could not get the dye to stick. I'm glad Losi released the R pulleys in black, hides the dirt.
Your old Losi did well at the weekend Bq'd and finished second at the BTCC at Wrexham.
You at Stafford on thur? Martin and I are making an appearance.
Grindog001 is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
