Old 07-09-2007, 11:09 PM   #4861
RussB's Avatar
Send a message via MSN to RussB
i use a xxx4 slipper cluth wrench with one of the sides cut off.
or one of the small allen wrenches that came with the kit, that's about all they're good for.
RussB is offline   Reply With Quote
Old 07-10-2007, 01:53 AM   #4862
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
so i was diggin through my box of S parts and found a center pully hub w/ 1 way, has anyone tried that? it seemed to fit so im gonna run it and see how it works....
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 07-10-2007, 04:54 AM   #4863
J@UNE's Avatar
Will it run on the same side? I though the belt were fliped.
I like having 2 oneway on my T2.
I'm currently building a one-way/multidiff out of my Xray diff... Will post pic once completed
J@UNE is offline   Reply With Quote
Old 07-10-2007, 02:50 PM   #4864
Trader Rating: 21 (100%+)
Rear wheel one-way?
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 07-10-2007, 03:48 PM   #4865
Yeti35's Avatar
You could use that center oneway, but it would make the rear of the car freewheel, not the front. It was made to swap out on the spur side of the shaft and that did not change on the new car. So in theory it would fit, just would not be for the right end of the car.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 07-10-2007, 08:47 PM   #4866
mojoman's Avatar
The center one way will fit on the opposite side. You have to reverse it so the plastic side is to the outside of the layshaft. Now in theory this will work. In a practical situation the pulley will come loose from the shaft and leave you with bearings on the track and a rear wheel drive car for about two laps until you hit a wall and break an arm. I had a friend try and take the rabbit bearing out of the pulley to put it back in the other way and he had no success (it's a pretty tight fit). But that is the only way you can get that center one way to work in a five minute race, unless losi releases the kit soon.
Peace,
C
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 07-10-2007, 09:02 PM   #4867
well it seems to work like a 1 way.....i wrenched on all the tires and nothing gave.....i will just have to run it and see...lol
Old 07-11-2007, 03:32 PM   #4868
mojoman's Avatar
Good luck bro. But I tried to warn you. (Insert disclaimer here_____).
Casey Castleman
Old 07-12-2007, 04:02 PM   #4869
level-4's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to level-4
Default 19 turn gearing
i just picked up a type r, what gearing range are people running with a 19turn money motor, i'm running on pavement medium sized track.
thanks level-4
level-4 is offline   Reply With Quote
Old 07-12-2007, 04:11 PM   #4870
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
thanks level-4
5.5- 6.0
Old 07-12-2007, 04:36 PM   #4871
level-4's Avatar
thanks marcos
Old 07-12-2007, 04:37 PM   #4872
schreff's Avatar
Send a message via AIM to schreff
thanks level-4
Ya, like Marcos said, I wouldn't go any lower than 5.5. The gearing we nomrally run at our medium sized track with sweeping corners is 128/42, which is 5.57.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 07-12-2007, 05:03 PM   #4873
morris's Avatar
Trader Rating: 40 (100%+)
schreff,
how does the car wrok out the box at horsham?
morris is offline   Reply With Quote
Old 07-13-2007, 05:37 PM   #4874
Send a message via AIM to ERTRACHTER
i never run my checkpoint money motor more than 6.0 and im usually around 6.3 and i never get pulled on down the straights
ASSOCIATED 12r5.1,REEDY MOTOR AND BATTERY, LRP SPEEDO,KIMBROUGH PRODUCTS,BIG DOG RACING,BELMONT R/C SPEEDSHOP, DENNIS LYMAN RACING, TEAM TOSO, TEAM FACTORY BITTER, SCHUUR SOLUTIONS, SIMMONS RACING, TEAM BOOZCRUZ
ERTRACHTER is offline   Reply With Quote
Old 07-13-2007, 06:27 PM   #4875
schreff's Avatar
Originally Posted by morris View Post
schreff,
I never actually ran the car "out of the box" at Horsham. The first thing I did was remove the JR Link and put the normal camber link on. I also changed the rear pivot from a 2 degree to a 1 degree to get 2 degrees total toe.
Other than that, the car was stock. It definitely worked good the couple times I got to run it there. Still have a lot more to try. Waiting patiently to get back to carpet.
-Jason Schreffler-
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
