Old 06-19-2007, 10:35 AM   #4576
rcarmchl's Avatar
Trader Rating: 15 (100%+)
Are you guys still running the servo horn that came with the kit or are you running something else? Mine stripped out this past weekend and I replaced it with an aluminum one that doesn't take the ballstud on top - rather to the side. Should I go back to the kit horn?
rcarmchl is offline   Reply With Quote
Old 06-19-2007, 10:41 AM   #4577
jrxs-r's Avatar
G'Day guys... Thought that i'd share this setup with you. Its in the initial stages of running, and it still has a lot of work to be done. Still has a bit of understeer into corners, but rear end stays put quite well. On power steering is killer, and still nice and controllable.
Speed isn't really quick as I'm evaluating the LRP Eraser Brushless 13.5 for racing in the stock class. I'm probably about a tooth or two undergeared.
Hope this helps. I'll be posting a few more setups as soon as I get time to get out with the car....!
Here's a pic of the track.... pretty tight!
http://www.rcracephotos.com/special/eponroad.html
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 06-19-2007, 10:43 AM   #4578
jrxs-r's Avatar
Get the kit replacement unless anyone here knows of any others available. I've found them to be the best for fitment and height. It could be a little lower though.
Cheers,
Zack
Serpent S411
Old 06-19-2007, 11:28 AM   #4579
TheCoolCanFanMan's Avatar
Hi Guys
I know this has been asked many times but what is the thickness of the wire on the springs for all the different rates? as I have sooooo many springs without tabs on them that without a clue what the wire thickness is I cant tell them apart. Sooner rather than later on this one please asim sitting here trying to sort them out.
Cheers Malc The im getting frustrated Man
TheCoolCanFanMan is offline   Reply With Quote
Old 06-19-2007, 11:32 AM   #4580
hamster778's Avatar
Send a message via MSN to hamster778
Hey all as a reminder a guy was looking for the spring wire size chart...to tell them apart without the little stickers:
10.5lb .045"
12.5lb .047"
15lb .052"
17.5lb .054"
20lb .056"
25lb .060"
30lb .063"
35lb .066"
42.5lb .071"
50lb .072"
60lb .073"
Always worth while to keep this floating around...it was pretty buried over on the jrxs.com site.
this was posted by Mike Haynes way back on page 137
Hope it helps Malc, ( i ment to print it off for you)
cheers
tim
hamster778 is offline   Reply With Quote
Old 06-19-2007, 11:40 AM   #4581
Cheers Hammy
You coming to Wet London this weekend?
Malc
Old 06-19-2007, 11:43 AM   #4582
hamster778's Avatar
Hi Malc
yep I'll be there, fingers crossed it will be dry, I need to get some running there with the new car (always been wet).
Are you?
Tim
Old 06-19-2007, 12:00 PM   #4583
rcarmchl's Avatar
thanks....
Old 06-19-2007, 01:31 PM   #4584
GCracker's Avatar
just as a matter of interest are there any other kits that use the same sway bars (not the hardware just the bars) as the typr R?
GCracker is offline   Reply With Quote
Old 06-19-2007, 01:31 PM   #4585
GCracker's Avatar
just as a matter of interest are there any other kits that use the same sway bars (not the hardware just the bars) as the type R?
Old 06-19-2007, 01:53 PM   #4586
tallyrc's Avatar
why did losi move away from the colored springs? people not want folks to know what rates they were running?
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 06-19-2007, 05:48 PM   #4587
Mike Schumacher's Avatar
Trader Rating: 36 (100%+)
Unpainted springs are much more consistent on performance. Losi unpainted springs come with rate number labels (for yourself to keep track).
Mike Schumacher is offline   Reply With Quote
Old 06-19-2007, 09:48 PM   #4588
Trips's Avatar
Trader Rating: 16 (100%+)
Unpainted springs might be more consistent, but all my JRXS springs are painted black...
MARSHAL!!
Trips is offline   Reply With Quote
Old 06-20-2007, 01:02 AM   #4589
Good Day
At my local track in Australia, in 540 Class, All the fast guys are running Schumachers, including myself. These seem unvbeatable in 540 class, But spares are scarse now for the older mission and mi2's. I have come to think that these cars are fast in 540 class due to the drive train layout and the efficiency of the drive train. Would i be able to be just as fast with the losi in 540 class ?. we normally run an FDR of 4.1. Can the Losi use diffrent spurs, or does it need an adapter for it ?.. I am looking for a car where it is just as fast (if not faster) than the mission and mi2's in 540 class?
Thanks ya'all
MoonTrap is offline   Reply With Quote
Old 06-20-2007, 08:12 AM   #4590
jrxs-r's Avatar
I do believe so. Almost all of the cars in the top end range of the market will be good. It mainly comes down to the drivers and setups.
PRS sell a spur gear adaptor that will take most aftermarket spurs on the market. The JRXS-R uses 64dp spurs out of the box, and option 48dp spurs are available too.
See above.
I think Stanbridges Hobbies in Perth have a huge range of spares in stock for the Mi2s. A fellow racer that runs the Mi2EC gets almost everything from them.
Cheers,
Zack
Serpent S411
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
