Old 01-25-2003, 10:30 AM   #1
Default Tire truing, pros and cons
I was just wondering what the pros and cons are for tire truing
micro speed is offline   Reply With Quote
Old 01-25-2003, 10:42 AM   #2
Registered User
OB42TC3's Avatar
Different foam diameters handle differently
Keeps fronts and rears even diameter
Keeps tires flat (or you can camber them)
Can repair tires when chunked by gluing in donor foam and retruing
Makes slightly out of true wheels runnable by truing the foam relative to the axle
Can make your own wheel tire combos, ex. 1/8 rubber on 200 mm touring wheel
It's just one of those tools that you need eventually, it will last years and years. Same as a comm lathe, 30 amp power supply and any competition electronics equiptment. High initial investment, but you'll have it for years.
OB42TC3 is offline   Reply With Quote
Old 01-25-2003, 05:44 PM   #3
Trued tires are faster, less prone to chunking, have more consistant traction , and wear alot longer...... I didn't believe it until I tried it for myself, but they wear alot less....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 01-25-2003, 09:06 PM   #4
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
True, the smaller the sidewall on the tires, the faster they're going to be, and they will chunk less, but they will be less forgiving.
With a larger sidewall, you have more side to side flex in the tire, so you have more forgiveness in the tire, but they can chunk a lot easier.
Generally, you will find a diameter that you like for racing. But for practice, run them big so you get as much runtime out of them as possible!
Also, truing them can mean you can "overdrive" your car a bit (or underdrive) which means driving your front wheels faster than the rear (larger fronts vs. smaller rears) - this makes your car more "positive" through the turns - the fronts pull your car through the turn very nicely. With my nitro car I usually run about a millimeter of overdrive. . .works very nicely.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Pros/Cons on AE 18R Huffpie Micro and Mini Scales 5 12-07-2008 06:11 PM
pros and cons MMS2 Rookie Zone 13 11-11-2007 03:30 AM
Pros and Cons! Bobby J Electric On-Road 6 01-06-2005 06:15 AM
pros and cons of XXX-S & TC3 jiggamacdaddy Electric On-Road 15 04-30-2003 09:09 AM
pros and cons on the v-one rr fuse01 Singapore R/C Racers 16 04-05-2002 12:39 AM
SEO by vBSEO 3.5.0
