Old 07-16-2007, 10:19 PM   #4906
GCracker's Avatar
Default Chadwicks Setup
I dont have a printer so heres the text format, if someone wants to put in blank setup sheet and post all good
Bending Corners Raceway, Orange, CA Outdoor Asphalt, openish, med-high bite
FRONT
Front Toe.....0'
Ride Height.....5.2mm
Camber.....-1.25
Kick/Dive.....N/A
Caster.....4
Droop.....2.5
F Pivot.....0
Roll Center.....Low
Arm Spacing.....Middle
Shock Position.....2
Steering Rack.....2
Spindle Ackerman.....1
Camber Link.....3
Camber B/Stud.....Std
Sway Bar......N/A
Up Travel.....N/A
Arm Length.....Long
Front Drive.....Spool
Pulley.....42
Diff Height.....High
Drive Axle.....LCD
Hex width.....Stk
Oil......Losi 35
Piston.....56
Spring.....15
Bladder.....Black
Above Bladder.....NONE
JR Link.....Low
Washers under B/Stud.....0
Ball Stud.....Std
REAR
Toe.....3'
Ride Height.....5.4mm
Droop.....4
Camber.....1
Anti/Pro Squat.....N/A (but an option to get more rotation and forward bite)
Hub.....Std
Roll Center.....Low
Arm Spacing.....Front
Shock Position.....3/outside
Camber Link.....5
Ball Stud.....Std
Sway Bar.....N/A
Up Travel......N/A
Arm Length.....Long
Diff Height.....Low
Drive Axle.....RCD
Hex Width.....Stk
Oil.....Losi 30
Piston.....56
Spring.....10.5
Bladder.....Black
Washers.....N/A
Body.....Mazda Speed 6 wigth Ride Wing
3.5 B/L
128 Spur
25 Pinion
FDR 9.37
5 Cell
4200 cells
RP30s, Stk PG Insert, Speedmind soft rims
Buggy Grip for traction compound
GCracker is offline   Reply With Quote
Old 07-17-2007, 07:48 AM   #4907
TLRacing
Todd Hodge's Avatar
Originally Posted by vabroom View Post
Good to hear, didn't realized that there was a small turnout. Too many big races or is TC running out of steam?
Honestly I think both, there are major TC races almost every month. In the summer there are very limited asphalt races so it is loosing some popularity. I think TC is going through a transition period with battery and motor technology. Eventually it will be easy once we are allowed to solely run Lipos and Brushless motors in all classes.
Todd Hodge is offline   Reply With Quote
Old 07-17-2007, 07:52 AM   #4908
TLRacing
Todd Hodge's Avatar
Originally Posted by gee-dub View Post
Follow-up question: Do you, representing a manufacturer, feel that Horizon's increasing lack of participation (i.e. 1/8 Worlds, 1/10th TC Nats., etc.) for sanctioning body's "premier events", diminishes the importance and popularity of those events?
Thanks in advance for your time.
We make decisions based on what is going on at the time. It only makes business sense to do so. You mention the 1.8th Worlds, we were simply not prepared to attend last years WC. As for the TC Nats, it was a decision based on the turnout. By no means is Horizon telling us what we can and can not do. You also have to look at where the market is right now and you have to invest wisely where the market is telling you to do so.
Old 07-17-2007, 08:46 AM   #4909
GCracker's Avatar
Todd, Thanks for answering my question re: ETA on the one ways for the Type R. Going back east just in time for carpet season and no one ways for the foamies
Old 07-17-2007, 09:12 AM   #4910
rcarmchl's Avatar
Trader Rating: 15 (100%+)
FRONT
Front Toe.....0'
Camber.....-1.25
Kick/Dive.....N/A
Caster.....4
Droop.....2.5
F Pivot.....0
Roll Center.....Low
Steering Rack.....2
Camber Link.....3
Sway Bar......N/A
Up Travel.....N/A
Arm Length.....Long
Pulley.....42
Drive Axle.....LCD
Hex width.....Stk
Oil......Losi 35
Piston.....56
Spring.....15
Bladder.....Black
JR Link.....Low
Ball Stud.....Std
REAR
Toe.....3'
Droop.....4
Camber.....1
Hub.....Std
Roll Center.....Low
Camber Link.....5
Ball Stud.....Std
Sway Bar.....N/A
Up Travel......N/A
Arm Length.....Long
Diff Height.....Low
Drive Axle.....RCD
Hex Width.....Stk
Oil.....Losi 30
Piston.....56
Spring.....10.5
Bladder.....Black
Washers.....N/A
3.5 B/L
128 Spur
25 Pinion
FDR 9.37
5 Cell
4200 cells
Hey Cracker....I mean Gcracker..don't want Rev. Sharpton on my case....
