Old 06-14-2007, 10:43 AM   #4516
markf3x's Avatar
OK, thanks...
Here's another stupid rookie question....
When installing a spool pulley (LOSA3329), does it just replace the diff pulley (ie- I still use the diff rings, just not the balls out of diff pulley)?
or do I not use the diff rings and ......?
or do I need to get some rubber pads somewhere and put them where the diff rings are?
I put it together with the pulley between the diff rings, but want to verify that this is correct.
Mark
markf3x is offline   Reply With Quote
Old 06-14-2007, 10:58 AM   #4517
rocketron's Avatar
Trader Rating: 16 (100%+)
Mark
just replace the diff pulley with the spool pulley with the pads. but make sure to clean any silicone or other grease from the diff rings etc.. otherwise you will have slipage
rocketron is offline   Reply With Quote
Old 06-14-2007, 12:14 PM   #4518
rcarmchl's Avatar
Trader Rating: 15 (100%+)
UMMMMM..My spools came with no pads ...is there something I am missing?
rcarmchl is offline   Reply With Quote
Old 06-14-2007, 12:18 PM   #4519
markf3x's Avatar
Mine have no pads either.
Old 06-14-2007, 12:18 PM   #4520
rocketron's Avatar
you have part# LOSA3329 -right? If so the pads are installed in the pulley aready. (notice no holes available for the diff balls)
if not the only way to get pads is in the above part as they are not sold seperately because they would be broken in transit.
edit: there are two spool pulley parts numbers one for a 41T pulley and then LOSA3329 which is a 42T pulley
Old 06-14-2007, 12:31 PM   #4521
markf3x's Avatar
Attached is a rubber tire gearing chart I put together (Final Drive Ratio).
What's unique (I think)... I only include the spur/pinion combinations that will actually fit in the car. I've included the standard Losi Spurs (118,126,128) and the PRS ones I have 104,110, and 112.
ps- to figure out what pinion/spur combos would fit I used math and didn't actually try them, so there might be a margin of error.. I measured min and max distance between center of motor shaft and pulley shaft (1.15" to 1.35"). Using the # of teeth I calculated the radius of all the pinions and spurs and included only the ones that when added together were in the range 1.16 to 1.33".
Yes... I was bored on a flight with my laptop.
Mark
Old 06-14-2007, 12:37 PM   #4522
rcarmchl's Avatar
you are pretty sharp - I didn't think about that. that is how mine showed up and i installed them without question!!!!
Old 06-14-2007, 12:38 PM   #4523
markf3x's Avatar
The 42T spool pulley (LOSA3329) is solid plastic where the diff balls are on the diff pulley. The pulleys I received, there is no additional parts/materials applied to the pulley, nor is there any pieces in the bag besides the pulley.
Is this the way it should be?
Mark
Old 06-14-2007, 01:13 PM   #4524
Yeti35's Avatar
Mark
There is supposed to be black rings where the balls would normally go and they are preinstalled. There is nothing for you to do other then replace the current diff pulley with the spool pulley.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 06-14-2007, 01:21 PM   #4525
markf3x's Avatar
Yeti, Thanks for clearing this up..
Old 06-14-2007, 07:26 PM   #4526
David Galdo's Avatar
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Markf3x:: When I get my Losi, I want your setup for a starting point. Your car actually tracks better than the others I have seen on our track.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 06-14-2007, 08:28 PM   #4527
markf3x's Avatar
Galdo,
Your going to get a Type R?
I thought you were just a closet Losi groupie..
I'd be happy to help you dup my setup as a starting point.
markf3x
Old 06-15-2007, 07:43 AM   #4528
STLNLST's Avatar
Trader Rating: 17 (100%+)
That's what I'm talking about. When are you getting yours? Have you driven one yet?
STLNLST is offline   Reply With Quote
Old 06-15-2007, 08:06 AM   #4529
I will look at getting one in a few weeks. I have watched Dumas and Markf3x wrench on their kits enough to appreciate what value and potential the kit offers.
Markf3x is pretty much new at this and has elevated his game with a simple chassis change. His car transitions through the turns better and he is still figuring out the wheelin' and tuning part. He admits needing more wheel time but lately is running up front. Has me wondering if I sat out of touring too long...
No, I have not wheeled one...
V-Dezign 4.0
Old 06-15-2007, 08:12 AM   #4530
Mr. McGoo's Avatar
i will believe it when i see it Galdo.....all i can say is that my Mi3 is strong....
remember I am the 2007 punt, pass, kick winner!!!!!
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
