Old 06-01-2007, 12:00 PM   #4276
Send a message via AIM to ERTRACHTER
Default my reedy race setup
allright here it is guys my reedy race setup sorry i dont know how to post the setup sheet but here goes
front suspension
toe straight
ride height 5 mm
kick/antidive 0
caster 4 deg.
droop using losi droop guage 3 to bottom of screw
front pivot 0 deg.
roll center mid .030 shims under all pivot blocks
arm spacing mid
shock position 2
steering rack 2
spindle ackerman 1
camber link standard camber link position 1
camber ball stud short
sway bar .030
front drive spool
grease type losi
front pulley 42 tooth
diff height high
drive axle lcd
hex width .165
oil 40
piston .56
bladder losi black
above bladder tamiya red foam
rear suspension
toe 3 degrees
ride height 5 mm
droop using losi droop guage 5 mm
camber 1 degree all 4 wheels
anti pro squat 0
hub standard
rear pivot 2 deg.
roll center mid .030 shims under pivot blocks
arm spacing arms pushed all the way forward
shock position 1/outside
camber link 5/a
camber link ball stud stock
sway bar .020
diff height low
drive axle rcd
hex width .165
oil 30
piston 56
bladder losi black
above bladder tamiya red foams
gearing 128/41
body protoform mazda 6
checkpoint batteries
transponder was middle of chassis on right side
i had to add 20 grams of weight right next to transponder
tire sauce was buggy grip on new tires old tires i used ragu
hope this helps everybody later jason
ASSOCIATED 12r5.1,REEDY MOTOR AND BATTERY, LRP SPEEDO,KIMBROUGH PRODUCTS,BIG DOG RACING,BELMONT R/C SPEEDSHOP, DENNIS LYMAN RACING, TEAM TOSO, TEAM FACTORY BITTER, SCHUUR SOLUTIONS, SIMMONS RACING, TEAM BOOZCRUZ
ERTRACHTER is offline   Reply With Quote
Old 06-01-2007, 12:28 PM   #4277
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by RussB
gearing is very important. next time at the track, find some people running the same motor as you and ask what they are running. the wrong gearing can make your car either really slow down the straight or run really really hot and have no punch.
thats what i did, but i forgot to see the motor, and that was a fri nite race with fans, im going to see what day time and no fans does and see
srry for the hi jak, im done now
BlackedOutREVO is offline   Reply With Quote
Old 06-01-2007, 12:29 PM   #4278
schreff's Avatar
Send a message via AIM to schreff
Hey J... you forgot one fundamental part of the setup.
What springs were ya running?
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 06-01-2007, 12:39 PM   #4279
my bad schref i was running 15 in front 12.5 in the back
Old 06-01-2007, 12:53 PM   #4280
Yeti35's Avatar
We need to get you more tech savy Jason.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 06-01-2007, 01:22 PM   #4281
Jason, how was your car on old tires compared to new?
DOTMAN is offline   Reply With Quote
Old 06-01-2007, 01:50 PM   #4282
IF I RAN ALL 4 OLD KICKS IT WAS PRETTY GOOD WHEN I TRIED RUNNING NEW REARS AND OLD FRONTS IT PUSHED REAL BAD
Old 06-01-2007, 01:57 PM   #4283
RussB's Avatar
Send a message via MSN to RussB
.030 shims under the pivot blocks in the high or low roll position? like .030 higher than low roll, or .030 higher than high roll?
RussB is offline   Reply With Quote
Old 06-01-2007, 02:05 PM   #4284
His setup said mid roll center so I would assume he added the spacers to the low roll center setting
Old 06-01-2007, 02:06 PM   #4285
YOU ARE CORRECT DOTMAN THANK YOU BUDDY YOU COMING TO BENDING CORNERS TOMORROW
Old 06-01-2007, 03:28 PM   #4286
RussB's Avatar
ahh, i see it now. thanks.
Old 06-01-2007, 03:46 PM   #4287
losi nut's Avatar
Originally Posted by Marcos.J
didnt think about that
Marcos, if you are using the LOSA9739 and not 9739A arms that would explain your problem, the "A" arms have a shock mounting hole that is further out and up a little, that's what I have on mine. Sometimes they are referred to as the "BK" arms. Just something I thought about at work today.
losi nut is offline   Reply With Quote
Old 06-01-2007, 03:49 PM   #4288
POOKYT's Avatar
Losi Parts House items delivered in 3 days..............Very nice!!!
EA Batteries delivered to my door in 3 days............ Dialed!!!!
PookyT gets to race this weekend!................Priceless!!!!!
I'm gonna start with the Nats'06 high roll center set-up and work from there. Will report back Monday night.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 06-01-2007, 09:43 PM   #4289
Super Moderator
Marcos.J's Avatar
Trader Rating: 174 (100%+)
yes you are correct
Old 06-01-2007, 09:55 PM   #4290
J.Filipow's Avatar
Trader Rating: 15 (100%+)
0.030 above low roll center, which is almost mid roll center. I personally prefer to run low front and the low +0.030 in the rear (for rubber on asphalt). This is what I went to (my standard) for the last round of qualifying at the Reedy and it gave me my best run.
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
