Old 04-13-2007, 08:12 AM   #3181
Send a message via AIM to Paul1786511
I know that this has been said before but where can i get the p-dub bumper from ?
Paul
Paul1786511 is offline   Reply With Quote
Old 04-13-2007, 08:31 AM   #3182
wannabee's Avatar
Paul
www.pdubracing.com
wannabee is offline   Reply With Quote
Old 04-13-2007, 08:32 AM   #3183
CRASH's Avatar
Trader Rating: 26 (100%+)
Paul
P-Dub Racing
Later,
CRASH is offline   Reply With Quote
Old 04-13-2007, 09:03 AM   #3184
Cheers Guys
Old 04-13-2007, 10:49 AM   #3185
EricF's Avatar
Why is it when you break your car its always from a lite "tap". Come on guys... are there really lite taps
E
EricF is offline   Reply With Quote
Old 04-13-2007, 10:54 AM   #3186
Yeti35's Avatar
E
These arms are taking less force to break then the previous graphite ones. The arm I broke a Pdub or Rubberneck bumper would have made no difference in savin it.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 04-13-2007, 10:54 AM   #3187
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
E
It's not that hard to believe. I set my old RDX on the track and was literally bumped from behind be someone also setting their car on the track. It broke the rear A-arm. That was the very first time I set the brand new car on ANY track, ever. It was a laughable "bump" that broke parts that should never have broken. I spent the next 5 months dealing with similar instances of breakage. I wasn't the only one to do so...
I've seen little "bumps" that broke parts on touring cars that would make you NEVER want to buy the cars that broke.
Hearing all of these stories is bringing me back to a place that I don't want to see again. I hope this stuff gets sorted out, because bumpers are Band-Aids for other problems and not cures or complete solutions.
I still REALLY want this car, but not if I need to keep dozens of spare arms in the tool box. I want to wrench LESS at the track, not more.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 04-13-2007, 10:57 AM   #3188
wannabee's Avatar
Is it true that the axles stick out past the rim?? If this is the case wouldn't those dig into the boards and rip the arm from the axle which if that is the case you'll need a 12" wide bumper...
Old 04-13-2007, 11:02 AM   #3189
RussB's Avatar
Send a message via MSN to RussB
the front arm i broke was definitely a light tap. it was my first pack with the car, i was not anywhere close to race speeds, was very easy on the gas, etc... i bumped a flexible bumper around a corner and the arm just snapped in half. i'm running the wide assoc hexes in the front, so axle sticking out from the nut was at a minimum.
i will grind my axles down before the next time i race, but i'm still going to run graphite arms...
RussB is offline   Reply With Quote
Old 04-13-2007, 11:11 AM   #3190
yyhayyim's Avatar
Talking
Yes, the axles stick out after tires are set and nut is bolted; they stick out an ugly 4mm at least. It looks like a those Roman/Greek chariot rides from 2000 yrs ago gladiators would fight with to take out each others wheels or cut off legs from by-standers. This is definetely part of the issue...
a) either a shorter axle needs to be realeased,
b) or a maybe bringing the arms out more by using the outer hole on suspension holders, instead of the inner one.
c) Or, using shims between the plastic wheel hex adapters and the tires so increase track width
d) Dremmel 4mm off the axles so that they are flush with the wheel nut once the wheels are mounted.
5) Drive it like its, solo, and always stay in the middle of the track; but dont get angry when others are blowing by you...
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 04-13-2007, 01:11 PM   #3191
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
If anyone cares to try, and they have the old car.. put the front axles on from it. Rather than butchering the new ones. I am running them and there have been times I have definitely cringed from a "board meeting" and like i have been saying all along, 2 broken arms in 3+ months... both of which, not from driving error. But one from someone turning on a radio, and the other from putting the car on the track and having it BLOWN off before I ran it..
Also= one day at CEFX last year some friends watched me go through my entire inventory of front right short arms on the old car. Infact, both of my front motor cars are is still sitting in my closet without a front right arms..
I do have a Rubberneck bumper.
KB
OUT
Keith Billanti is offline   Reply With Quote
Old 04-13-2007, 01:59 PM   #3192
hamster778's Avatar
Send a message via MSN to hamster778
Originally Posted by T. Hodge
Have you broke front or rear arms? Have you upgraded to a P Dub bumper or a Parma bumper. I wish the car could have came with a stiffer bumper. This is what we raced all season and we did not have production arms be this fragile.
Trust me the pro's hit stuff....really hard. I am just wondering if the stiffer foam bumper is helping?
I have just spent well over £300 on my new Losi tc, i shouldn't have to spend out more on a better bumper so that the soft plastic arms are better protected.
As a good will gesture, it would be nice if they were to send every type R owner a free p-dub bumper
Just my thoughts,
My car still broken, probably two more weeks to wait
Hamster
hamster778 is offline   Reply With Quote
Old 04-13-2007, 02:16 PM   #3193
syndr0me's Avatar
Trader Rating: 32 (100%+)
I spent twice as much as you on two cars, and it didn't come with a pony. I think Losi should send me a complementary pony.
syndr0me is offline   Reply With Quote
Old 04-13-2007, 02:43 PM   #3194
hamster778's Avatar
i've now got a tricycle
Old 04-13-2007, 03:10 PM   #3195
dr_hfuhuhurr's Avatar
Trader Rating: 70 (100%+)
KB
I've heard the Rubberneck bumpers are much better than the p-dub ones...can anyone confirm or deny this?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
