Old 05-24-2007, 05:43 AM   #4066
TheCoolCanFanMan's Avatar
Anyone
How do I switch on my HTML and my (IMG) in my sig please, as I cant seem to fathom out how to do
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 05-24-2007, 05:44 AM   #4067
Originally Posted by Marcos.J
i build it like i build every diff using AdrianM method,
Which is please I personally dont have a prob with my diffs but would like to know how others do there's
Malc
Old 05-24-2007, 05:50 AM   #4068
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Originally Posted by TheCoolCanFanMan
Anyone
Cheers Malc
You can'tit isn't allowed in these forums...
For sig files:
vB code is On
[IMG] code is Off
You can build links, though, by using the [url] tag around whatever link you want to be active.
HTH
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 05-24-2007, 06:02 AM   #4069
Super Moderator
Marcos.J's Avatar
Trader Rating: 174 (100%+)
Malc
here it is
Originally Posted by AdrianM
One of the most important factors in building a good diff is keeping everything clean. Before you start wash you hands to reduce the natural oils on your fingers.
Carefully place the diff balls on a paper towel and spray some more spray onto them. Take it easy unless you want to launch the balls all over you shop.
Get some 600 grit wet/dry sand paper and spray some motor spray onto it. place a diff ring on the wet area and with a curcular motion sand the ring. If the motor spray dries out spray some more on to the ring and paper. The motor spray will clear away the steel removed by the sand paper. You want to have a consistant pattern of scoring across the full face of the diff ring. if you see any high or low spots in the area where the diff will run keep sanding. Sand both sides of both rings.
Clean the rings with motor spray to remove any residue and set them aside.
Clean the diff pulley with motor spray.
The main thing to remember is you want all the diff balls, rings and pulley to be clean and oil free.
Every racer has their own ideas about how much silicone diff grease is the correct amount to apply to the diffs. Before I say what I like to do lets cover what the diff grease does in the diff.
The diff grease is a damping fluid and lubricates the balls as they run in the diff pulley. The diff grease contributes to the limited slipped effect on a ball diff by damping (slowing down) the movements of all the components in the diff. The caused torque to contiute to be sen to a loaded wheels even if the wheel on the opposite side lifts off the ground or otherwise looses traction.
The diff grease also lubricates the ball and diff rings in order to keep them running cool and reducing wear. This is really important and is one of the reason why we use special silicone based greases on our diffs.
Silicone diff grease has a special property. It will lubricate between the ball and the pulley but offers near zero lubication between the rings and the balls. This is critical to the operation of the diff. This allows us to set the diff loose with zero slip between the rings and balls.
Over the years we have tried all kinds of diff lubes and I can say with all honesty nothing works as good as Schumacher diff grease. AE Stealth lube gets too thin and gets slung away to easily. Joel Johnson Lube is too thick when its cool but thins dramatically when it is worked hard. Schumancer Diff grease stays put and is consistant.
Old 05-24-2007, 06:38 AM   #4070
For sig files:
vB code is On
[IMG] code is Off
HTH
Cheers Dude, wondered why it was that I couldn't get the stuff in my sig to HTML Still not to sure how to do the build link thing though can you give me a sample, soory for being stupid DOH!
Malc
Old 05-24-2007, 07:46 AM   #4071
Trader Rating: 8 (90%+)
Malc
[u r l]link[/ u r l]
take out the spaces in the url
Johnny Carey is offline   Reply With Quote
Old 05-24-2007, 08:06 AM   #4072
Yeti35's Avatar
Yeah Malc, if you notice my sig my links are URL's so it can be done.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 05-24-2007, 12:23 PM   #4073
I had to rebuild my diff half way through a wet meeting.
Track wet and gritty and diff started to lock up during race,
bad under steer, could hardly turn diff over.
Grit had got between diff tube and plastic output, found three
thrust race balls loose.
Cleaned and re-greased diff, have had no problem since.
Chris
Livingston is offline   Reply With Quote
Old 05-24-2007, 12:38 PM   #4074
Trader Rating: 24 (96%+)
Anyone know anywhere online that has lower front arms back in stock yet?
nemix is offline   Reply With Quote
Old 05-24-2007, 01:30 PM   #4075
Andrew Gray's Avatar
I just checked on Horizon Fastserve, they have front arms in stock in CA.
Retired & Washed Up. TLR Supporter For Life
Andrew Gray is online now   Reply With Quote
Old 05-24-2007, 05:00 PM   #4076
POOKYT's Avatar
Drew---Are you not at the RROC?
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 05-24-2007, 05:01 PM   #4077
POOKYT's Avatar
Clint!!!!!!!!!
I know its the first day of practice but where are you guys on set-up at this point? High roll centers??? Low roll centers???
Brant
Old 05-24-2007, 05:03 PM   #4078
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Are these the revised arms or the kit? Can any team guy give us any details as to when they revised will be avail?
Dasupacat1 is offline   Reply With Quote
Old 05-24-2007, 08:08 PM   #4079
ctn226's Avatar
Are you using the thrust race that comes with the 'R' kit, if so you may find that the balls in that particular thrust race some times come dislodged and lock up the diff spiradically, there are other thrust races avaliable which the balls sit in a solid washes and not a hollow one, these work far better.
Cheers Malc THE CAN MAN
Thanks for your info n help, I'll find one to replace my thrust bearing.
ctn226 is offline   Reply With Quote
Old 05-24-2007, 09:16 PM   #4080
Yeti35's Avatar
If they are back in stock it is a good chance they will be the revised ones. Local Losi racer here has been keepin me up to date on this even though he is mainly a dirt racer. I hope that helps a little.
22 2.0
22T 2.0
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
