Old 07-19-2007, 10:16 AM   #4951
GCracker's Avatar
See I knew dumping Physics and taking European Social and Economic History from 1750-1850 instead would come back to bite me in the ass
Uhm ya that is interesting and will require some thought given that what I thought was a minor change in camber link position actually has quite a significant effect on the pivots of the grounded and coupler links
GCracker is offline   Reply With Quote
Old 07-19-2007, 10:30 AM   #4952
Suspended
McSmooth's Avatar
Talking
Originally Posted by adavid View Post
Wow. I didn't think I'd see the day when four bar linkages were mentioned in an rctech post. Awesome.
...and from the guy who once had a picture of a human colon for his avatar.
Every now and then, we need to put the "Tech" back into this forum.
McSmooth is offline   Reply With Quote
Old 07-19-2007, 10:40 AM   #4953
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Originally Posted by GCracker View Post
OK now were getting somewhere, let me rephrase the question to take some of the confusion away.
What effect does legnth of the a-arm have on a car. Ignore shock positioning, and its effect on shock forces as this can be the same. But what really are the effects of the overall length of the a-arm and why is there a difference between a longer arm or shorter arm and hex which equates to the same legnth of the a-arm. Not sure if Im asking the question right. but the question is not who has the best car and what is right or wrong its more of a theoretically speaking why is this the case?
For those of you like myself with small children look at me as the one saying "WHY?" everytime someone says you should do this........ I like to understand the principles behind things not just that it works or doesnt work but WHY does it work? Maybe I should change careers
To lead you in the right direction...Roll Center Migration
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 07-19-2007, 10:49 AM   #4954
RussB's Avatar
Send a message via MSN to RussB
a-arm length has a lot to do with shock positioning and it's effect on shock forces. the arm pivots around the chassis hinge pin, and if that length from the chassis pivot to the shock attachment point on the a-arm is shorter, which it will be on a shorter arm, the shock motion will be different.
RussB is offline   Reply With Quote
Old 07-19-2007, 10:55 AM   #4955
GCracker's Avatar
Not just that but also brings into play the role of downstops and upstops and camberlink angles hmmm its gonna be an interesting flight home from SoCal
Old 07-19-2007, 10:56 PM   #4956
TLRacing
Todd Hodge's Avatar
Originally Posted by rcarmchl View Post
I am running Hodges 06 nat's setup and was curious about a couple of things....he has the front hex at .225 and the rear at stock...if I take the rear out with the .195...wil that make it a little more stable through the turns? Also, with reguard to Caster what affect does increasing the angle have (go from 4 to 6)? and conversly from 6 to 4?
Most likely if you move the rear out to .195 your car will be too wide. I always run .165 in the rear.
On asphalt you will have less overall steering as you increase the caster.
Todd Hodge is offline   Reply With Quote
Old 07-19-2007, 11:01 PM   #4957
Trader Rating: 34 (97%+)
Send a message via AIM to King of B Main
Todd,
I hope you make it out to the BCR track sometime... They are having a summer slam race on the Aug. 18
King of B Main is offline   Reply With Quote
Old 07-20-2007, 08:58 AM   #4958
rcarmchl's Avatar
Trader Rating: 15 (100%+)
I am currently using an airtronics servo with the #23 horn....is that right? Someone mentioned that there was a typo in the manual...any help? Ihave stripped one and the second one doesn't quite fit right.....
rcarmchl is offline   Reply With Quote
Old 07-20-2007, 09:20 AM   #4959
jrxs-r's Avatar
Default Updated setup
Hey guys. Tried this new setup, and it works remarkably well. Only thing that is lacking is driver skill...
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 07-20-2007, 04:58 PM   #4960
Yeti35's Avatar
They are not right, for it was calling for a 25 for my KO and they did not work right. 23 is what worked on the KO, just try the other two and see what one fits better.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 07-21-2007, 09:56 AM   #4961
RussB's Avatar
oh man i love this car more every time i run it
i ran bl 13.5 stock again last night and held tq until the final round where i got edged out by 2 seconds. my fast round had quite few "bad" laps at the start, so i know there was room to improve. in the main i got bumped down to last by the 3rd place car, had to work my way up. i worked up to about 3 seconds off 1st and 2nd and finished 3rd. i had probably the 5 fastest laps of the main though when i was reeling those two in.
time spent cutting motors: 0 minutes and 0 seconds
time spent fixing broken parts: 0 minutes and 0 seconds
time spent checking setup: less than 10 minutes for the whole night.
Old 07-21-2007, 10:51 AM   #4962
syndr0me's Avatar
Trader Rating: 32 (100%+)
I'm with you, I feel the same way.
But in case you didn't hear, brushless is only for beginners. :-)
syndr0me is offline   Reply With Quote
Old 07-21-2007, 11:16 AM   #4963
RussB's Avatar
yeah, it's soooo slow compared to brushed. actually, i did get spanked on the straight by a guy running a co27, but whatever. i *could* probably go up a tooth or three at night, but i'm already at 4.9 for temperature reasons during the heat of the day.
Old 07-21-2007, 11:31 AM   #4964
i ran bl 13.5 stock
with rubber tires? what was your spur/pinion?
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 07-21-2007, 11:34 AM   #4965
RussB's Avatar
rubber tires. i was running 114/42. i use the PRS adapter, so i can run any standard spur.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
