Old 08-02-2006, 08:53 PM   #1
Tim W.'s Avatar
Default Help
I have a xxl 75mhz fm reciever that works fine but the antena wire is broken in 2 can i just re solder it or should i send it in to novak
Werks Racing USA, Mugen, AKA, Airtronics, Avid, Upgrade
Tim W. is offline   Reply With Quote
Old 08-02-2006, 08:56 PM   #2
I tryed fixing one of my antenas once...didnt work out to well. Send it to novak theyll probably only charge you a few bucks. And it will be done by people that know what there doing.
slowandsteady is offline   Reply With Quote
Old 08-02-2006, 09:00 PM   #3
PeteB's Avatar
you should be able to just strip off some of the insulation and twist it together, that should work. (maybe with slightly less range, but still enough)
better solution is to solder it back together
better solution again is to replace the antenna altogether, carefully open the receiver, and desolder the existing antenna and put in another. make sure that the solding iron that you use is not too hot (maybe 15a), because you are working in a circuit board,
even better solution is to get someone in an electronics shop or someone who know how to solder to do it for you...
GTB SS + 13.5 & 10.5
Trakpower 4900
PeteB is offline   Reply With Quote
Old 08-02-2006, 09:01 PM   #4
Z.Hallett's Avatar
Send a message via AIM to Z.Hallett
you could always try to fix it yourself, but if it doesnt work right, novak might not fix it if you try and send it to them because it is "tampered" with. your choice, you could possible fix it though.
Z.Hallett is offline   Reply With Quote
Old 08-02-2006, 09:06 PM   #5
RoachRacing's Avatar
Send a message via ICQ to RoachRacing Send a message via AIM to RoachRacing Send a message via Yahoo to RoachRacing
Your best off sending it in, downside is time without it and the cost. The other thing that you can do is get some antenna wire that is the same length of the original wire and solder that to the board in the receiver. just be carefull!!
Use a good iron and as little solder as possible while attaching the new wire. i have dont it on an old receiver of mine.
RoachRacing is offline   Reply With Quote
SEO by vBSEO 3.5.0
