Old 03-24-2007, 12:44 AM   #2446
syndr0me's Avatar
Trader Rating: 32 (100%+)
If you plan on running the 13.5, I hope you've got some BIIIIIIIG pinion gears. There's not much hope of running anything lower than 108T spur. A 100T with 41T pinion was about a mile off. :-O
I guess I'm just a gimp. The PRS thing is working fine now, I just made the slot longer with the dremel. I guess I could have filed the pin too. Now I've just got a snug fit so that the layshaft can't move side to side at all. I checked everything mentioned here and still no luck.
Mounting a GTB in this sucker has been interesting. I ended up having to do it like the picture of Todd's car. Otherwise, the belt is in the way and the ESC is hanging off the side too much.
syndr0me is offline   Reply With Quote
Old 03-24-2007, 01:08 AM   #2447
syndr0me's Avatar
I just snatched up 49-56 from PRS. Crazy, these huge pinions look goofy next to the spur.
Old 03-24-2007, 01:57 AM   #2448
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
anyone else get a spare shock bladder? cause im looking at 4 built shocks and 1 bladder.....and im 99.2% positive that i have them all in there
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 03-24-2007, 02:07 AM   #2449
Yeti35's Avatar
I hope the handling far out ways some of the little things about the car I do not like. I am not crazy about the battery tray in this car. I like the old one with two screws better. Installing electronics on this thing is really tight and stuff does over hang the chassis. I run a GTX and it still over hangs the chassis a little. I am probably going to purchase a micro Spektrum receiver in the future for I don't like how the regular one hangs off the chassis.
I do have to say I had no issues building it though and thought it went together well. I also like how the up limit adjustment brackets are now part of the arms. The diff tubes and indrives are really nice. Diffs will be so much easier to work on now since it is four screws and it is out.
The transponder worked out fine for me even though I don't have ears on it anymore. It just fits on the chassis in back of the roll center brace with the velcro I normally used to install it.
I only need to change my wires on my speedo and put the thing on a setup station and all will be done. I only wish I had somewhere to run it now!!
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 03-24-2007, 02:08 AM   #2450
Yeti35's Avatar
Better pull them apart and check again!!
22 2.0
22T 2.0
Old 03-24-2007, 03:06 AM   #2451
syndr0me's Avatar
The SLR was dead, so I had to grab my wife's crappy camera which seems to struggle with, well, anything related to creating digital photographs in focus. Anyway, here's the completed monster with 13.5, GTB and Carbon LiPo. We're DEFINITELY going to need a weighted LiPo tray, I don't see how we can make weight without putting it on the outside of the chassis.
Team Losi JRXS Type-R-img_0086.jpg   Team Losi JRXS Type-R-img_0087.jpg   Team Losi JRXS Type-R-img_0088.jpg   Team Losi JRXS Type-R-img_0089.jpg   Team Losi JRXS Type-R-img_0091.jpg
Old 03-24-2007, 03:21 AM   #2452
syndr0me's Avatar
For the brushless folks, it seems like an ESC designed like the Genius 95 up on its side might make more sense on this chassis to keep things from hanging over too much. Too bad Orion canned their version of it. :-(
Old 03-24-2007, 04:23 AM   #2453
PeteB's Avatar
For those that have built their cars...
how hard will it be to remove bearings for cleaning. is it a 30 min marathon, followed by a complete rebuild, or is it a 5 min easy job?
How good are the bearings? I was going to get a set of ceramics when they are available. Any thoughts?
JRXS-R
GTB SS + 13.5 & 10.5
Trakpower 4900
Supernova
Nomadio
PeteB is offline   Reply With Quote
Old 03-24-2007, 05:13 AM   #2454
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Originally Posted by $$$...
Hey Keith, great looking car you got there... hanging out for them to make it down here. Just wondering, I thought the car had the "new" front camber mod? does the kit come with both?
Camber mod is included.. but I dont run it. Im not sure if anyone does on foam???
Spur is 126 or 128 PRS... (only two i have)
Swaybars are direct fit.
KB
OUT
Keith Billanti is offline   Reply With Quote
Old 03-24-2007, 05:17 AM   #2455
Whaaaaa 4 screws...
actually, you only need 2. The lip in the front will hold it in just fine. Personally, i run all 4, but i think Kevin Hebert runs just 2.
OUT
Old 03-24-2007, 05:25 AM   #2456
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
so i take it everyone has enjoyed the build process of the car and we can read some results and how it went on the track... also how were the instructions, i read on here someone said they might be close to how xray has there instructions. If thats the case then that is very nice to see.
wallstreet is offline   Reply With Quote
Old 03-24-2007, 06:01 AM   #2457
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Nice wiring setup. WOw that looks like a tight fit and especially for brushless setups since they are still a little bigger than most brushed setups. Did a nice job figuring all the wiring out though.
Be interesting to see what you think of it after you have a chance to run it. Does look pretty cool.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 03-24-2007, 07:25 AM   #2458
dr_hfuhuhurr's Avatar
Trader Rating: 69 (100%+)
I will post pics of mine when I get the chance. I mounted my Sphere on it's side. I think it will be fine that way.
Keith B...you don't think anyone is running the camber mod on carpet? Why do you say that? What's it for? Hodge, care to weigh in here?
Also, if anyone needs a PRS adapter in blue w/extra 128 spur (2 spurs total) give me a shout. A friend of mine is getting out and gave one to me.
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 03-24-2007, 08:47 AM   #2459
CRASH's Avatar
Trader Rating: 26 (100%+)
Blake
YGPM.
Thanks,
CRASH is offline   Reply With Quote
Old 03-24-2007, 08:52 AM   #2460
CRASH's Avatar
Also has anyone noticed alot of play in the rear arms? Mine seem to have alot of play front to back.
Later,
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
