Old 03-26-2007, 04:00 PM   #2596
TheCoolCanFanMan's Avatar
Originally Posted by m8commando
So what did you do to fix that problem, because the diff hub on the type R is plastic....
Tried not to tighten it up so much
The other thing I have found is that when building the spool, its never centres on the pulley properly, therefore when you try and tighten the belt it seems to tention up and slacken off due to it not being centered
Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 03-26-2007, 04:04 PM   #2597
Originally Posted by hamster778
Hi guys
i have just had a spool play up, it was down to the nut and screw stripping.
This is the first time i have had such a thing go wrong the whole time i've had the car.
The hardest part of the repair was to get the old screw and nut out with out breaking the diff outputs..
Still looking forward to getting m hands on the new car
Tim
Hey Tim
You forgot to tell them you have probs with your thumbs to
Malc
Old 03-26-2007, 04:08 PM   #2598
hamster778's Avatar
Send a message via MSN to hamster778
Yeah thats true,
i should get some L and R stickers made up
Te he
hamster778 is offline   Reply With Quote
Old 03-26-2007, 04:12 PM   #2599
rocketron's Avatar
Trader Rating: 16 (100%+)
Hi guys
Tim
it seems your referring to the OLD spool and not the one used on the type-R
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 03-26-2007, 04:21 PM   #2600
RBLove's Avatar
Trader Rating: 72 (100%+)
Originally Posted by T. Hodge
A little fyi for everyone, at most of the races this past season we use double pink orange fronts and double pink rears. We even used this at Vegas and we had one of the best cars at the event. I am not really sold on the double pinks all around. At the ROAR Nats, we did use single stage double pinks and ran well for the first time however we did glue the front outer side wall above the sidewall. For some reason the Type R does not need the ultra aggressive front tire like other cars. For the most part we did not like the 26mm tires on high bite as it would make the car lift in the middle of the turn.
This is good information. I assumed everyone was running rears all the way around, but knowing that you do not have to do this with this car is very helpful.
THANKS DUDE~~!
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Old 03-26-2007, 04:22 PM   #2601
hamster778's Avatar
The Pulley that i use on the JRx-s is the same one that can used on the new type R
Its just the rest of the diff that is different.
Tim
Old 03-26-2007, 04:25 PM   #2602
Tim
Just hope it centres better on the Type R
Malc
Old 03-26-2007, 04:25 PM   #2603
hamster778's Avatar
Default Body Mounts
Hi guys
On the new car, are the body mounts in the same places as the old car?
Tim
Old 03-26-2007, 04:28 PM   #2604
Hi guys
Tim
yep sure are Tim
Malc
Old 03-26-2007, 04:28 PM   #2605
hamster778's Avatar
Malc
Just been looking at the Manual, i believe on the new diff the pulley goes on like the one way did, so hopefully it will be fine
Tim
Old 03-26-2007, 04:31 PM   #2606
Originally Posted by mainracer
here is what we ran ( the only thing I can't remember and I can't look on the car is where the ball stud was on the rear hub )
front :
20 spring 40 oil, 56 piston,
4 degree caster
middle hole on tower
camber link :jr front link , in and up on tower
high roll center
0 degree pivot
one way set to High position
arm spacing middle
Rear :
12.5 spring, 30 oil, 56 piston,
middle hole on tower,
camber link : middle in on tower, I think outside on hub + short ball stud
High roll center
Low rear diff
2 degree pivot
long arm
1/2 rear std hub
arm spacing middle
Dumas ran a type m body while we ran a mazda.
Thanks Kevin.....you saved me alot of work
now when is that oneway due out.....Todd???
Josh Hohnstein is offline   Reply With Quote
Old 03-26-2007, 04:38 PM   #2607
hamster778's Avatar
yep sure are Tim
Malc
Cheers for that Malc, i shall get a body made up ready. save me one thing to do once the car finally comes.
Tim
Old 03-26-2007, 04:38 PM   #2608
Capelracer's Avatar
This may be a biased opinion since I run for them however I think the Novak is the best. I have used the Novak GTB with the Orion BL and it has worked great. I just need to get more Orion BL motors and that is all I will run.
Mount the ESC on the right side of the chassis. This will give you more room to work with as you will not be working around the front belt.
Any chance of a couple of pics??? Cheers...
Capelracer is offline   Reply With Quote
Old 03-26-2007, 04:38 PM   #2609
Tim
Front posts are the same.
Rear can be in same position or can be mounted 1 inch
further out on each side.
It also looks like length from front to rear posts is a little
longer, will measure when I finish building.
Livingston is offline   Reply With Quote
Old 03-26-2007, 04:45 PM   #2610
Tim
No probs, just name it
Malc
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
