Old 05-29-2007, 04:53 PM   #4201
MikeXray's Avatar
Trader Rating: 73 (100%+)
Forum sponsor SpeedtechRC also has them, I believe it's $369 as well.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-29-2007, 06:22 PM   #4202
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Originally Posted by Capelracer
So what's the latest asphalt setup to use???
try this one
Old 05-29-2007, 10:31 PM   #4203
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by RussB
how are you quoting people's posts before they're even posted?
No xntpd on the farm servers? Even a cron'd ntpdate will do.
Or maybe it's just a database replication quirk. Balancing a farm of servers is non-trivial. I wonder if vBulletin will ever be able to work with memcached?
Err, I mean, woo, go Losi!
syndr0me is offline   Reply With Quote
Old 05-29-2007, 10:36 PM   #4204
syndr0me's Avatar
Anyway, I tried running Pro 53 magentas on all four corners tonight, with Larry's setup suggestions. And holy Jesus did the car turn. I mean, I went to take a sharp turn, overdid it, and turned completely around going the opposite direction. And it wasn't loose, it just turned in a way I didn't even think was possible. It wasn't totally impossible to drive, but I guess I'm not there yet, I couldn't be graceful with it, and made too many mistakes to be fast.
BUT... it gave me a great opportunity to test out the new arms. And they're just fine, which is a very welcome change. I hit more crap tonight than in the last 3 months combined, and didn't break a thing. I wimped out and went back to my old tire combo for the last two races, though. It's going to be a while before I can drive something that unruly. I have a renewed respect for what you guys do. :-)
Okay, so, the shocks. If you build the shocks, and they rebound a little bit when pushed in, and suck in a little be when pulled all the way out, does that mean I need to bleed them a bit? Do you guys run them totally dead, or with rebound? The deal with them sucking back in is weird, I've not seen that on other shocks.
Old 05-29-2007, 10:46 PM   #4205
syndr0me's Avatar
Also, when the traction comes up, if the car starts to want to tip/lift when cornering hard, what's the first thing you usually change? I guess we're spraying the track with Paragon now to better simulate a large race, and the car generally works better, but it really wants to lift if I dig in too hard. Should I look at gluing side walls?
Old 05-29-2007, 11:30 PM   #4206
RBLove's Avatar
Trader Rating: 72 (100%+)
Check your PM. I sent you a set up.
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Old 05-30-2007, 01:39 AM   #4207
Mike Haynes's Avatar
I usually have my front shocks rebound 100% and my backs about 50%.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-30-2007, 02:59 AM   #4208
Send a message via MSN to nelarozi
If i fill the shocks as the manual says, they dont rebound very much in most cases they stay in .
How do you guys fill your shocks? Please help!!
nelarozi is offline   Reply With Quote
Old 05-30-2007, 03:26 AM   #4209
over gear's Avatar
Trader Rating: 15 (100%+)
did you put a couple drops of shock oil on the o-rings before you assemble the shocks?
over gear is offline   Reply With Quote
Old 05-30-2007, 03:27 AM   #4210
yes i did. i am running double o-rings.
Old 05-30-2007, 04:16 AM   #4211
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Swaybars
Dasupacat1 is offline   Reply With Quote
Old 05-30-2007, 06:10 AM   #4212
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
You know whats funny syndrome, I still dont have as much steering as I would like.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 05-30-2007, 08:27 AM   #4213
syndr0me's Avatar
That's pretty amazing. I've gotta think something else about the setup was making the car turn too hard, I can't imagine trying to drive something like that consistently. I'm running the kit setup with 6 degree hubs, and 25lb springs in the rear.
Old 05-30-2007, 08:31 AM   #4214
chicky03's Avatar
Send a message via AIM to chicky03
25 lb rear springs are really stiff. I would not go any heavier than 20lb rears and with magentas on the front I usually went 12.5-17.5.
20lbs were usually with cyan fronts.
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 05-30-2007, 08:42 AM   #4215
syndr0me's Avatar
Paul
Ah, I just checked the notes I had, and it did say 20 in the rear. Damn. I'll experiment with it more in the coming weeks, and try going softer in the rear. I'm going to give Rob's setup a try, too.
I see a lot of guys using sway bars on this car for their carpet setups. Is this the only car where that happens regularly? I was under the impression that sway bars were almost never used on carpet with foams.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
