Old 04-10-2007, 08:12 PM   #3091
syndr0me's Avatar
Trader Rating: 32 (100%+)
I switched to the Platinum LiPo from the Carbon to do some testing, and wow, it's a really good fit! The rear bulkheads seem like they were intentionally squared off to handle the size of this battery perfectly.
It's good to see these design considerations being added to cars (Type-R, Mi3), not only because I hope for a LiPo-friendly future, but because it helps settle on a "standard" size for the use of LiPo, intentional or not. With cars being designed specifically to handle this size pack, it makes perfect sense for other companies to follow their lead (with the hard case, dammit) and build cases to the same dimensions. That could lead (hopefully) to other manufacturers creating optional chassis that have a rectangle milled into them to fit the LiPo packs rather than try and shoehorn something into the slots cut for NiMH. If there's a standard (spoken or otherwise) size, it makes those kinds of optional parts more reasonable to produce. Anybody releasing a LiPo pack now would almost definitely want to make it the same size as Orion's pack. A standard size has been one of the barriers of acceptance, and it's good to see at least that one slowly fading away.
syndr0me is offline   Reply With Quote
Old 04-11-2007, 03:09 AM   #3092
Originally Posted by Capelracer
Top layshaft is slightly bent - the spur gear gets a bit of a wobble up - pulled it all apart & checked & it's definately the layshaft at fault. I'll be all over the 1st aftermarket strengthened one to come out.
Mine, too!!!
xtaiji is offline   Reply With Quote
Old 04-11-2007, 04:39 AM   #3093
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
the lay shaft is thin.. and you can bend it.
im 99.9% sure that the old cars will fit, if you arent into the trick lightweight one.
KB
OUT
Keith Billanti is offline   Reply With Quote
Old 04-11-2007, 06:57 AM   #3094
highwayman's Avatar
Ready for outdoor setup - B*LL*CKS!! There was no swaybars, oil or springs to build it with the outdoor setup straight outta the box. Now, I don't expect these things to be in there usually, but after all the "there's rubber/asphalt setup included" I was expecting to build that setup straight out of the box - if I'd known I needed extra parts I would have ordered them when I purchased the car, now I'm waiting another 4 days until I can get it finished.
what's the oil? spring? that came with the kit?
highwayman is offline   Reply With Quote
Old 04-11-2007, 07:06 AM   #3095
masterhit's Avatar
50wt oil, 30lb, and 17.5lb springs.
Mike Slaughter
masterhit is offline   Reply With Quote
Old 04-11-2007, 07:51 AM   #3096
dr_hfuhuhurr's Avatar
Trader Rating: 70 (100%+)
Originally Posted by RBLove
Sorry to hear of your trouble. As for the layshaft being bent. I am sure Losi will replace this part for you. Contact Horizon Hobby about the part.
I am sure once you set the car on the track your troubles will be forgotten. the car is money!
Rob, you planning on heading to WOH frequently on Wednesdays? Time is VERY limited right now but I might be able to squeeze out a Wednesday here and there.
Give me a shout bro.
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 04-11-2007, 07:52 AM   #3097
People actually race on surfaces other than carpet? Wierd
Old 04-11-2007, 08:09 AM   #3098
KB
Nope. U can't bend it. Try it.
Old 04-11-2007, 08:16 AM   #3099
Yeti35's Avatar
Either contact Hodge and he will have a new one sent out, or just get the shaft from the old car at your LHS. I believe the old one should work as well, they spacing all looks the same to me.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 04-11-2007, 08:20 AM   #3100
Thanks. I already have contact a distributer.(not US)
Old 04-11-2007, 10:07 AM   #3101
Trader Rating: 7 (89%+)
I think Hebert broke one at one point..
Johnny Carey is online now   Reply With Quote
Old 04-11-2007, 10:46 AM   #3102
RC MARKET's Avatar
HK not have this car ,
& i'm saw many online shop sold out spare parts !
RC MARKET is offline   Reply With Quote
Old 04-11-2007, 01:09 PM   #3103
Send a message via AIM to Paul1786511
Added a picture of thre wiring with brushed motor, think it looks pretty neat
Paul1786511 is offline   Reply With Quote
Old 04-11-2007, 02:13 PM   #3104
TheCoolCanFanMan's Avatar
Default Type R wiring
Heres mine also quite neat I think. I also think it warants a CCF as the fans need to come accros a tad on both fans.
Cheers Malc
Team Losi JRXS Type-R-type-r-rc-004a.jpg   Team Losi JRXS Type-R-type-r-rc-005a.jpg   Team Losi JRXS Type-R-type-r-rc-006a.jpg
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 04-11-2007, 02:24 PM   #3105
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Here's mine
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
