Old 08-07-2006, 08:11 PM   #1
BigPapa's Avatar
Default motor
As I am breaking my motor in (19Turn) at 2 volts and 5.40 amps, then as I increase it to 7 volts and 8.00 amps, my motor starts to vibrate and numbers start to jump up and down, what does the mean
Big Papa
BigPapa is offline   Reply With Quote
Old 08-07-2006, 08:28 PM   #2
Trader Rating: 32 (100%+)
Send a message via AIM to Sean R
Your armature is not perfectly balanced (not very fixable unless you are willing to drill some material away) and causing the brushes to bounce; this causes arching, and funky amp draw numbers. Generally, the motor will run fine in your car, but not nearly as efficient and powerful as a motor that is perfectly balanced.
Sean R is offline   Reply With Quote
Old 08-07-2006, 10:39 PM   #3
might want to try skiming the com too , as well as what was mentioned ,checking the balance of the arm ... I had a 19t do the same thing , cut the com and did notice the com being out of round ....motor now runs fine ....
Mark Barden .
mb racer is offline   Reply With Quote
Old 08-07-2006, 10:50 PM   #4
XrayFK's Avatar
Why would you want to break in your motor at 7v? Stick with 1-2v.
XrayFK is offline   Reply With Quote
FS: MTRONIKS GENESIS TRUCK B/L ESC, FEIGAO 380C-6L MOTOR & REEDY NEO-ONE 4 STAR MOTOR davidrrr R/C Items: For Sale/Trade 5 08-16-2008 02:32 PM
FS/FT NIB LRP 5.5T Brushless motor/ Castle CM-2080 motor Trade for Newer FUTABA S9451 ffpm46 R/C Items: For Sale/Trade 13 03-31-2008 01:17 PM
Modify your stock motor, mod motor, any motor! TRF-Powered Electric On-Road 10 03-15-2007 04:52 PM
Trinity Motor Checker “Monster Horsepower Machine” Motor Performance Monitor CRiXman R/C Items: For Sale/Trade 5 01-25-2007 02:36 PM
Stock motor blowout!!! NEW Hurricane bushing reamer / 767 brushes / motor case LOW$ evostyle R/C Items: For Sale/Trade 0 11-27-2006 10:22 PM
SEO by vBSEO 3.5.0
