MLP's GTP/LMP Chassis and Car!
#61
Hmm wif this power transfer unit, would it be more efficient/durable than the belt drive? I think the belt would work better?
#63
Well Marty keep us updated! Cant wait! I am visualizing a somewhat wider chassis than the F1 car wif full suspension and 200mm width so i can put gtp/touring bodies and normal touring wheels on it. Woot!
#65
Will kit form come with instructions? Will it be tough? Difficult to build up?
#67
I hope they hold up well. I am no pro and i am a great friend of the kerbs and boards *laughs* what abt parts? Sorry if i am asking questions that have already been asked..
#69
This has nothing to do with MLP But it is cool and the way we are looking to go with our MLP GTP Car! Check it out read up on all of his hard work and Love for R/C cars and motor racing.
And I thought I was over the edge! Well I am but it is nice to see people out there Like John and Mathijs Hermens (Pro Ten Holland )
John Stranahan's Smoken Pan Car!
For the Full Story Go here!
Link to tires
Link to tires
#70
Been following those threads as well Marty , alot of creativity and knowledge going on there . Mathjis is a great guy , he has helped me in the past with info on Pan cars.
Love how John has got you going on front suspension ideas for your GTP car , now i'm realy looking forward to it . I was going to buy a wide pan car , but now i think i'll wait till you have your GTP car finished
Link to tires
Link to tires
#71
none
#72
Well thanks and yes Mathjis is a great guy as well as John and I have been following there thread for sometime and I have always felt that one should make a pancar that could out run touring cars but have a little more adjustment on the front.
I am going to make the front suspention and try to fit most 1/10 scale pan cars if not all of them or make a new lower Chassis for a persons car with our front suspension.
And a complete Pan car. in 190mm/200mm and 235mm and then a 235mm with our F206F1 suspension.
#74
I am going to build a 190/200mm and 235mm Pan car and it is going to have the tripod rear shocks of a pan car with a dual floating front suspension with micro shocks or just spring loaded tubes for the front.
Then I am going to build a 235mm Car with a belt drive and a full floating suspension 4 shocks like our F206F1
I will be running the Normal Pan car front and rear tires for both cars and try to make wheel adapters for touring wheels and tires.
As for the front suspension if you know of the AE Dynamic Strut front suspension has adjustable aluminum front arm mounts, which provide 6-position mounting Well I would like to make our front in the same manner but with both upper and lower arms that move and adjust like the AE suspension with shock and springs or spring tubes.
This will also let you mount the AS Dynamic strut front suspension right to our car if one would not want to use our design.
CEO:Martin Peterson
CEO:Martin Peterson
