Old 01-27-2003, 07:06 AM   #1
warlord385's Avatar
Default battery short?
I accidently touched the batteries together when i was putting then in my car. It made a pop noise. It was very brief. Are my batteries still Okay?
warlord385 is offline   Reply With Quote
Old 01-27-2003, 12:30 PM   #2
Probably your pack is fine. But without testing that's a firm maybe.
Check each cell for voltage across the individual cell.
Cycle it and make sure it's charge / discharge time is normal. If there is a reversed or shorted cell, you'll lose voltage and runtime. For instance I had an OLD 1700 SCR pack that had a shorted cell that I didn't realize, I was only getting ~1400 Mah from and average voltage was down quite a bit, not a full 1.2v, but significantly. When I removed the bad cell and made a 4 cell pack with the rest, it came right back to ~1750 Mah at the same discharge rate with voltage right where you'd expect it to be.
You can just use a normal digital multimeter to test for a dead cell, check each cell individually, and it will show no voltage difference across it if it's dead. For cycling just time discharge from full and compare it with a similarly rated pack, if a cell is gone, you will notice a significant difference.
Concillian is offline   Reply With Quote
Old 01-27-2003, 07:26 PM   #3
Neil Rabara's Avatar
The pack should be fine if any of the cells did not vent. You will definitely know if a cell or pack vents. The shrink wrap melts and it makes an terrible hissing sound, like it is ready to explode. If it didn't vent, discharge the pack on a discharge tray, let them cool on a fan, then cycle them.
Neil Rabara is offline   Reply With Quote
Old 01-27-2003, 07:59 PM   #4
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
what if it did ? what happens?
imataquito is offline   Reply With Quote
Short vid of my MGT savagebeaster Monster Trucks 3 07-31-2006 02:35 PM
Battery "Shelf-Short" Question lost Electric On-Road 10 12-07-2005 12:05 AM
Short arm design. RCknight Electric On-Road 2 08-01-2005 07:46 PM
Josh Short Ballistik Buyer/Seller dispute and Feedback discussion forum 0 02-11-2005 03:34 PM
Long arm, short arm, what's different ttso Nitro On-Road 4 11-14-2004 08:04 PM
SEO by vBSEO 3.5.0
