Old 05-01-2007, 07:41 PM   #3601
schreff's Avatar
Send a message via AIM to schreff
Originally Posted by Brian L
I started with what Schreff has been running and then started trying things thanks to Gray's and Hayne's suggestions. Car was awesome and will try and get something posted. Anyone come up with a editable set-up sheet yet?
Brian,
How did that setup work? I'm guessing it pushed a little.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 05-01-2007, 08:00 PM   #3602
Regional Moderator
Send a message via ICQ to fAfA Send a message via Yahoo to fAfA
hi all! sorry, this might be a stupid question or may have been answered previously but i'll ask anyway and hope you guys can help me out:
when using the spool pads, is the rough/abrasive side of the pad supposed to face the diff pulleys or the diff rings? i dont have an instruction guide on how to use the spool pads since i just got extras from a friend's old stuff. i currently have the abrasive side facing the pulleys and i noticed they slip too much and when i opened up the assembly, the pads basically smoothened out the pulley surface ... much like they were sanded (since the pads i believe are basically sandpaper).
was thinking of doing a few things:
1) flipping the pads so the abrasive side faces the diff rings (although not sure if that will work, hence the question above.)
2) keep them in their current config and maybe put a very small drop of CA so the pads adhere to the pulleys and wont slip and sand the plastic material down.
3) replace the diff pulleys with header board with similar thikiness. am thinking the header board would slip less than the smoot/polished diff rings.
what do you guys think? would appreciate any pointers.
Thanks in advance!
fAfA is offline   Reply With Quote
Old 05-01-2007, 08:18 PM   #3603
Trader Rating: 21 (100%+)
Originally Posted by schreff
Brian,
It was pretty decent. I probably could of stayed with it, but I tried different things and like what I ended up with. This car impresses me more and more everytime I drive it. Thanks to everyone on the team for all the help and support.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 05-01-2007, 08:32 PM   #3604
Mike Haynes's Avatar
I ended up with a much different then usual setup on my car..it was very easy to drive, however lacked slightly in cornerspeed compared to Andrew's car.
I think it may need a little more tweaking, but is somehting different to try.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-01-2007, 08:33 PM   #3605
fafa- i used the smooth side agains the gear when i used those pads last year...if u get too much slip you could put a tiny bit of ca glue to hold them onto the gear.
Old 05-01-2007, 08:42 PM   #3606
Here is what was different on my car from Mike's.
Front: .195 hex, 2 camber, 60 wt, 56 piston, 25 spring, no o-ring above bladder, and droop 1mm over ride.
Rear: 50 wt, 17.5 spring, shock mount #3 on tower,1.5mm droop over ride, no washers under ballstud on hub
Misc: only compound 1/2 front tire
Thanks to pops
Old 05-01-2007, 09:10 PM   #3607
Regional Moderator
rcracingkid: thanks! was already planning to do that next but just wanted to get affirmation from you guys here ... its seems to be the logical think to do when i think about it. will try it and let you know how it turns out.
Old 05-01-2007, 09:55 PM   #3608
CRASH's Avatar
Trader Rating: 26 (100%+)
Default Editable Setup Sheet
Anyone needing an editable setup sheet PM me your e-mail and I will send you a copy.
It is to big to post.
Later,
CRASH is offline   Reply With Quote
Old 05-01-2007, 10:32 PM   #3609
Trader Rating: 71 (100%+)
What's up with running the rear arms back? What does that do over the standard middle set up? I have been wanting to try everything forward like we used to do on the XXX-S.
RBLove is offline   Reply With Quote
Old 05-01-2007, 10:56 PM   #3610
TLRacing
Todd Hodge's Avatar
I feel running the arms back frees the car up in the center of the turn. With the motor in the back of the car, this car does have a lot of traction.
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 05-01-2007, 11:10 PM   #3611
Thanks Todd. I will give it a shot next time out. So far so good, but every tenth counts.
Old 05-01-2007, 11:16 PM   #3612
rocketron's Avatar
Trader Rating: 16 (100%+)
What you have described are the OLD sandpaper disks that were used on the xxx-s. The PADs for the JRXS and Type-R are made of something like plastic and snap into the pulley one on each side. Not sure if the sandpaper will work well but before you CA everything try to get some of the new PADs
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 05-02-2007, 12:10 AM   #3613
Super Moderator
Marcos.J's Avatar
Trader Rating: 141 (100%+)
im not sure if anybody has done this , im too lazy to go back on pages to look, but this may help keep the front arms from breaking
Old 05-02-2007, 12:50 AM   #3614
syndr0me's Avatar
Trader Rating: 32 (100%+)
I got a bit of a tweak in the car tonight. It normally runs VERY even from side to side, but I struggled with it this evening. Aside from the normal stuff (rebuild shocks, make sure chassis is flat, re-seat topdeck) is there anything else I should check, or any particular trick to straightening the car out? It seems like every car has an order in which to do things, or tweak tricks that aren't always apparent.
It was mentioned to me that making the shocks a little longer overall will allow for more suspension travel, and should let me run my foams down to the rim once again. I'll look into that when rebuilding the shocks in hopes of getting the tweak out. I was having trouble getting enough uptravel once the tires got around 54mm.
Also, for the second time, I had a front shock retainer pop off during a minor impact. I still can't figure out what's causing them to launch like that, but I've heard at least one other person mention the same thing. They seem to be snug on the shocks, so maybe there's something else I should be looking for.
syndr0me is offline   Reply With Quote
Old 05-02-2007, 12:59 AM   #3615
TheCoolCanFanMan's Avatar
What ive done on all 4 shocks is to put a 3mm screw and a washer in the end of the shock retainer to stop the shock a shock from poping off in an accident, not that one has of yet, but just in case
Malc TCCFM
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
