magne zapper
:lol: need advice for a magne zapper that u would recommend i use
Thunder RC is the best one made.....look no further, listen to nothing else....I have spoken :p
Later EddieO |
And I have 2nd that motion :lol:
EA |
Thunder RC ,worth every $$$
PS. Stay away from ERP!!!!!!!!!!!!!! |
Other than the thunder the only zapper I am aware of that even works is the Team1 unit. The Thunder is king but the team1 is the cheapest functional unit available.
Mark |
If by functioning you mean, weighs 300 hundred pounds and trips everything on the breaker assuming it even gets enough voltage to get a decent zap, then yes the team 1 functions.......
My team 1 sits under my bench and has not been used in two years..... Later EddieO |
Thunder RC is the only way to go. ;)
Hey guys thanks for your info
Now.... Which equalizing battery disharger is the best to use When you are looking at your print out from the dyno how is it one can tell how one should change gearing if the final ration on a track is 640 RPM Torq Watt EF AMPS 21774 1.4 24 37 12.7 20015 3.5 52 61 17 18845 5.0 70 69 20.1 17840 4.8 64 54 23.3 16549 8.1 99 73 27.0 15824 9.6 112 74 30.2 this is a 19t MOTOR MY FINAL RATIO BEING 8.3 SHOULD i THEN USE LINE 5 TO GEAR MY MOTOR? Seeing that the torque for that line is the closest to my final gear ratio. Let me know if I am thinking wrong Thanks BigPapa |
Now.... Which equalizing battery disharger is the best to use When you are looking at your print out from the dyno how is it one can tell how one should change gearing if the final ration on a track is 640 RPM Torq Watt EF AMPS 21774 1.4 24 37 12.7 20015 3.5 52 61 17 18845 5.0 70 69 20.1 17840 4.8 64 54 23.3 16549 8.1 99 73 27.0 15824 9.6 112 74 30.2 this is a 19t MOTOR MY FINAL RATIO BEING 8.3 SHOULD i THEN USE LINE 5 TO GEAR MY MOTOR? Seeing that the torque for that line is the closest to my final gear ratio. Let me know if I am thinking wrong Thanks BigPapa here is the #' of my last Komodo 19t that I built at 7 volts rpm torq watt ef amps 26219 8.0 166 71 31.2 25430 9.0 180 71 34.0 24560 10.2 195 71 37.1 23883 11.1 206 70 40.0 23165 12.1 217 68 43.4 22396 13.1 225 66 46.9 full face brush purple+ red - |
The Eclipse magnetizer from Advanced Racing Components works better than any anvil style magnetizer I have used. I owned a Team 1 magnetizer and the Eclipse blows it away.
www.arc-racing.com |
:weird: Hey looks good, I threw that one up before making any changes, My Point was to get my question answered, so any one let me know what you think about my question.. :nod: ......
