Old 04-24-2007, 08:22 PM   #3466
Trader Rating: 194 (99%+)
Arm breakage is Losi's history. They can not design arms for nothing. The Streetweapon, XX4, XXX4, XXX,JRX. All have had arm problems. Some were redesigned with less breakage.
Hopefully they will have arm fixes when the carpet season starts back up.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 04-24-2007, 08:36 PM   #3467
RussB's Avatar
Send a message via MSN to RussB
the only that i've had that broke arms easily was the xxx4 before they fixed them. even the jrxs wasn't soo bad.
RussB is offline   Reply With Quote
Old 04-24-2007, 10:05 PM   #3468
Trader Rating: 15 (100%+)
Just dont hit anything.
AARON YOUNG is offline   Reply With Quote
Old 04-24-2007, 10:12 PM   #3469
RussB's Avatar
and run a parma bumper.
Old 04-24-2007, 10:18 PM   #3470
syndr0me's Avatar
Trader Rating: 32 (100%+)
I finally had my first bad luck with arms breaking, and lost a front and rear. I can't say either hit was particularly spectacular, but both were decent (one brushing a board kinda hard at decent speed, one from getting hit from behind after missing an apex.) Both were incidents that could have been avoided, but I see other cars regularly survive far more punishment without broken parts, so I'm a little disheartened by it. I guess add me to the list of people that hopes something positive happens with the arms, but it's something I can live with in the meantime.
I noticed tonight that you can't run foam tires much lower than about 54.5mm and still make 2mm of uptravel, at least in the rear. The arms will sit on the chassis, which prevents any further upward movement. Maybe that's too small to be running tires anyway, but I'm used to basically taking them down to the rim during club races. Is there something I'm missing, or is that just the way it goes with this car's design?
This car continues to drive like a dream, and go exactly where I want it to, faster than any before it. I hope our guy comes through with a weighted LiPo tray soon, I want to get that weight back down low. A tray weighing around 6oz would be perfect. Losi? :-)
syndr0me is offline   Reply With Quote
Old 04-24-2007, 10:44 PM   #3471
adamge's Avatar
This is great news for me, as it means there will be many more used foam tire lots. Don't throw them away, save them up and sell on rctech!
adamge is offline   Reply With Quote
Old 04-25-2007, 05:41 AM   #3472
highwayman's Avatar
T. HODGE :
got the parts that you sent over thru trackside (scotty), THANKS A LOT!!!
this car is pretty sweet...
- jason
highwayman is offline   Reply With Quote
Old 04-25-2007, 05:45 AM   #3473
Kwikvdub's Avatar
Trader Rating: 90 (100%+)
Send a message via AIM to Kwikvdub
Can anybody out there point me in the right direction to a outdoor set-up, asphalt, rubber tire, med. grip, long straight, flowy layout.
Any input would be greatly appreciated!!............... or just follow the set-up that comes w/ the car??
Thanks Guys!
Alex Valdes
TQRacing / 360 v2 RC Raceway
Kwikvdub is offline   Reply With Quote
Old 04-25-2007, 06:10 AM   #3474
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Yo Alex, we can give you a hand on sunday if you need it.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 04-25-2007, 06:17 AM   #3475
Kwikvdub's Avatar
Thanks Bro!!
Alex Valdes
Old 04-25-2007, 06:20 AM   #3476
STLNLST's Avatar
Trader Rating: 19 (100%+)
Thanks Guys!
Todd's nationals set up is killer and my boy Dominic has a good one too. I'll try to get them both posted before the end of the day.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-25-2007, 03:19 PM   #3477
jland's Avatar
Trader Rating: 74 (100%+)
Default Carpet rubber set-up
Looking for a good starting place for CS-27's on ozite. I was thinking about just putting the kit rubber set-up on it to start out with the spool but was wondering if anyone else has tried it. Also the track only allows paragon, does that work ok on rubber.
Thanks,
Justin
jland is offline   Reply With Quote
Old 04-25-2007, 04:02 PM   #3478
Juan Valdez's Avatar
Thanks,
Justin
Paragon works awesome on rubber tires/carpet. I hope to try my car out on carpet with rubber tires this weekend, and I am going to start out with the kit rubber tire set up, but with 17.5 lb front springs and a front diff (instead of the spool). For reference though, here is something Keven Hebert from Losi posted earlier about the set up the team ran at the Vegas race:
Rubber Tire Carpet Setup from Vegas (from Keven Hebert)
here is what we ran ( the only thing I can't remember and I can't look on the car is where the ball stud
was on the rear hub )
front :
20 spring 40 oil, 56 piston,
4 degree caster
middle hole on tower
camber link :jr front link , in and up on tower
high roll center
0 degree pivot
one way set to High position
arm spacing middle
Rear :
12.5 spring, 30 oil, 56 piston,
middle hole on tower,
camber link : middle in on tower, I think outside on hub + short ball stud
High roll center
Low rear diff
2 degree pivot
long arm
1/2 rear std hub
arm spacing middle
Dumas ran a type m body while we ran a mazda.
Hope this helps. Good luck!
TLR 22 3.0 | TLR 22-4 | TLR 8ight-E 3.0 | Tamiya TA07 | Tamiya TA05
Juan Valdez is offline   Reply With Quote
Old 04-25-2007, 06:13 PM   #3479
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
syndr0me: I learned this past weekend, from another guy that runs this car, that if you cut the excess off the axle that you thread the nuts on to hold the tires, that this will decrease the chance of the arms breaking. Because the axle sticks out further than the rim, which can get caught on a pipe, which leads to the arm being ripped off or broken. Just a little tip. I havent tried it, cause I havent broken an arm yet. hehe
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 04-25-2007, 06:18 PM   #3480
jland's Avatar
Thanks Juan, I will give that s shot. Here is a pic of my brushless layout and my DNA1.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
