Old 07-02-2007, 07:59 AM   #4756
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I have never popped a turnbuckle yet. I cut my axles down recently but even before I never popped one.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 07-02-2007, 08:44 AM   #4757
tallyrc's Avatar
Originally Posted by rcarmchl View Post
Are any of you guys having issues with the camber links, both front and rear, staying on? It seems any time that I brush the pipes that mine pop off from the chasis. I have changed them out several times and continue to have this problem.
I know the short answer is to stay off the pipes so you can save that one
Are you guys cuttng done the threads on the axels?
i asked the same Q a page back.. if your running the camber link long.. (outside on the hub and in on the tower, there is barely any thread in the the ball cups.. if you are gonna run it that way get longer turnbuckles like 24mm or 1" or get longer ball ends.. my car is used so maybe they were already worn, cause i took a corner real hard and that force alone poped one out..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 07-02-2007, 09:02 AM   #4758
jrxs-r's Avatar
Only when I have run the camber link in the long position with the standard turnbuckle it has popped off brushing a pipe. But I have not popped one off running the link in a shorter position.
I have built 2 Rs, and the open ball cups do vary quite a bit from packet to packet. On one car, they are relatively tight, and on the other they have noticable play. It must be a batch where they might have suffer less 'shrinkage' on cooling from the molding process. If the problem persists with using the camber link in the shorter positions, get a new set of open ball ends, and it should solve the problem.
Hope this helps.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 07-02-2007, 09:06 AM   #4759
Yeti35's Avatar
Any team guys hear anything about the oneway yet? I can't believe something like this is not out yet. I hope we are not waiting on it like we did the kit.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 07-02-2007, 09:58 AM   #4760
TheCoolCanFanMan's Avatar
Originally Posted by tallyrc View Post
yea it was good.. that track is tiny and twisty, so i really needed a lot of steering, but the car was stuck for sure.. till my shock popped off..
If your shock pops off, then use a 1/4 length buton head screw with a washer larger than the ball in the shock, use this idea top and bottom of the shock then the shock wont 'pop off'
Cheers Malc TCCFM
TheCoolCanFanMan is offline   Reply With Quote
Old 07-02-2007, 10:00 AM   #4761
rcarmchl's Avatar
Trader Rating: 15 (100%+)
Hope this helps.
Pretty sure I am running the shorter position and I have changed them multiple times, it seems that once they pop - you might as well replace cause it's gonna keep popping. i am going to trim down the axle as well. My issues is that it happens with the lightest brush, not like I am smacking the pipes at full tilt.....
rcarmchl is offline   Reply With Quote
Old 07-02-2007, 10:05 AM   #4762
tallyrc's Avatar
Cheers Malc TCCFM
that is exactly what i thought of the minute i even got the car.. we used to have to do this to the old rc10gt's to keep them on.
Old 07-02-2007, 10:10 AM   #4763
Its a nice easy little tip, as there aint nothing more anoying, used to do a simular thing on the XXX-S & JRX-S to
Malc TCCFM
Old 07-02-2007, 12:35 PM   #4764
Well, just got another Type-R after have a MI3 for the last 3 weeks. I borrowed an MI3 from a buddy and "thought" it was the kit to have. Being half a second faster per lap will make you do some stupid things! That didn't last of course. Even quicker with the Losi now! The MI3 is hands down better than the MI2 but that still didn't keep me from sending the free kit back. Setup changed dramatically from track to track. The aftermarket chassis didn't help at all either. The car doesn't tweak, it just doesn't work on every carpet track like the Losi. The Losi always has a good starting point. If you are a hardcore carpet racers that likes to run on asphalt every once and awhile get a losi. If you are a hardcore asphalt racer that likes to chase setup, get an MI3. Customer service is top notch at Shumacher but that doesn't win races.
jstikes is offline   Reply With Quote
Old 07-02-2007, 04:10 PM   #4765
hamster778's Avatar
Send a message via MSN to hamster778
well back from snetterton for the brca national
6 runs on track
5 broken wishbones
do'h
Tim
hamster778 is offline   Reply With Quote
Old 07-02-2007, 07:32 PM   #4766
RBLove's Avatar
Trader Rating: 72 (100%+)
6 runs on track
5 broken wishbones
do'h
Tim
Ouch. Have you purchased one of the extra firm bumpers from P-Dub or Parma?
RBLove is offline   Reply With Quote
Old 07-02-2007, 08:53 PM   #4767
Super Moderator
Marcos.J's Avatar
Trader Rating: 180 (100%+)
6 runs on track
5 broken wishbones
do'h
Tim
try this ,this should help you out a little bit
Old 07-02-2007, 08:56 PM   #4768
STLNLST's Avatar
Trader Rating: 19 (100%+)
The new arms are alot better than the original one's.
STLNLST is offline   Reply With Quote
Old 07-02-2007, 11:17 PM   #4769
Trader Rating: 35 (100%+)
Send a message via AIM to Sean R
Marcos - You know what a big bumper means...
Sean R is offline   Reply With Quote
Old 07-03-2007, 03:29 AM   #4770
Chrissy C's Avatar
6 runs on track
5 broken wishbones
do'h
Tim
That sounds like a very expensive and frustrating day mate, I'm sure this will stop when the new arms are here, until then can you go to the older, shorter versions?
I had a rear one go in the final, but it was driver error, i clipped a corner quite bad coming in to that dam round-a-bout!!
Are you at West London for the BTCC this weekend? I have entered mod, just waiting to hear if i made it in...still lots to try!
Chris
Chrissy C is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
