Old 05-12-2007, 07:44 AM   #3781
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Well, I guess if we never wreck, then no one would ever need bumpers, would we?
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 05-12-2007, 09:17 AM   #3782
Super Moderator
Marcos.J's Avatar
Trader Rating: 151 (100%+)
just keeping the front arms safe dont need them with the new arms the extra bumpers are already out of the cars
Old 05-12-2007, 10:16 AM   #3783
EricF's Avatar
having cf that goes around the esc is not providing the the protection that you think. when another car hits you, it will be hitting you with their bumper which is higher that the 2mm thick peice of cf that you mounted you esc to.
Hmmm.... something to think about!
E
EricF is offline   Reply With Quote
Old 05-12-2007, 12:01 PM   #3784
losi nut's Avatar
Jeez,, all I do is post a simple way to mount an esc and nod now I've become a non-engineering, unsafe, crasher. thanks alot
losi nut is offline   Reply With Quote
Old 05-12-2007, 12:09 PM   #3785
squarehead's Avatar
Anything is better than nothing, IMO.
Corally and Xray both developed "nerf" wings to go around the motor area to protect the motors in their cars. A motor is far cheaper than a speedo, too.
Something to think about.
Everything depends.
Nothing is always.
Old 05-12-2007, 12:10 PM   #3786
squarehead's Avatar
Just remember that high post counts here don't necessarily mean you know what you're talking about.
Everything depends.
Nothing is always.
Old 05-12-2007, 12:23 PM   #3787
Super Moderator
Marcos.J's Avatar
neither people who are sponsored
Old 05-12-2007, 02:01 PM   #3788
Super Moderator
Marcos.J's Avatar
Originally Posted by chumanji
I want to convert my 64pitch to 48pitch spur. How many teeth should the 48pitch spur be???? Is it 96t?
yes 128 64 pitch = 96 48pitch
Old 05-12-2007, 04:17 PM   #3789
hamster778's Avatar
Send a message via MSN to hamster778
I think its a good idea too
I looked at the xray motor guard to see if it would fit, but alas it didn't.
It is much better to protect these new expensive items as much as we can, I would rather get a new nerf wing at 10 than to get a new esc at 175.
Tim
hamster778 is offline   Reply With Quote
Old 05-12-2007, 06:05 PM   #3790
RussB's Avatar
Send a message via MSN to RussB
FYI - if you feel like running cvd's, there's a hybrid combination that is the perfect length and fits the outdrives just like the stock drive shafts... cyclone cvd bone with the stub axle from a jrx-s or xxx-s.
RussB is offline   Reply With Quote
Old 05-12-2007, 06:37 PM   #3791
MikeXray's Avatar
Trader Rating: 72 (100%+)
I got to run my type-r today, I got to run one pack before I broke it, surprising not an arm, just a turnbuckle. I ran the stock carpet setup with 6 dg caster blocks, coming from someone who is a mediocre driver this car can carry a LOT of cornerspeed, the whole car felt more free and easier to drive. It was a little sluggish on initial turn in, but I didn't get to try any setup changes.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-12-2007, 08:04 PM   #3792
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Hey Type R drivers, just wanted to share some set up stuff that I have learned from asphalt testing the past two weekends....I am fairly certain that this car benefits from sway bars on the front and rear of the car when running on smooth medium-high bite asphalt. I say that b/c my lap times with the sway bars were not only a tad faster but, more importantly, more consistent. Any of you that may be running asphalt right now might benefit from trying this....(start with 0.030 in the rear and 0.040 in the front).
Good luck.
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
Reedy / RC America/XRayUSA / Hudy / Avid / JConcepts / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 05-12-2007, 08:41 PM   #3793
Trader Rating: 71 (100%+)
Originally Posted by CRASH
Will be anxiuos to here your results. I have been running the setup you gave me for the past couple weeks. As a matter of fact I logged a couple hundred laps tonight, practice night.
Later,
Larry/Crash,
I started off running the front roll center in the high position and the car was a "pig". Very lazy and unresponsive. I tried different spring combos, droop, and camber and it never came around. I put it back to the low position and went to the rear. I raised the rear roll center .030 (shims) and the car was "money". I noticed, before the change, the rear of my car would lean quite a bit in hard cornering. With this change it kept the rear end more level/flat. Seemed to transition faster and flatter.
I never made it to high roll center front and rear or the mid .030 front and rear.
Crash,
Move the rear arms all of the way back and raise that rear roll center .030 and let me know what you think. If you need more steering disconnect front sway bar. I ended up with a 25lb spring and no front bar.
BTW: double pink front and rear is what I ran today. Bite was on the lower/inconsistent side.
Give it a whirl. Take it for what it's worth. I recommend trying it.
RCAmerica - Xray - Hudy - ProLevelRC - R1Wurks - BSR Racing Tires
RBLove is offline   Reply With Quote
Old 05-12-2007, 10:53 PM   #3794
syndr0me's Avatar
Trader Rating: 32 (100%+)
I tried running the front diff low (foam/carpet) and lost a few tenths. I couldn't feel it, per se, but the difference in lap times was very clear.
I skipped a week of racing to drink my weight in vodka in Vegas, and now I feel like I haven't raced in a year. Arg, c'mon Tuesday! And I crashed and utterly destroyed my poor CX2 today, too. Lame.
syndr0me is offline   Reply With Quote
Old 05-13-2007, 05:17 AM   #3795
Super Moderator
Marcos.J's Avatar
Good luck.
isnt that the base set-up in the manual
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
