Team Losi JRXS Type-R
#3346
Originally Posted by Capelracer
Any thoughts on using aluminium screws to hold the battery tray in?? Not worried about the weight, only the strength. I just want to use different coloured screws - if I'm in a hurry on raceday I'll occasionally undo the wrong ones trying to change the battery
#3347
UK drivers, spares are now in the shops.
Got some front wishbones from DMS.
Chris
Chris
#3348
Originally Posted by schreff
I've been using aluminum screws to hold the battery in on my car. Most all the screws on my car are black aluminum so you really can't tell. Aluminum works fine for the most part. You just have to make sure you put them in tight cuz they can work their way loose. You also have to be a little gentle when tightening otherwise you will strip them. The last thing you wanna do is bust out the dremel to get a screw out.
Somebody say Dremel????
Brant
#3349
Tried the link and it did not let me even when I registered.
Originally Posted by TryHard
Hi All,
Just found this setup on another forum, Thanks to Mr Hodge for writing it up, and Mr Spashett for posting it there
Outdoor asphalt.
T.Hodge - Rippon Raceway - Region 12 Champs
Intriguing to see use of the red foam in the shocks too
Cheers
Ed
Outdoor asphalt.
Cheers
Ed
#3350
Originally Posted by POOKYT
WHAT??
Brant
Brant
Lucky for me, I have been Dremel free with the Type R. I had a couple people approach me asking if my car came with a dremel. The funniest thing was me finishing my car and then watching the other person build theirs (different brand car mind you) with dremel in hand! Ya, they ate their words.
And can't wait for this weekend. First weekend for me with the car on asphalt.
#3352
I didn't need a Dremel, but I did have to file the chassis a bit in the front for belt clearance (if you decided to run the front diff low) and the top deck just a tiny bit to make the connectors on the LiPo a little easier to get to.
I'm having really good luck with the kit setup plus a few changes. 6 degree hubs, 20lb. springs in the rear, and normal camber links up front. It rotates so fast I've had to adjust my reaction time to get on the throttle faster. I'm used to cars taking a little longer to square up and waiting, which I haven't had to do with the R. It's sitting there ready to launch, like it's saying "WTF, lets go already!" Fun stuff, this car has truly made racing more enjoyable.
#3353
#3354
Anyone know how the "arm" thing is coming along?? I picked up a new kit yesterday still in the box and I heard a front arm break
E
E
#3355
E
E
#3356
Originally Posted by rocketron
Originally Posted by RussB
quick question, is there some sort of white fiber or rod impregnated into the arms? i noticed something that looked like thick dental floss in the front arm.
Thanks again
Ron
finding the problem is the first step toward fixing it.
#3359
Try this
#3360
Originally Posted by syndr0me
So they're leaning toward a material/injection issue rather than a design issue? Does that make it more easy to fix, if it's a problem with the batch of EA3 or whatever? I'm not a process guy, sorry.
the design seems beefy enough, and the jrxs ea3 arms i had my hands on were damn near indestructible.
