Old 03-23-2007, 02:20 AM   #2356
syndr0me's Avatar
Trader Rating: 32 (100%+)
Oh man, I'm spent. I haven't built a new kit in like two years, I guess I'm out of practice.
I LOVE these Losi shocks. I can't believe I suffered for so long with something else. These are so easy to get right. I had no idea building shocks didn't have to completely suck.
I got the shocks mounted, made a 3AM run to Pancho's for some mexican eatin', and now it's time to zzZzz and resume tomorrow.
syndr0me is offline   Reply With Quote
Old 03-23-2007, 02:59 AM   #2357
TheCoolCanFanMan's Avatar
Originally Posted by syndr0me
Any idea if Corally thrusts will work in these diffs? I've had a grillion of them.
They should do I think, if the R, is using the same the S, as I used to give my spare ones to the Corally boys at my track.
Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 03-23-2007, 04:28 AM   #2358
CRASH's Avatar
Trader Rating: 26 (100%+)
Your still not done? My car is done, just need to moun the RX and esc. My drive train is very free and the car went together very very well! I am very impressed with this car.
If the car works on the track as well as it looks it will be a very tuff car to beat.
Later,
CRASH is offline   Reply With Quote
Old 03-23-2007, 05:26 AM   #2359
Trader Rating: 17 (100%+)
Originally Posted by smojoe
c'mon guys, post some buildup pictures. After the last 12th scale race I might as well drive a TC while being punted into walls
Well with the thrust bearing problem I had I didn't get too far. I will get almost done tonight. Got a late start on it yesterday. My buddy sanded down the chassis real nice with 1500 grit after gluing it. The two screws on the bottom front side of the rear bulk heads underneath did not countersink very well so i had to do a little extra countersinking on them and the holes are next to the edge of the chassis so you have to be careful. Anyone else run into this? So far I like the car, It is very different and nice.
429racer is offline   Reply With Quote
Old 03-23-2007, 07:37 AM   #2360
CRASH's Avatar
Same problem with those 2 screws. Rear bulkhead screws next to the battery opening.
Only thing that kind of bothers me is they do not give you the clamping wheel hexs. Hate slide on hexs because as we all know they slide off the pin slides out and you spend alot of time looking for that pin. We know Losi makes them so it should have been very easy for them to include them.
Later and happy building,
Old 03-23-2007, 08:21 AM   #2361
Yeti35's Avatar
I have had the the hexes come of with the wheel but never lost the pin ever. I always had to push the pin out and it did not come out very easy.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 03-23-2007, 08:24 AM   #2362
dr_hfuhuhurr's Avatar
Trader Rating: 70 (100%+)
What is the part number for the clamping hexes? (direct Type-R replacement width).
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 03-23-2007, 08:31 AM   #2363
POOKYT's Avatar
http://www.teamlosi.com/newprod/index.htm
There ya go!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 03-23-2007, 08:36 AM   #2364
Mike Haynes's Avatar
The plastic hexes work just fine, i keep meaning to order some clamp ones but always forget...lol
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 03-23-2007, 08:39 AM   #2365
Originally Posted by POOKYT
LOSA9686 Aluminum .165"w (Stk) Wheel Hexes (2) $ 11.99
Thanks!
So far the kit has gone together REALLY well (except for the upper camber link thingies, I still don't care for those). The bulkheads, arm mounts all looks sweet.
I have everything but the shocks and the Spur Gear put built now. My PRS adapter should be here today.
Can someone explain to me the advantage of this new upper camber link thingy?
Old 03-23-2007, 08:47 AM   #2366
Send a message via AIM to R/C Anonymous
Anyone else have the new front upper turbuckle assembly thing cause a LOT of binding? Either the screw is coming out or it's binding things up.
I'm really not digging that setup.
Blake
When I assembled one the set screw was in too far into the turnbuckle. Try undoing it a few turn to the point where set screw sticks out through C-hub side of the assemble .5 mm or so. You might have to hobby knife a tiny slice if material on the inside of the turnbuckle were you pushed it in.
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 03-23-2007, 08:49 AM   #2367
I assume umean the JR link, if this is so then on my car it tends to keep the car flatter/square on the front
Malc
Old 03-23-2007, 08:56 AM   #2368
Originally Posted by Keith Billanti
gimme an hour.. my 10mo old daughter is passed out on me.
KB
Hey Keith, hope you don't work on an hourly rate, or you would skint by the end of the week dude, wheres the pics please
Malc
Old 03-23-2007, 08:57 AM   #2369
Yeti35's Avatar
This is actually pretty good, those of us that don't have the car can see what everyone is havin issues with and be prepared for it. Pooky, Malc and myself appreciate the building info you guys are giving us.
I will be picking mine up today, but since I have no place to run it tomorrow may just take my time and do it up right. That and I am sure Pooky has not even started painting my body anyhow!!
22 2.0
22T 2.0
Old 03-23-2007, 08:59 AM   #2370
POOKYT's Avatar
LOL
Brant
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
