Old 03-26-2007, 02:31 PM   #2581
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Andrew Gray
Great to hear that everyone is liking their new rides.
Yeah, but we don't like YOU!
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 03-26-2007, 02:37 PM   #2582
Originally Posted by mainracer
we ran oneway
Thanks....anything else you can tell us about the setup.
roll center, arm spacing, shock location and castor
Josh Hohnstein is offline   Reply With Quote
Old 03-26-2007, 02:52 PM   #2583
Send a message via MSN to TAMIYAMANUK
anywhere in the uk that i can get my greasy hands on one dont want use my LHS as he is just a waste of time and would probably take him months to get one in stock.
TAMIYAMANUK is offline   Reply With Quote
Old 03-26-2007, 03:01 PM   #2584
POOKYT's Avatar
Spool users! I used the spool pads from a pulley for my old JRXS. Be VERY carefull if you try to pry them out of the pulley. I cracked one but it shouldn't cause any problems since it will be nearly locked up. Once the first pad was removed the other simply pressed out. I put these pads in the kit supplied 41 tooth pulley. Good luck and continue the info guys!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 03-26-2007, 03:11 PM   #2585
TheCoolCanFanMan's Avatar
Originally Posted by vabroom
Also try Losi Parts House. They sent theirs out insured.
LPH 0 in stock
M
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 03-26-2007, 03:16 PM   #2586
Not in the UK as yet dude
Malc
Old 03-26-2007, 03:17 PM   #2587
m8commando's Avatar
Brant
Does this type of spool ever come loose.......or has anybody had a problem with the spool loosening during a race? and how do you prevent it?
JAF RACING / AIRTRONICS
m8commando is offline   Reply With Quote
Old 03-26-2007, 03:28 PM   #2588
syndr0me's Avatar
Trader Rating: 32 (100%+)
I'm going to weigh my car tomorrow and see how much weight it requires with the carbon LiPo. I think it's only about 6oz under with the body, but I'll know for sure later. Anyway, I believe, at least with the carbon LiPo, I may have found a solution. If the measurements on these tungsten plates are close to what they've advertised, they should fit 2 wide/3 long perfectly on the underside of the carbon battery, and not obstruct its ability to sit flat in the LiPo tray. I can sticky that to the bottom of the tray to gain 3oz down low. I believe I can add the same amount of weight to the top of the battery, or possibly even inside its case down at the bottom. I haven't checked if there's any room on the inside yet. At any rate, that opens up the possibility of adding 9oz within the battery area, which I believe will be way more than needed. Unfortunately, the tungsten weights aren't cheap.
If this works, it may end up that the carbon LiPo is a better choice for this car since it gives you some useful places to add weight. I mentioned in the carbon thread that a way to easily add weights to their batteries (as needed) without changing the form factor would be awesome, and they said they're already looking into it. In the meantime, this may work out okay. I'll take pictures and update this thread with my progress.
Originally Posted by markf3x
Earlier I saw a post suggesting that a steel Lipo tray could be made to add weight (in a very low location). I couldn't find this earlier message, so I don't know if you all already know this, but... While building my new car I was playing around with an orion 4800 in the chassis and it fits like a glove. The top of the Lipo is less than 1mm to a notch in the bulkheads. It is VERY obvious that they had an Orion 4800 in their hand when they designed this.. It looks like to keep the upper deck as low as possible, the tray that the Lipo sits on is quite thin (say 1-1.5mm maybe). This means with a steel plate, you'll proabably only get a couple ounces of weight under the LiPo. Hmmm. Anybody else come up with a ballast technique to get their LiPO car up to weight?
Maybe I need to make that plate out of Gold or Tungsten?
Mark
syndr0me is offline   Reply With Quote
Old 03-26-2007, 03:35 PM   #2589
Lightbulb
I personally have had a problem when if you tighten up the screw up to much into the T nut you can brake the diff half.
Malc
Old 03-26-2007, 03:39 PM   #2590
POOKYT's Avatar
I never had any loosening issues with it last year. Its designed to actually "give" a little during a hard impact.
Malc--If you would quit using those Big car tools on your little car then things would be OK!! LOL
Brant
Old 03-26-2007, 03:40 PM   #2591
rocketron's Avatar
Trader Rating: 16 (100%+)
did you find PADS Shawn? when running the PADS it has not come loose on me. I have run it two full days without it backing off. It wouldn't hurt to monitor every so often as it is now so easy to get to.
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 03-26-2007, 03:49 PM   #2592
Malc--If you would quit using those Big car tools on your little car then things would be OK!! LOL Brant
its not he size of my tool its the size of my hands dude
Malc
Old 03-26-2007, 03:49 PM   #2593
mainracer's Avatar
Send a message via AIM to mainracer
here is what we ran ( the only thing I can't remember and I can't look on the car is where the ball stud was on the rear hub )
front :
20 spring 40 oil, 56 piston,
4 degree caster
middle hole on tower
camber link :jr front link , in and up on tower
high roll center
0 degree pivot
one way set to High position
arm spacing middle
Rear :
12.5 spring, 30 oil, 56 piston,
middle hole on tower,
camber link : middle in on tower, I think outside on hub + short ball stud
High roll center
Low rear diff
2 degree pivot
long arm
1/2 rear std hub
arm spacing middle
Dumas ran a type m body while we ran a mazda.
Keven Hebert
AE / Reedy / LRP
KOpropo / Much-More / Parma PSE / Protoform / APS ceramic Bearing / BawdyShop / Fastcats / Dekelz
mainracer is offline   Reply With Quote
Old 03-26-2007, 03:50 PM   #2594
m8commando's Avatar
Malc
So what did you do to fix that problem, because the diff hub on the type R is plastic....
Old 03-26-2007, 03:50 PM   #2595
hamster778's Avatar
Send a message via MSN to hamster778
Hi guys
i have just had a spool play up, it was down to the nut and screw stripping.
This is the first time i have had such a thing go wrong the whole time i've had the car.
The hardest part of the repair was to get the old screw and nut out with out breaking the diff outputs..
Still looking forward to getting m hands on the new car
Tim
hamster778 is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
