Team Losi JRXS Type-R
#4729
My front tires seem to wear more on rubber and foam. If you want to run the camber link in the longest position possible you will need longer ballcups or a longer turnbuckle.
#4731
Setup and driving style have a lot to do with it, but fronts typically always seem to wear a little faster. I drive extremely hard so my fronts are always wearing out.
#4734
#4736
Super Moderator
i used a set of old schumacher 24mm turnbuckles
http://www.racing-cars.com/usa/produ...ecnumber=44533
#4737
What can I do with this thing to get the rearend more planted on lowbite asphalt? Is there some change I can make to it in the rear that would allow this? I am pretty much using the Nats setup but with 6 degree fronts other then that it is on that setup. I works pretty good and is fast but the rear is twitchy sometimes. I also pulled to spool out of it and went with a diff, that seemed to help it handle a little better as well.
