Old 04-10-2007, 11:27 AM   #3076
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Originally Posted by TL_XXX-S_racer
RussB: Thanks. Ill do that too. I also noticed that the belt wasnt centering on the diff pulley and the pully that is connected to the spur gear shaft. Maybe adding the diff rings to the front spool will center it.
I thought that the pads would replace the rings, cause they're just as thick as the rings.
What adjustments did you guys make to the car from the car setup? Im gonna run 19T, so just want to have an idea what to expect, and what to change after the first couple runs. Im thinking of running mod as well, soon. Do you guys put the sway bars as well, like the setup says. Im running on asphalt, CS27, med grip.
chris
hey Chris talk to Jeff F. his TypeR was dialed last week at Superiors
Old 04-10-2007, 12:06 PM   #3077
RussB's Avatar
Send a message via MSN to RussB
i race at speedworld raceway (unsealed ashpalt, high grip, decent size track) and started with todd's setup from the nats there. the only changes i made were to set the droop as described in the tuning section of the manual, and moved the front shocks out to the middle hole as the track was a bit tighter than at the nats. oh, i also ran short front arms out of necessity, but the change felt good on that track. it took out a little of the super aggressive steering.
the car was awesome, much faster than my old mid motor car. my driving however was not awesome.
RussB is offline   Reply With Quote
Old 04-10-2007, 12:36 PM   #3078
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
alright. Thanks guys for the response
What 19T would you recomend? im thinking of getting the Komodo.
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 04-10-2007, 01:01 PM   #3079
rocketron's Avatar
Trader Rating: 16 (100%+)
you may consider the new Peak/Orion 19t 2007 characteristics of komodo with better magnets imho....
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 04-10-2007, 01:11 PM   #3080
Super Moderator
Marcos.J's Avatar
Checkpoint and gear it to the moon
Old 04-10-2007, 01:26 PM   #3081
TryHard's Avatar
Setup from WLRC yesterday.
Regards
Ed
Old 04-10-2007, 01:27 PM   #3082
Super Moderator
Marcos.J's Avatar
Regards
Ed
wow a set up from the future
Old 04-10-2007, 01:28 PM   #3083
TryHard's Avatar
Uk date style D/M/Y
Old 04-10-2007, 01:29 PM   #3084
Super Moderator
Marcos.J's Avatar
Uk date style D/M/Y
so its May in the UK??
Old 04-10-2007, 01:50 PM   #3085
TryHard's Avatar
check again.. do do do do...
Old 04-10-2007, 01:51 PM   #3086
Super Moderator
Marcos.J's Avatar
Old 04-10-2007, 05:25 PM   #3087
Capelracer's Avatar
OK, finished my build (well kinda), here's my impressions....
Top layshaft is slightly bent - the spur gear gets a bit of a wobble up - pulled it all apart & checked & it's definately the layshaft at fault. I'll be all over the 1st aftermarket strengthened one to come out.
Drive pulley holes didn't line up.... until I tried every combination of alignment! They do go on straight, but there's only one way they seem to (only 9 different combinations of hole alignment)
Ready for outdoor setup - B*LL*CKS!! There was no swaybars, oil or springs to build it with the outdoor setup straight outta the box. Now, I don't expect these things to be in there usually, but after all the "there's rubber/asphalt setup included" I was expecting to build that setup straight out of the box - if I'd known I needed extra parts I would have ordered them when I purchased the car, now I'm waiting another 4 days until I can get it finished.
Other than that, it's all good - went together very nicely. Can't wait to run it, hope my parts get here b4 the weekend so I can race it this weekend.
Capelracer is offline   Reply With Quote
Old 04-10-2007, 06:13 PM   #3088
Trader Rating: 71 (100%+)
Sorry to hear of your trouble. As for the layshaft being bent. I am sure Losi will replace this part for you. Contact Horizon Hobby about the part.
I am sure once you set the car on the track your troubles will be forgotten. the car is money!
RBLove is offline   Reply With Quote
Old 04-10-2007, 06:44 PM   #3089
ground-round's Avatar
Trader Rating: 14 (100%+)
The only change I made from the box asphalt setup was moving the front shocks out one hole and using 40wt shock oil up front. She's fast.
ground-round is offline   Reply With Quote
Old 04-10-2007, 06:48 PM   #3090
cool. Do you run the sway bars? cant wait to run it.
ProMatchRacing
Team Corally
Superior Hobbies
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
