Old 06-29-2007, 02:48 PM   #4711
Yeti35's Avatar
I switched to the standard link for I found the JR a PITA to adjust.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 06-29-2007, 03:35 PM   #4712
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Mark:: I am looking at Dumas' rear hubs and he is running 1 degree, which are you using?
Might want to consider foam... when I get my Type-R, it will be foam prepped. Dumas wants to prep for Vegas.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 06-29-2007, 04:00 PM   #4713
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
I modded my jr links to use a rear titanium turnbuckle. Easy to adjust, more strength.
Dasupacat1 is offline   Reply With Quote
Old 06-29-2007, 04:29 PM   #4714
Pics / Links / How-to?
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 06-29-2007, 06:09 PM   #4715
markf3x's Avatar
I'm running what ships with the kit (2 degrees on the inside pivot pin and 1 degree on the outside hub). I bought zero degree hubs to reduce the total to 2 degrees on the same order that I bought the rear wide hexes. I tried the hexes first and they worked so well, I never got around to trying the hubs.
Mark
markf3x is offline   Reply With Quote
Old 06-29-2007, 07:35 PM   #4716
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Thinking about getting a JRXS Type R for asphalt/rubber racing. Been reading the threads and will eventually go Lipos and brushless. What parts do you recommend for this type of racing in terms of spares and hopups? Everywhere that I had read said that the car was orginally designed for foam and carpet.
Also, what hex drivers and nut drivers are needed for the car?
cpatel529 is offline   Reply With Quote
Old 06-29-2007, 08:24 PM   #4717
Mark
Sweet, where are you getting your spares from?? Are you special ordering through Mike's??
V-Dezign 4.0
Old 06-29-2007, 09:29 PM   #4718
rcarmchl's Avatar
Built might out of the box for asphalt and rubber and it runs great. I think the only "hop-ups" you will be after are those lipo's ant that BL setup!!!
For spares I would got with:
Front and Rear Arms
Hubs/carriers
definately get a spool....
just the common items that might get mashed up.....if you do get a new kit you might be better off to go ahead and switch the front arms out, as the first ones were a little on the weak side.
rcarmchl is offline   Reply With Quote
Old 06-29-2007, 09:34 PM   #4719
What size hubs are used in the front? I was reading that 6 deg is pretty common now. Do you need a variety of sizes? I only plan on doing asphalt/rubber.
I am assuming that the carriers are all the same size.
Chirag
Old 06-30-2007, 07:33 AM   #4720
GCracker's Avatar
4 degree 6 would be for tighter more technical tracks
GCracker is offline   Reply With Quote
Old 06-30-2007, 07:45 AM   #4721
sportpak's Avatar
Trader Rating: 26 (100%+)
You remove the setscrew that forms the link in the JR setup. You then trim about .05 - .075 inch off of the ballcup. Now you thread in your titanium turnbuckle(same as the rear turnbuckle). Put it all together and you have what Losi should have come up with in the first place. I'll get a picture of mine for you in a little bit.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 06-30-2007, 08:14 AM   #4722
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
i posted a pic of that mod about month ago ill find it for you
here it is
Old 06-30-2007, 09:55 AM   #4723
sportpak's Avatar
Bingo! I looked a while for it and didn't find it. It's been awesome.
Anybody tried the 41T spool with rubbers on carpet? I'm gonna try it next. I'm preparing for war next fall. Car is getting good, just needs a little steering getting in with a little surer feel in the center. Our carpet over the summer is never the best, but I need to add a few feathers to my hat in tuning this thing.
Old 06-30-2007, 10:17 AM   #4724
here it is
That's COOL. I'll try.
xtaiji is offline   Reply With Quote
Old 06-30-2007, 01:52 PM   #4725
This one?
https://www.ssl-stormerhobbies.com/c...ns&pn=LOSA6532
www.freerice.com
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
