Old 06-17-2007, 07:32 PM   #4561
Mike Haynes's Avatar
You could try running some front arm sweep out or using anti squat in the back, i used both when running outside and it seemed pretty good.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 06-17-2007, 07:49 PM   #4562
HarshGuy's Avatar
Originally Posted by STLNLST View Post
I got this car rockin' in the hot heat in Roseville, Ca. This car is so easy to drive. Hit on a set up that was to die for. I'll get it posted shortly for those of you that want to try it. It's for med grip tight outdoor track with rubber tire's. Track temp reach as high as 150 this weekend. Had some hard hits and the only broken part was a right front caster block and split the plastic ball cup NO MORE FRONT ARM ISSUES The new arms are molded correctly and can take the hits on the boards a lot better than the previous arms. Those of you that have been to Speedworld know what I'm talking about. Can't wait to run again
It brought a tear to my eye to see you running so well, car looked great
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 06-17-2007, 08:06 PM   #4563
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
didnt u strip a spur to?
but u had some NICE lap times
BlackedOutREVO is offline   Reply With Quote
Old 06-17-2007, 08:51 PM   #4564
STLNLST's Avatar
Trader Rating: 21 (100%+)
Spur wasn't a losi part so that's probably why it stripped out.....
It happened when I was hard on the brakes at the end of the straight. I wasn't even running my big boy motor That track was very tight and not really a mod friendly layout. Stock was running close to mod times. Glad I got my car working great.
STLNLST is offline   Reply With Quote
Old 06-17-2007, 09:55 PM   #4565
lol ahhhh i c
and yeah, im novice and i got down to 15.3... which for me was sweet! lol
Old 06-18-2007, 02:30 AM   #4566
hamster778's Avatar
Send a message via MSN to hamster778
Hi guys
On the set-up sheet, i see that Losi have a 2 deg rear hub.
Does anyone know when this will be available
Cheers
Tim
hamster778 is offline   Reply With Quote
Old 06-18-2007, 02:19 PM   #4567
JRXS_chris's Avatar
Really?? I have never come across one of them before. You must be thinking of the rear inner toe in angle which is 2 degrees kit (2 dots on the aluminium bar stating 2 deg). The toe in blocks are only available in 0,0.5,1 as far as im aware...
2 degrees is pretty immense!
JRXS_chris is offline   Reply With Quote
Old 06-18-2007, 02:25 PM   #4568
hamster778's Avatar
Thats what i thought, as i have always wanted them for my old car.
But look at the new setup sheet
Cheers
Tim
Old 06-18-2007, 02:35 PM   #4569
RBLove's Avatar
Trader Rating: 72 (100%+)
Cheers
Tim
This set up shows "std 0 degree hub" with a 2 degree rear toe pivot block. This is what comes in the kit. The car has 1 degree of toe built in, plusthe 2 degree pivot gives a total of 3 degrees.
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Old 06-18-2007, 02:42 PM   #4570
hamster778's Avatar
Yes i can clearly see that
Losi have given us the options of standard and off set rear hubs
These hubs as it says on the sheet they are,
0 deg
1/2 deg
1 deg
2 deg
They are the choices we have.
By moving the toe out to the hubs, you get less weight transfer to the front, which i want to try,
Any one know when they will be out or at least a part number
Cheers
Tim
Old 06-18-2007, 03:03 PM   #4571
hamster778's Avatar
Hi guys, i've posted up some new spoony pictures of his lastest adventures. He went up to halifax with me for the national.
Spoony Adventures
Enjoy
Tim & Spoony
Old 06-18-2007, 04:27 PM   #4572
RBLove's Avatar
0 deg
1/2 deg
1 deg
2 deg
Cheers
Tim
I see what you are getting at. There is the option. I am not sure if these are actually in production or are going to be. I will see what I can find out and get back with you.
Old 06-18-2007, 04:50 PM   #4573
rocketron's Avatar
Trader Rating: 16 (100%+)
2 deg
Cheers
Tim
it was a thought at one point but not in any current planning
rocketron is offline   Reply With Quote
Old 06-18-2007, 05:11 PM   #4574
TheCoolCanFanMan's Avatar
Spoony Rules OK
Is he only allowed to marshal your car then Hammy as it seems to me that is always yours that seem to have crashed again again again again again
Malc The im a fan of the Spoony Man
TheCoolCanFanMan is offline   Reply With Quote
Old 06-18-2007, 11:09 PM   #4575
hamster778's Avatar
Thats great cheers
Thats a big shame, as i would think it would make my car alot better in ther turns.
Originally Posted by TheCoolCanFanMan View Post
Spoony Rules OK
Yep, i do keep him busy. Keeps his fitness up too, te he.
Tim
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
