Old 06-04-2007, 10:53 AM   #4336
TheCoolCanFanMan's Avatar
Originally Posted by RBLove View Post
I believe the internal changes to 1.80 or a 1.81. Very minimal.
Think you will find its 1.78 I think
SORRY JUST REALISED THAT RATIO IS WHEN YOU HAVE 41 PULLEY TO THE FRONT AND REAR OF THE CAR, WHICH GAVE A LITTLT MORE EXCELLORATION THAN THE 42 ALL ROUND
TheCoolCanFanMan is offline   Reply With Quote
Old 06-04-2007, 02:56 PM   #4337
JRXS_chris's Avatar
Quite oddly I have found that Low Roll Centre up front works really well on carpet with rubbers! Hmm!
JRXS_chris is offline   Reply With Quote
Old 06-04-2007, 03:04 PM   #4338
i know this is the type R thread but my question involves the shocks which are the same for both type R and the regular jrxs. ok i just purchased a used but in excellent condition Jrxs. when i received it it arrived with the xxxs shocks. i have since then purchased the jrxs shocks and built them. but im running into a problem, i dont know if i doing something wrong. i followed the building of shocks instructions as perfect as possible BUT i getting shocks that leak.. i ran into 1 delemma that were in the instruction... it was he picture of the shock body o ring, not the o ring that gets installed in the spring nut that gives tension to the springs.. the shock body o ring, i dont know if that was to be placed on the shock body itself where the end cap goes or if it supposed to be placed inside the end cap? at first i put it on the shock body but then looking at the pictures i wasnt sure if it was supposed to be placed in the shock end cap.. well i tried to put one in there and it was a reall pain in the butt. so after much sweating i decided to put that shock body o ring on the shock body it self. please help if anyone knows what im doing wrong please tell me. if theres something else to buy or recommend to do, please let me know thanks.
cheech4 is offline   Reply With Quote
Old 06-04-2007, 04:24 PM   #4339
Capelracer's Avatar
Originally Posted by POOKYT View Post
Russ--I was telling Yeti last night that with the '06 Nats set-up my car felt just like my JRXS with the Numan set-up except it was way faster around the corners. ...
Brant
Refresh my memory, which setup was this one?? Cheers...
Capelracer is offline   Reply With Quote
Old 06-04-2007, 05:12 PM   #4340
POOKYT's Avatar
cheech4--
Large white O-ring goes on shock body at base of threads for the cap. Smaller thin white O-ring goes on bottom of shock body where the lower cap threads touch the shock body. One of my guys built his shocks and got confused on the instructions and he ended up putting the shaft O-ring around the little plastic spacer instead of pushing the spacer against the O-ring. Let me know if this helps.
Brant
POOKYT is offline   Reply With Quote
Old 06-04-2007, 05:26 PM   #4341
Kropy's Avatar
Send a message via AIM to Kropy
Pook ~ Check your email
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 06-04-2007, 06:32 PM   #4342
cheech4--
Brant
no thats how i have it, the smaller thin shaft o ring is on the shock shaft at the end of the threads where the end cap fully closes. the small fat one is in the black thingy, the large black o ring in the nut ring. i filled up the oil to about 1/16 inch from the top. moved the shaft and then let the air out, but i noticed though when i did it alittle faster it seems that the air would come from the bottom. then i tightened the top cap alittle pushed the shaft in to let it bleed then tightenend it all the way. but whenever i move it back and forth it still bleeds. maybe its just to much oil in it.. it has some rebound and its fairly easy to push it. i dont know. im going to contact losi 2 moro.
Old 06-04-2007, 06:46 PM   #4343
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
thanks cool can! i know it's a rather significant jump in internal ratio when you change one pulley to 41t. i just cant seem to remember exactly what it will change to from the 1.83 when using 42t front and rear. but i think its close to the 1.78 you are quoting .
if it changes from 1.83 to 1.78 then that would mean a 128/27 spur/pinion combo would change my fdr from 8.68 to 8.44 ... i think thats significant. ... maybe todd could shed some light.
todd: help?
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 06-04-2007, 06:47 PM   #4344
aca
Can anyone tell me where I can find the '06 Nats setup.
Thanks Allen
aca is offline   Reply With Quote
Old 06-04-2007, 08:10 PM   #4345
STARSCREAM's Avatar
Thanks Allen
maybe I shouldnt...EDIT!!!
Sean Maybell
Team Associated/Reedy/LRP
Last edited by STARSCREAM; 06-04-2007 at 08:53 PM. Reason: finally growing up a little
STARSCREAM is offline   Reply With Quote
Old 06-04-2007, 08:18 PM   #4346
POOKYT's Avatar
Capelracer and ACA--Todd emailed me the set-up but when I try to downlaod it in here its too big and I don't know how to make it smaller. If anybody wants the set-up then send me and email at btomlins@suddenlink.net
and I will send it to you. Sorry for the lack of computer skillz guys!
On the set-up I made a few changes to my car. I am running 40 in front and 35 in rear. 12.5's in the rear for springs and still using the Jr. link. Plus I was running all 4 shocks in the outer most holes. Start with the set-up and then make your own changes because the car was pretty darn good with it as a base line.
Brant
Old 06-05-2007, 04:47 AM   #4347
Send a message via MSN to missionhockey33
maybe try 2 white o-rings on the bottom of the shock body.
missionhockey33 is offline   Reply With Quote
Old 06-05-2007, 05:23 AM   #4348
Send a message via MSN to Bigger Brother
todd: help?
Using the 42t pulleys gives an internal ratio of 1.83. Changing to a 41t in the front gives 1.78 at THAT END of the car - average of the two is 1.80 - although I would still use 1.83 as your IR - basically each end of the car will have a different IR so you will have 2 final drives.
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 06-05-2007, 09:25 AM   #4349
Thanks Allen
Josh Hohnstein is offline   Reply With Quote
Old 06-05-2007, 09:31 AM   #4350
riccardo's Avatar
Send a message via MSN to riccardo
where i can find typeR spare parts? at cheap price i mean!!
riccardo is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
