Old 04-08-2007, 09:57 AM   #3046
RussB's Avatar
Send a message via MSN to RussB
syndr0me, regarding the spool... you really only need the pads. you can remove the diff balls from your current pulley and add the spool pads. it looks like they are only sold with the pulleys though. if you go that route, vs. drilling out the center of an old pulley, be careful as they are made of a thin and brittle material. even if they crack though it's fine, they can still be used just fine.
RussB is offline   Reply With Quote
Old 04-08-2007, 09:58 AM   #3047
Originally Posted by 429racer
On another note, what do most people who use foam tires do when your tires gum up and start balling hair on them do to prevent this? My car in practice is just stupid fast when the tires are fresh trued and compounded, but then after that they just gum up like crazy (I use lighter fluid to clean them off, but still seem kinda gummy), and the car goes into ill handling due to the hair building up on the tires. Any methods to prevent this or how do you guys keep the tires prepped and clean?
How often are you cleaning the tires with L/F? I found with a high traction track - with lots of compound layed-down, you need to clean the tires between rounds.
duckman996 is offline   Reply With Quote
Old 04-08-2007, 10:01 AM   #3048
Originally Posted by syndr0me
I tried typing that all into Google, but it brought up links for some seedy Canadian porn site.
Not to mention we have some of the best strip-clubs as well....
Old 04-08-2007, 11:19 AM   #3049
TLRacing
Todd Hodge's Avatar
Apex, the car plays out like the RDX. A better than stock front bumper and a lower brace and I think the front end breakage is minimized. Most people I knew had the same problem with the RDX and once the Kydex bumper and brace was put on, the breaking was reduced dramatically (I noticed it with my RDX, I couldn't hardly break the car if I wanted to). I will not run this car again till I get BRP brace and P-Dub bumper. The track I run on has alot of wood with plastic flappers on the corners, but may not be as forgiving as other tracks.
I have found that denatured alcohol works best for foam tires.
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 04-08-2007, 11:23 AM   #3050
TLRacing
Todd Hodge's Avatar
Default Caster Blocks and Spindles
If you guys are looking for caster blocks and spindles Team Losi has them available in graphite right now. We are working on the EA3 ones now.
LOSA9756 2deg FR Spindles & Carriers-GR
LOSA9757 4deg FR Spindle & Carrier,Graphite
LOSA9758 6deg FR Spindles & Carriers-GR
LOSA9759 8deg FR Spindles & Carriers-GR
These will get you by until the EA3 caster/spindle come to market.
Also for spool users, you can get the LOSA3325 spool. Remove the pads and put them in your Type R pulley. Be careful doing this as the pads are brittle. This is why they come installed in the pullies.
Todd Hodge
Old 04-08-2007, 12:31 PM   #3051
Send a message via AIM to Paul1786511
Well spent all of friday and most of saturday building the car up. must say was impressed with the way the car went together. Will post a bit of the electric install when i get a chance
Ran it for the first time today, went out on kit setup (rubber) to start with then, moved the rear shocks out and put high roll centre on the front and the car felt soooo nice, so first outing out after 20 mins of running, put it 10th in the A, at what was basically a national level final, and managed to finish 6th overall.
Vey impressed so far and was definatly worth the wait
Any one requires setup just email me
Paul
Paul1786511 is offline   Reply With Quote
Old 04-08-2007, 01:16 PM   #3052
edward Haywood's Avatar
Default Also for spool users, you can get the LOSA3325 spool. Remove the pads and put them in
As for the spools ...are they best on carpet or can you add them if you are going to run on asphalt ....I 'am going to be running carpet mostly so would this be a good idea
Mtx-4.....Rolling baby/Blue Diamond /West Chester/
Magneto X-Woodawson/FX/Nitro forever/
edward Haywood is offline   Reply With Quote
Old 04-08-2007, 01:26 PM   #3053
Typically spools are run on asphalt... big open tracks with some 90 degree turns. For carpet, a diff with foams, or a one-way with rubber.
Old 04-08-2007, 02:05 PM   #3054
hamster778's Avatar
Send a message via MSN to hamster778
Hi guys, just got back home from the cotswold track, i ran the new car for the first time there today. i used a lipo for a few practice laps and it felt very good, just the back end a little loose, the track was very dusty though.
Back to the normal 5 cell for racing though, still very good, it is show good promise of things to come. Till in the second round someone decided to smash the front left side off of the car, wish bone, diff out drive and spool. Do'h
So back to the old car for a while then.
Lets hope Helger ( Uk importer ) have got the bits in already
hamster778 is offline   Reply With Quote
Old 04-08-2007, 03:20 PM   #3055
Trader Rating: 17 (100%+)
I would clean my tires after every round, but they would still feel a little sticky so I would not use traction compound on them again, until they felt dry, but they never would dry up they just kept gumming from running on the track. Here was my method:
I would compound the tires and let them sit for 3-5 minutes wipe off, then run. After my run I would use the lighter fluid to clean them off. I tried running them after being cleaned and not compounding they would work good for a few laps then gum back up.
Hey Todd thanks for the reply! Is there a specific brand and where I should get the denatured alcohol from? Is that like rubbing alcohol? I have been using lighter fluid, but it seems like it does not clean the tires off enough. I hate to bug you about this but what is your tire method of prepping using alcohol?
429racer is offline   Reply With Quote
Old 04-08-2007, 05:50 PM   #3056
Trader Rating: 22 (100%+)
Send a message via AIM to AChupp2
Are you guys spraying motor spray directly on the tires or are you spraying it on a rag and wiping the tires off?
Fantom Racing Team Manager
AChupp2 is offline   Reply With Quote
Old 04-08-2007, 05:56 PM   #3057
RBLove's Avatar
Trader Rating: 71 (100%+)
I would recommend spraying a rag and then wiping the tires off.
RBLove is offline   Reply With Quote
Old 04-08-2007, 05:58 PM   #3058
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Denatured alcohol can be purchased by the quart from Home Depot or Lowes. I pour it into a cheap spray bottle (also from Home Depot) and use it to clean everything from gummy tires, to white scuffed wheels, to bodies before they are painted. Works great on just about everything and doesn't harm plastics.
We had the foam tire issue last winter in 12th scale, and found that one compound harder in tires helped, as well as not using Paragon on the tires for more than the time it takes to apply them to all of the tires and wipe them off. The problem isn't your car or tires, it's the carpet on the track, and the amount of compound and rubber in it.
I also had good luck using Goop/GoJo hand cleaner on the tires, just to open the pores and soften them up. They didn't get as sticky and messy as the Paragon made them.
And I found that lighter fluid works the best to clean that gummy mess off without drying out the tires.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 04-09-2007, 08:13 AM   #3059
TLRacing
Todd Hodge's Avatar
It is not rubbing alcohol, as Apex you can find this at the local #20 or #48 store down the street. A quart will last you a long time. I use a old paragon can and store the alcohol in there, this makes an easy applicator.
Todd Hodge
Old 04-09-2007, 09:31 AM   #3060
Lana's Avatar
Be very careful when using Denatured alcohol it burns clear!! So If you smoke do yourself a favor and light up after using it.
I have had a very close call with it.
Lana is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
