Old 05-11-2007, 02:02 PM   #3766
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Originally Posted by RBLove
Going carpet testing tomorrow. Planning to mess with roll centers. Will report back my findings..... Good luck to everyone racing this weekend.
where you running carpet this weekend?
ps - don't forget to shim your camber links with your r/c, or you're effectively adjusting camber gain as well, which is a pretty big thing on foams. bump steer washers too if you're working on the front end.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 05-11-2007, 02:04 PM   #3767
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Rob I was thinking about trying high roll centers next time I run on carpet too, Im sure it will take a little bit of changing the front end but it might be better. Definatley report back on your findings.
I'm not running the same setup as anyone on carpet or on asphalt so I figured it might work for me.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 05-11-2007, 02:23 PM   #3768
The Tank's Avatar
Originally Posted by Marcos.J
if you noticed with 128 spur and the 20 tooth pinion the belt pulley will rub on the can you can fit a 130 spur with no problem but if you mill down under the spur you can fit a 134 with no problems
awesome but I have 1 question... 130,134 tooth spur gears??
--Xray--LRP--Futaba--JR--Team Orion--ReVtech--PRS--MIP--Protoform--
The Tank is offline   Reply With Quote
Old 05-11-2007, 02:45 PM   #3769
RBLove's Avatar
Trader Rating: 71 (100%+)
Thanks Chris.. Very good points and I probably would have not done this. YOU THE MAN!
I am going to Cincy tomorrow. They're not racing, but Junior, Favian, and I are going to run.
Larry,
I will definitely let you know how it works out and what I can come up with.
RBLove is offline   Reply With Quote
Old 05-11-2007, 06:10 PM   #3770
POOKYT's Avatar
PRS makes those gears.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 05-11-2007, 06:18 PM   #3771
losi nut's Avatar
For those still contemplating or still looking for a esc mounting solution, I came up with one for my "R". I took the side plate off of my Pro3, drillied one hole, and used 2 of the forward holes on the left side. I had the hpi cf chassis set on the pro3, I don't think it is available separately, check Tower, Penquin rc has side plates in g 10 fiberglass $7.99 or cf for $14.99. Just a thought.
Bob
losi nut is offline   Reply With Quote
Old 05-11-2007, 06:26 PM   #3772
Bob
How about a photo of your solution when you get a chance.
Much thanks.
Babalu is offline   Reply With Quote
Old 05-11-2007, 06:59 PM   #3773
losi nut's Avatar
Here it is on the car. sorry it's not clearer
Team Losi JRXS Type-R-im001399.jpg   Team Losi JRXS Type-R-im001402.jpg   Team Losi JRXS Type-R-im001401.jpg
Old 05-11-2007, 09:49 PM   #3774
CRASH's Avatar
Trader Rating: 26 (100%+)
Larry,
Will be anxiuos to here your results. I have been running the setup you gave me for the past couple weeks. As a matter of fact I logged a couple hundred laps tonight, practice night.
Later,
CRASH is offline   Reply With Quote
Old 05-11-2007, 11:27 PM   #3775
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
you dont need that at all
check out both of my type r's
Old 05-12-2007, 02:06 AM   #3776
I want to convert my 64pitch to 48pitch spur. How many teeth should the 48pitch spur be???? Is it 96t?
chumanji is offline   Reply With Quote
Old 05-12-2007, 04:24 AM   #3777
losi nut's Avatar
[QUOTE=Marcos.J]you dont need that at all
Why not? The esc was already mounted to it, I used existing holes in the chassis, I drilled 1 hole in the plate to line up with the chassis, and the esc has cf extending all the way around it. It's not just hanging off the edge of the chassis.
Old 05-12-2007, 04:37 AM   #3778
squarehead's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Thumbs up
I think a lot of people are really worried about side impacts with this type of mounting style. I know I am. It's a shame that cars like this are getting more and more designed around the 1% of drivers in the world who never crash or don't have to pay for replacement parts and electronics.
A GTB is half the price of the car. I can't afford to take something so fragile and hang it out there in the open like that. Personally, I really like the added side plate. Very creative!
Maybe Bud Bartos or some other innovative company will come out with something out of Kydex that will help protect the expensive electronics a bit...
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 05-12-2007, 05:32 AM   #3779
squarehead's Avatar
Thumbs up
BTW, I have found baseline rubber tire setups for asphalt, and foam tire setups for carpet, but does anyone have a suggestion for a foam tire asphalt starting point?
Everything depends.
Nothing is always.
Old 05-12-2007, 06:23 AM   #3780
Super Moderator
Marcos.J's Avatar
well they are not hanging out that much ,im just saying that you dont need to add any graphite or plates to mount your esc, but i guess if you wreck alot you will need the added support
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
