Old 08-04-2006, 09:45 PM   #1
bigair78's Avatar
Default Which tires?
I'm racing on road tomorrow. The temp is expected to be around 96 with humidity 63%. What tires should I run? My LHS carries RP and take off's.
bigair78 is offline   Reply With Quote
Old 08-04-2006, 10:45 PM   #2
maxepower's Avatar
Red face Tires,tires, tires!
I'm assuming you mean the air temp and not the track temp. If the air temp is 96 degrees then the track itself will be at least 120-150 depending on the time of day. If this is the case then RP-30, or RP-32's should work!
I haven't even considered what insert to use! Both brands have pre-mounted tires so if that's the case then use what they got. If not, then a general rule of thumb the harder the insert the higher the temp. the insert can handle!
Take-off 27's might work in the early mourning but in the afternoon they will probably overheat and you'll loose traction. When the track gets that hot a high a temp tire is required. Usually the higher the number the hotter tire temp rating.
For example: Sorex 28's are for cooler temp track, then a Sorex-40 is for a very high temp track!
I hope I was of some help! Then again, ask the local racers at the track what they are using and they should be knowledgeable on what tires work!
Don't forget first and formost HAVE FUN!!!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EXO-6,TA-07,TRF419,EVO-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Cleaning Out Garage Sale TIRES TIRES TIRES MattOCM R/C Items: For Sale/Trade 5 01-15-2008 02:55 PM
Foam Tires, Parma, TRC, JACO, Tire truer, Rubbers tires and much much more! Team Speedy R/C Items: For Sale/Trade 43 12-15-2006 09:38 AM
Team Orion tires / monster truck tires and weld wheels evostyle R/C Items: For Sale/Trade 4 04-25-2006 08:52 PM
TIRES tires TIres, Ellegi or UFRA. bleach1 Nitro On-Road 51 06-01-2004 09:58 PM
Used trc & jaco touring & 12th scale tires trued mint shape a ton of tires 1 to 3 run jason cheng R/C Items: For Sale/Trade 10 01-02-2004 09:27 AM
SEO by vBSEO 3.5.0
