Old 05-23-2007, 05:03 AM   #4051
Trader Rating: 35 (100%+)
Send a message via AIM to Sean R
Originally Posted by ctn226
anyone can help me? I have a diff problem with this type R. all of the pulley which is have a ball bearing are melted, although I have tighten the front diff and a bit loose at the back. I am using GTB with 4.5R with 9.56 final ratio. I build the diff as per manual, is there anything wrong with my setup or something wrong with the diff?
It sounds like it wasn't tight enough and was slipping, causing incredible friction and heat, melting the pulley.
Sean R is offline   Reply With Quote
Old 05-23-2007, 06:36 AM   #4052
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
yeah you missed a step or spmething to have that happen to your diff , i run a 3.5 brushless with no problems at all,just pay close attention when building your diff
Old 05-23-2007, 07:06 AM   #4053
JRXS_chris's Avatar
Originally Posted by Ali Graham
And whose track record is that Good to hear it's going well Christoff That truly used and abused JRXS of yours can be retired!
Sorry to dissapoint you Ali but its Chris Clarke's, he beat yours not so long ago!
JRXS_chris is offline   Reply With Quote
Old 05-23-2007, 02:34 PM   #4054
Super Moderator
Marcos.J's Avatar
i did some minor changes to a set up that i posted a few pages ago, i changed the front long arms to the short arms and raised the roll center front and rear, and wow what a difference , i ran it earlier today at my local track (with a un-prepped track) and was really good!! cant wait to try it again this weekend on a prepped track.
Old 05-23-2007, 07:12 PM   #4055
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
marcos: what did raising the roll centers do in terms of handling?
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 05-23-2007, 07:51 PM   #4056
Adding more traction by making the car roll more.
oops - I was thinking of the the upper arm, my bad.
Old 05-23-2007, 07:55 PM   #4057
RBLove's Avatar
Trader Rating: 72 (100%+)
High roll center = car will lean less, react faster, and provide more over all traction.
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Old 05-23-2007, 08:02 PM   #4058
ROBORAT's Avatar
Blue/RBLove: I know thats what it will "technically" do. I just wanted to confirm if thats what Marcos also observed when he did the change. But thanks, I appreciate all the help everyone provides in these threads.
Old 05-23-2007, 08:44 PM   #4059
RBLove's Avatar
Got ya. Sorry about that. I am anxious to hear his thoughts as well..
Old 05-23-2007, 09:38 PM   #4060
Super Moderator
Marcos.J's Avatar
Exclamation
ditto
Old 05-23-2007, 09:39 PM   #4061
Super Moderator
Marcos.J's Avatar
also with the short front arms you are not able to use the lower shock mounting hole on the front shock tower the left shock's collar will rub against the front diff pulley
Old 05-24-2007, 12:18 AM   #4062
ctn226's Avatar
Thanks Bluebird-sr and Marcos.J for your help, for your info, I already tightened them quite tight and just a bit loose at the back, after the race I disassembled the diff and I found that the thrust bearing ( F/R ) were broken too. Marcos may I know how tight is the diff to use a brushless motor? thanks
ctn226 is offline   Reply With Quote
Old 05-24-2007, 12:49 AM   #4063
ROBORAT's Avatar
RBLove: as mentioned i appreciate all the inputs .... so its all good!
Marcos: good to hear! im actually planning to run the high roll set up this weekend as well.
Old 05-24-2007, 04:48 AM   #4064
Super Moderator
Marcos.J's Avatar
i build it like i build every diff using AdrianM method,
Old 05-24-2007, 05:32 AM   #4065
TheCoolCanFanMan's Avatar
Are you using the thrust race that comes with the 'R' kit, if so you may find that the balls in that particular thrust race some times come dislodged and lock up the diff spiradically, there are other thrust races avaliable which the balls sit in a solid washes and not a hollow one, these work far better.
Cheers Malc THE CAN MAN
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
