Team Orion 3200mAh Race Spec LiPo
#1083
Originally Posted by SWTour
syndr0me
NoVAK IS listening. We are working with Charlie and the NoVAK crew doing our testing...and they have been awesome to work with.
We've been testing on both the West Coast and back east, so different racer input can be derrived.
#1084
Originally Posted by diha
HI all,
Today, I tried my 1st 3200 lipo on my mini & I realised that the voltage drops with every re-charged. Is it normal? Can someone explain why.
What should I do gain back the voltage?
Initial charged: 8.4V; Run: 10 mins
2nd charged: 8.4V; Run: 10 mins
3rd charged: 8.22V; Run: 10 mins
4th charged: 7.98V; Run 10 mins.
I am using a Supernova Competition charger with contant current & contant voltage charge.
Thanks.
Thanks.
First I would check to see if both cells are showing the same voltage ( it has been explained several times in this thread how to do this) then if they are not matching votage I would try to balance the pack.
If balancing does not help then I would send your battery into the manufactuers for review.
#1085
syndr0me
#1089
Originally Posted by Guo Chean
does any know how to fix my orion lipo pack recently i make a mistake by plug in wrong polarity to my lipo pack and after i put it back correct polarity it doesn't work and not able to let you charge the lipo cell. what wrong with my lipo pack? thanks
If you plugged a battery backwards into your charger; you more likely burn the fuse in the charger than actually damaging the battery. And if it's a crappy charger; you might even burn the charger! Some have reverse polarity protection.
If you plugged a battery backwards in a speedo; you can burn it out! Some might have protection but I don't think a lot of the highend ones did..
#1090
#1091
No, I mean you can burn out a speedo, burn a charger or the fuse on the charger. It's unlikely your Lipo gets burned that way.
#1092
I now take an extra moment to ensure that the battery polarity is correct. I use Deans plugs and will always plug the female side into the battery before connecting it to the ESC. This gives me one last chance to make sure that I didn't have momentary brain-fade. This is a hard lesson-learned and hopefully will not happen to you again.
Pete
#1093
#1094
i try to open the carbon case it seem that one of the lipo cell connected tab was break and i just fix it with another wire it works but dunno whether it would works in future.
Pete
PS In my previous response, I mentioned that I contacted Novak. I meant to say Team Orion.
#1095
Pete Thomas,
Was that a Peak/Orion 3200 battery that blew a fuse?
If so, why would you call Novak to find out about repairs? LOL you already corrected yourself...
This will be something we'll have to advise about and be very careful with, but the rules we are working on will NOT allow ANY Battery to be run if the Plastic case is DAMAGED or has been TAMPERED WITH.
