Old 02-15-2007, 04:11 AM   #1696
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Originally Posted by jrighter
Keith, Todd and others, this may have been answered elswhere but are you able to tell us what parts are shared with the original car? I assume shock springs, pistons, and maybe sway bars? Anything else?Hinge pins, turnbuckles? Bearing sizes etc? I noticed that the pics display the new car using the sway bar ends for ballcups (love em) will the new car arrive with these?
I think its been answered before so sure..
can use the old arms- dont need old LCDs-- pretty sure
can use all hubs/ castors/ spindles
Bearings
shocks
bumpers
spurs/ adaptors
body mounts
sway bars
hingpins
turnbuckles
that might be about it..
i can only assume the car will come with those ball cups.
Keith
OUT
Keith Billanti is offline   Reply With Quote
Old 02-15-2007, 08:32 AM   #1697
sportpak's Avatar
Trader Rating: 26 (100%+)
Has it been determined if the GTB will fit on this car? It's what I want to run on it when it comes out. I have some ideas how to do it, but was currious if someone has done it yet. Also, will the Orion 3200 carbon edition LiPo fit in this car. I can't wait for the car, but some of the details have me concerned. Any help would be great.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 02-15-2007, 08:40 AM   #1698
syndr0me's Avatar
Trader Rating: 32 (100%+)
It seems you may need to run it on the opposite side of the motor tabs and run wires over the top deck. Here's a picture of Todd's car with a GTB from a few months ago.
Team Losi JRXS Type-R
I believe both the carbon and platinum Orion LiPo fit in the car just fine. The Platinum is in the car for its product shots, and it comes with a dedicated LiPo tray, so that one almost certainly works.
syndr0me is offline   Reply With Quote
Old 02-15-2007, 08:44 AM   #1699
sportpak's Avatar
Thanks dude. I feel much more relieved. There is no way that I'm not going to be fully brushless/lipo next year. I really want to do that with this car.
Old 02-15-2007, 08:47 AM   #1700
syndr0me's Avatar
No problem, I'm in the same boat as you are. Making the most out of LiPo seems to be one of the biggest reasons for getting this car. It's definitely why I'm switching.
Old 02-15-2007, 08:47 AM   #1701
Default Thrust bearings
To the Losi dedicated:
I have had a few thrust bearing failures lately. I noticed there are two versions. Which version is the most recent?
Version 1: The ball bearings are held within a brass hollow ring allowing grease to completely fill the bearing ring.
Version 2: The ball bearing ring is solid (brass I think) with grooves.
Version 1 is the thrust bearing that has been failing me. It basically distorts and comes apart. Leaving the diff almost seized.
dasdaman is offline   Reply With Quote
Old 02-15-2007, 09:13 AM   #1702
sportpak's Avatar
The LiPo down the middle seems to make the most sense to me. I run rubber tire, so the motor in the back should help keep the rear end down. Any weight I have to use to make the minimum I can put anywhere. Can't wait to get the new car. I'm running the original car now and love it. I just can't get a LiPo in it.
Old 02-15-2007, 09:17 AM   #1703
syndr0me's Avatar
We've got two guys locally running LiPo in the original car. They pulled the case off a 3200 and put it in double shrink, and managed to jam it in there. They're both winning races every week without issue, so I guess it's working okay for them.
Old 02-15-2007, 09:28 AM   #1704
sportpak's Avatar
I think I'll wait for the new car. I want to use the batteries for offroad this summer too. Right now our points rules say no LiPo. Next year we're going to allow them I think.
Old 02-15-2007, 09:41 AM   #1705
Administrator
Matt M.'s Avatar
i have had the same problem with your version 1....
there were a few version 2s at my track i bought all of them...i have not seen them in a while now....
possibly todd can chime in here
Matt
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 02-15-2007, 09:59 AM   #1706
Andrew Gray's Avatar
As far as the thrust assembly goes the best thing to do is to buy the thrust that mcmaster carr sells #7806K53. www.mcmaster.com They are awesome, your diff will be smoother and last longer. They are a little pricey but worth it.
Retired & Washed Up. TLR Supporter For Life
Andrew Gray is offline   Reply With Quote
Old 02-15-2007, 11:51 AM   #1707
Administrator
Matt M.'s Avatar
mmcmasters are nice, the corrally ones are wonderful also, but are VERY expensive.....
Old 02-15-2007, 12:18 PM   #1708
syndr0me's Avatar
Will the Corally ceramic thrusts work in the Losi diffs?*
*This question was not approved by Larry Fairtrace.
Old 02-15-2007, 12:52 PM   #1709
The McMaster thrust washers are $10.68, not sure about the Corally one, never tried it. As far as it fitting I'm sure it will, I've used the xray one in the Losi diff, most of the thrusts are for use with a 3mm screw.
Old 02-15-2007, 12:58 PM   #1710
mainracer's Avatar
Send a message via AIM to mainracer
I tried the Corally ceramic one and it worked fine but the mcmaster was even better and I think it cost less !!!
Keven Hebert
AE / Reedy / LRP
KOpropo / Much-More / Parma PSE / Protoform / APS ceramic Bearing / BawdyShop / Fastcats / Dekelz
mainracer is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
