Old 03-26-2007, 04:48 PM   #2611
TheCoolCanFanMan's Avatar
Originally Posted by Livingston
Tim
Front posts are the same.
Rear can be in same position or can be mounted 1 inch
further out on each side.
It also looks like length from front to rear posts is a little
longer, will measure when I finish building.
A few posts back I seem to recal someone, maybe KB mentioning there were in the same place as the JRX-S
Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 03-26-2007, 04:58 PM   #2612
Andrew Gray's Avatar
Originally Posted by J.Filipow
Yeah, but we don't like YOU!
Sorry about your luck bud, 2 each his own.
Retired & Washed Up. TLR Supporter For Life
Andrew Gray is offline   Reply With Quote
Old 03-26-2007, 05:03 PM   #2613
hamster778's Avatar
Send a message via MSN to hamster778
With my new job i am able to get home a bit earlier so i might get the new body painted then and drill the hole later on.
The last body i did i forgot to drill the holes first so its no biggy i guess.
Are the body mounts as thin as they are on the old car, on my old car i have the new xray ones, nice and strong.
Yes Malc, i know i need them. Te he
Tim
hamster778 is offline   Reply With Quote
Old 03-26-2007, 05:04 PM   #2614
J.Filipow's Avatar
Trader Rating: 15 (100%+)
....man, "you're just a teenager, with a little bit of gold and a pager!"
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 03-26-2007, 06:16 PM   #2615
dr_hfuhuhurr's Avatar
Trader Rating: 73 (100%+)
Are all the bearings the same from the JRXS to the TypeR?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 03-26-2007, 06:22 PM   #2616
Keith Billanti's Avatar
all but the diff and steering rack...
OUT
Keith Billanti is offline   Reply With Quote
Old 03-26-2007, 06:38 PM   #2617
Yeti35's Avatar
Pooky, why did you not just make your spool gear fit like I told you I did it? You like the Dremel and it works well.
Any one else that did not hear how I did it here is how. I took a tapered grinding stone for the dremel and just ground the hole out till it was as big as the inside diameter of the spool pad. I test fit it on the diff tube and it works fine.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 03-26-2007, 06:46 PM   #2618
hamster778's Avatar
when these newer style of pulley came out i ordered a few, but they came with the larger hole in, i thought this was very strange at the time. but now i'm glad i didn't send them back.
so no drilling for me, at least for a while any ways
i did drill one out for the one way, i used a sharp step drill taking it one at a time and trying it. this wa works well too
Cheers
Tim
Old 03-26-2007, 07:40 PM   #2619
A_Stratus's Avatar
I have a question about the production kit...What degree rear toe block does it come with or does it come with all the aluminum blocks?
Team Express Motorsports
HOBBYCRAFT CANADA
Rizzo's Rides
CEFX
A_Stratus is offline   Reply With Quote
Old 03-26-2007, 07:42 PM   #2620
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
comes with 0deg rear blocks and all the aluminum you see!
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 03-26-2007, 08:22 PM   #2621
CRASH's Avatar
Trader Rating: 26 (100%+)
It comes with a 0 degree front aluminum block, 2 degree aluminum rear toe block and 0 degree rear hub carriers. The car has 1 degree of toe in built in for a total of 3 degrees rear toe.
Hope this helps.
CRASH is offline   Reply With Quote
Old 03-26-2007, 10:29 PM   #2622
mikez's Avatar
Did anyone check there rear tow?Out of the box it is 3 deg. of tow in.
I went over it and the same lame problem on every losi I ever had.
The tow is never the same from left to right.I have 3deg. on left and 2deg. on right.You would think losi would get it right this time .Also did anyone check how much play in the sus.arms there is.Left front was decent but the right was loose.I had to shim to take some of the play out.The rear arms were like this also.Did anyone have these problems?
Laterz.
mikez is offline   Reply With Quote
Old 03-26-2007, 11:44 PM   #2623
There is 1 degree of toe built into the rear(in the chassis). So if you use the 2 deg. pivot you will have 3 deg. total rear toe, if you use the 1 degr. you will have 2 deg. total rear toe and so on.
Laterz.
Old 03-26-2007, 11:47 PM   #2624
"searching my car, looking for the product, thinking every ...... is selling ?????????"
Old 03-26-2007, 11:48 PM   #2625
Trader Rating: 29 (100%+)
When you say built in the chassis, do you mean by the toe blocks/sus. arm mounts?
$$$... is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