On the rear setup for the arm sapcing it says "front" - does that mean that the spacer is towards the front of the car or the spacer is on the rear moving the arms to the "front"?
rcarmchl is offline   Reply With Quote
Old 07-17-2007, 09:24 AM   #4911
GCracker's Avatar
Spacer is towards the rear against the outer pivot
Old 07-17-2007, 10:31 AM   #4912
Trader Rating: 21 (100%+)
Check the Horizon site in a few days. Info should be listed on there with a estimated ETA for them. Also look for the weighted Lipo battery tray.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 07-17-2007, 10:38 AM   #4913
Need some help. I run on somewhat dusty parking lots. And found that my rear diff gets very dirty fast...it gets packed full with dusty. Is there any tricks, or cover that I can buy to keep it clean? i even tried not putting lube in it, but it still get pack full with dusty.
chumanji is offline   Reply With Quote
Old 07-17-2007, 10:39 AM   #4914
GCracker's Avatar
Woohoo
Old 07-17-2007, 10:41 AM   #4915
GCracker's Avatar
You have a leaf blower and an outdoor broom?
Old 07-17-2007, 11:01 AM   #4916
Yeti35's Avatar
Buy yourself a small air compressor to blow it off after every round. That is just the nature of parking lot racing, not much you can do.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 07-17-2007, 01:22 PM   #4917
J.Filipow's Avatar
Did somebody say 'one-way'?
Front One-Way Assembly: JRX-S Type R-LOSA3358
Lightened aluminum housing
One-way bearings on either side
Wide diff provides support for high bite tracks
All necessary hardware included
The LOSA3358 Front One-Way Assembly is a drop in unit that replaces the stock front differential. The assembly includes a precision machined and lightened aluminum housing with one-way bearings in either side, outdrives, shafts, one-way pulleys, dogbones and all hardware. This type of one-way is a popular tuning item with racers who like and aggressive set up and/or run in extremely high bite conditions. Typically a front one-way will yield better acceleration out of a turn but does not have any braking capacity and is less forgiving. The front one-way can also be helpful in carrying greater corner speed on high-speed tracks with sweeping turns. All parts for the JRX-S Type-R front one-way are available separately.
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 07-17-2007, 01:23 PM   #4918
J.Filipow's Avatar
Or did somebody say 'Lipo tray'?
JRX-S Type-R Steel LiPo Battery Tray-LOSA4312
Allows existing JRX-S Type R owners a direct fit option for standard LiPo battery packs
Adds an additional 120 grams to offset the reduced LiPo battery weight
The additional weight is place in the most ideal position possible ( placed directly in the center of the chassis and as low to the ground as possible
Finished in an attractive gloss black and engraved with the Type-R logo
Old 07-17-2007, 01:33 PM   #4919
syndr0me's Avatar
Trader Rating: 32 (100%+)
BOOOOOOOOOOOOOOYA! We wants it!
syndr0me is offline   Reply With Quote
Old 07-17-2007, 01:37 PM   #4920
mojoman's Avatar
I'm gonna assume this was the old one way for the original JRXS. I was recently at a race with Andrew and he was sporting the prototype not yet available from horizon that did not require the use of the short arms and even shorter dogbones. It was my impression that the design was finished. Losi is looking for a manufacture to mass produce the new one way.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
