Team Losi JRXS Type-R
#2386
The only trouble I've had so far is with the spacing on the layshaft using the PRS adapter. It's still just snug enough to bind up a little bit. That and the slot in the adapter wasn't long enough for the pin, but that's a PRS thing. It was a good 1/8" too short, so there was no forcing it in there. I may just sand down one of those spacers a tiny bit to free it up.
#2387
Originally Posted by sportpak
What size fan are the mounts machined for? I could guess 25mmx25mm, but wanted to know for sure. I don't have my kit yet and was wanting to get some nik-nacs on the way.
sportpak- I would recommend getting the Losi machined and clamping drive hexes in all the available sizes and more importantly, a 7mm nut driver for the new (wheel) axle nuts.
Hexes-
LOSA9686 Aluminum .165"w (Stk) Wheel Hexes (2) $ 11.99
LOSA9687 Aluminum .195"w (+.030) Wheel Hexes (2) $ 11.99
LOSA9688 Aluminum .225"w (+.060) Wheel Hexes (2) $ 11.99
Nut Driver-
(LOSA99162)7mm
#2388
Super Moderator
#2389
Hexes-
Nut Driver-
(LOSA99162)7mm
Hexes-
Nut Driver-
(LOSA99162)7mm
#2390
Originally Posted by Marcos.J
the only trouble that i've got so far is "that i haven't got my kit yet!!!!"
#2391
Thanks. Any idea about the fans?
Malc
#2392
There's a hole in the chassis (countersunk on the bottom) just a bit behind the center front bumper hole. It doesn't appear that there's any real use for this hole UNLESS (Losi is genius) and it is made for a transponder mount. Which is EXACTLY what I used it for. Transponder fits perfectly below the diff, just behind the bumper and in front of the servo. Beautiful!
#2393
hey guys
the fans are 25x25mm and the Novak Fans not only fit well but are quite good
the countersink of the two forward bulkhead mounts are purposely cut shallower than the others. This was done because the side wall is already thin in that spot. What you may consider is using a steel screw that does not have the YFS marking on the screw head OR Ti screws in those two positions becuase they are typically a thinner headed screw. Then you should not have to do any additional countersink.
#2394
Originally Posted by rocketron
hey guys
#2395
Super Moderator
#2396
I guess I will not be using that spot since I have no ears on any of my transponders.
#2398
I feel that I'm more of a Bionicle man instead of the Transformer! LMAO
Billy --your right I could send him a solid green paint job but I gotta keep my "Live Wire" supplier happy for Vegas this year!
Brant
Brant
#2399
#2400
The Evicerator
filiPOW!
Shuuuuuuuuuurrrrrur!
