Old 06-10-2007, 10:35 PM   #4456
Capelracer's Avatar
Can I use 48p spurs with the PRS adaptor??? (& yes I do want to - was trashing a 64p every 2nd club day when I was using them )
Capelracer is offline   Reply With Quote
Old 06-11-2007, 04:31 AM   #4457
Matt Howard's Avatar
you can use any "standard" spur gear with the PRS adaptor, so you can run whatever you want.
Matt Howard is offline   Reply With Quote
Old 06-11-2007, 04:48 AM   #4458
Mike Haynes's Avatar
Pook, i have been running the squat on my car also, for turn in purpose
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 06-11-2007, 05:11 AM   #4459
schreff's Avatar
Send a message via AIM to schreff
Originally Posted by POOKYT View Post
Jason--Your right!!! I was looking at the set-up and I had the look! LOL
The front looks cool but it looks like you started with the kit rear set-up and then busted your but trying to get it to rotate? Then I'm guessing it was rotating a bit too much off the corner so you added the anti squat to help hook it up?? Am I close? The reason I ask is that for me it was better to just go with the high rear roll center and tune it from there. Thoughts?
Brant
Brant,
I'm not sure if we really did start with the kit setup. Larry and myself actually just threw together a couple setups and went our own ways to start off. If one of us hit something, we could work off of that. Larry was the first to use the heavy rear bar. I was running a convential setup at first, like a .030 rear bar. I tried going to high rear roll center and that didn't help me enough. Believe me, we were all over the place with setup. Yes, we busted our butt to get steering. I was shocked too when I looked at Larry's car the first time. I wouldn't believe it. That is until I tried it and this past weekend was the first time. As far as the Anti-Squat... the track did have a few bumps in it. The Anti-Squat helped settle the car down and it helped turn in too. Can't complain about that. I'm guessing Jackson R/C required some sort of unique style setup. The only thing is, Larry has been running this setup for the past few weeks and it has worked at another track, so who knows - granted Larry's setup is a little different.
And no, the car didn't over rotate at all. It followed through corners just as it should. The only time it was a little hard to drive was when the tires had 3 or more runs on them. New and 2 run tires, it was unreal.
Hope that helps. I'm sure Larry will chime in too.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 06-11-2007, 05:11 AM   #4460
schreff's Avatar
Originally Posted by Yeti35 View Post
Hey Jason, is it safe to assume you were using 0 degree rear hubs since it is not indicated on your sheet? I see you have the stock 4 degree up front and just assume you have the stock 0 degree in the back.
Yes sir, 0 degree rear hubs.
-Jason Schreffler-
Old 06-11-2007, 05:37 AM   #4461
Send a message via MSN to nelarozi
Hello,
i was wondering if the JRX-S ADAPTER would fit on the Type R with 48 Pitch Spur(Pro-Lite Touring, 96 and 90 tooth)?
nelarozi is offline   Reply With Quote
Old 06-11-2007, 05:49 AM   #4462
Yeti35's Avatar
Originally Posted by nelarozi View Post
Hello,
If PRS sells those gears then yes they will fit.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 06-11-2007, 11:50 AM   #4463
Knight Rider's Avatar
Or you could just buy a TC5...... right Yeti!
MHOR R/C Raceway - W.E.D. Paint
RC8Be - Tekin Rx8 - T8 2050kv - Reedy 4s 5500mah
B4.1 - LRP SXX V.2 - X-12 (8.5) - Reedy 2s 5500mah
B44.1 - LRP SXX-TC V.2 - X-12 (7.5) - Reedy 2s 5100mah
Knight Rider is offline   Reply With Quote
Old 06-11-2007, 12:32 PM   #4464
Could someone tell me where I can find some rubber sealed bearings for the Type R?
Myhre is offline   Reply With Quote
Old 06-11-2007, 12:40 PM   #4465
olhipster1's Avatar
Trader Rating: 91 (100%+)
Send a message via Yahoo to olhipster1
Default Avid
try Avid bearings.
do a google search to find their site.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 06-11-2007, 01:01 PM   #4466
Yeti35's Avatar
Hey, don't be startin crap in our thread Rida!! I can find out where you live in Denver and come kick you azz!!
22 2.0
22T 2.0
Old 06-11-2007, 01:02 PM   #4467
Yeti35's Avatar
www.avidrc.com is where I get my bearings from.
22 2.0
22T 2.0
Old 06-11-2007, 01:08 PM   #4468
OK...
Old 06-11-2007, 04:31 PM   #4469
Capelracer's Avatar
$90 airfreight to australia for an adaptor & 2 spurs???? Does anyone else sell the PRS stuff? (It only cost me $38 to get the Type R airfreighted)
Old 06-11-2007, 04:38 PM   #4470
GCracker's Avatar
Default Woohoo finally found sway bars
Well I finally managed to find a hobby shop (stormer) that had sway bars for the type r in stock only took 8 days. Not sure they will stop me overdriving the car though
GCracker is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
