Old 03-26-2007, 11:20 AM   #2566
rocketron's Avatar
Trader Rating: 16 (100%+)
Parts List, Expoded Views etc... and Setup Sheets are now available on the Horizon website now
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 03-26-2007, 11:29 AM   #2567
markf3x's Avatar
Originally Posted by TryHard
Hey Todd,
Have you got a suggestion for a base rubber tire carpet setup? I understand it's mainly a spring change and maybe change the front axle to a one-way to get the car working with rubbers.
I took the plunge last week to try something a little different, so a Type-R is on it's way Rubbers only at the local club though, tyres CS22 or VTec24R
Cheers
Ed
I got my Type R a couple of days ago and putting it together currently. I will be running it in rubber class. Mike Dumas asked Todd on my behalf this same question.. In Vegas apparently they ran 25lb front springs, 15 in the rear. Would love to see a completed setup sheet (Todd?) to find out the fine details (oil weight, piston holes), and other geometry.
Mark
markf3x is offline   Reply With Quote
Old 03-26-2007, 12:26 PM   #2568
markf3x's Avatar
Default Adding weight to LiPo tray.
Earlier I saw a post suggesting that a steel Lipo tray could be made to add weight (in a very low location). I couldn't find this earlier message, so I don't know if you all already know this, but... While building my new car I was playing around with an orion 4800 in the chassis and it fits like a glove. The top of the Lipo is less than 1mm to a notch in the bulkheads. It is VERY obvious that they had an Orion 4800 in their hand when they designed this.. It looks like to keep the upper deck as low as possible, the tray that the Lipo sits on is quite thin (say 1-1.5mm maybe). This means with a steel plate, you'll proabably only get a couple ounces of weight under the LiPo. Hmmm. Anybody else come up with a ballast technique to get their LiPO car up to weight?
Maybe I need to make that plate out of Gold or Tungsten?
Mark
Old 03-26-2007, 12:31 PM   #2569
mainracer's Avatar
Send a message via AIM to mainracer
Hi Mark,
If I am not mistaken, we ran a 20 pound spring up front and a 12.5 rear in vegas for rubber. I still have my car partly build and that is what the spring says. As for oil if I remember right, we ran 40 front 30 rear with 56 piston al around. We also ran sway bar front and rear I think it was a .030 rear and .040 front.
hope that helps !
Keven Hebert
AE / Reedy / LRP
KOpropo / Much-More / Parma PSE / Protoform / APS ceramic Bearing / BawdyShop / Fastcats / Dekelz
mainracer is offline   Reply With Quote
Old 03-26-2007, 12:37 PM   #2570
Type-R arrived today in UK, starting its build tonight.
Should test it Friday or Saturday at Aldershot for SLCC.
Livingston is offline   Reply With Quote
Old 03-26-2007, 12:40 PM   #2571
sportpak's Avatar
Trader Rating: 26 (100%+)
Mark
The tungsten would be cool, but I wouldn't want to machine it. Even if a steel one wouldn't get you home on weight, it would help. You could then use what's still needed to dial in front/back left/right balast. I'm gonna work on it whenever the UPs man shows up .
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 03-26-2007, 01:01 PM   #2572
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
R is awesome in stock....gonna take me from the g to the b
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 03-26-2007, 01:15 PM   #2573
markf3x's Avatar
Originally Posted by mainracer
Hi Mark,
hope that helps !
Thanks, This helps alot.. I was planning to go 20lb and 12 anyhow because of our local very low traction carpet track. It seems that all "Big Race" setups you see are for tracks with alot more grip than ours has.
Mark
Old 03-26-2007, 01:39 PM   #2574
RBLove's Avatar
Trader Rating: 71 (100%+)
Originally Posted by schreff
Yo yo fellas!!
I ran my Type R for the first time this weekend at Carpet Wars @ The Track in Maryland.
I must say, for my first time out with the car, I was extremely pleased. The car changes directions like no other car I've ever driven. It has a completely different feel, but it's a good one.
In stock, I qualified 2nd and finished 3rd. In 19t, I qualified 2nd and finished 3rd. The results don't justify how good the car was. Either I had bad racing luck or just drove poorly. The car was easily fast enough for TQ and Win in stock. As for 19t, I have a little work to do there.
I did have the advantage of working with Andrew Gray and past Losi driver Craig Xavier. <- A big thanks to both these guys! I look for a different feel with my cars than Gray and X do. Some of the info they provided me worked for me, but I had to do some stuff on my own as well. I did need softer front springs though, that would have helped a lot.
I did let Larry Fairtrace (2007 SnowBirds Stock Touring Champ) drive my car in practice. He was really surprised how good the car was on only the 2nd pack on the track.
Only gonna get better as I get more time on the car.
Thanks again Todd!!
Awesome.........
RBLove is offline   Reply With Quote
Old 03-26-2007, 01:52 PM   #2575
Andrew Gray's Avatar
Great to hear that everyone is liking their new rides.
Retired & Washed Up. TLR Supporter For Life
Andrew Gray is offline   Reply With Quote
Old 03-26-2007, 01:58 PM   #2576
Hi Mark,
hope that helps !
Kevin.....oneway or spool???
thanks Josh
Josh Hohnstein is offline   Reply With Quote
Old 03-26-2007, 02:07 PM   #2577
TheCoolCanFanMan's Avatar
you have pm
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 03-26-2007, 02:15 PM   #2578
vabroom's Avatar
Originally Posted by L.Fairtrace
Too bad they are sold out at horizon, casue I need something to build this week.
Also try Losi Parts House. They sent theirs out insured.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is online now   Reply With Quote
Old 03-26-2007, 02:27 PM   #2579
mainracer's Avatar
we ran oneway
Keven Hebert
AE / Reedy / LRP
Old 03-26-2007, 02:30 PM   #2580
TryHard's Avatar
Hi Mark,
hope that helps !
Cheers boss. As asked above, one-way/spool/diff?
EDIT - Beat me to it
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
