Old 07-30-2006, 10:21 PM   #1
Default Xray FK04 Battery Question
Does anyone know if you can fit 3600-3800Mah cells in the FK04?
llamont is offline   Reply With Quote
Old 07-30-2006, 11:07 PM   #2
big al's Avatar
You can get the 3800's to fit, you just have to file the slots down a bit. Also, you have to grind down the rear bulkheads just past the battery straps. on the bulkhead there are little pilot holes..this is where you grind at. Enjoy--Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 07-31-2006, 12:16 AM   #3
eforer's Avatar
Send a message via AIM to eforer
you don't need to grind down the bulkheads, however if you do want to use them you'll have to grind the battery slots. I reccomend (a la mark smyka) a 1" sanding drum kit, which can be found at the home depot. Chuck it into a cordless drill and just slide it in the slots. Perfect bevels in like 2min for the whole chassis. For my 04, I used a spindle sander with the same bits to do the standoffs so you didn't have to tighten/loosen them from the underside of the car for the bigger cells. Also, remove the foam from the straps.
Speed Merchant/Corally USA/Specialized RC/Team Kwik/Tekin/Sweep/Parma PSE/Team Pickles Performance
eforer is offline   Reply With Quote
Old 07-31-2006, 12:46 AM   #4
Thanks for the response people.
Old 07-31-2006, 10:16 AM   #5
rayhuang's Avatar
I am running IB4200's with an extra layer of shrink wrap in my BMI FK04 Chassis. I relieved the battery posts just a little top to bottom, put a bevel in the posts to make slipping the batteries in a bit easier.
I will from now on use the IB4200s without the extra shrink wrap though!!!
xray FK04 battery strap surrealmaterial Australia Wanted to Buy 4 08-06-2007 04:14 AM
XRAY FK04 Rody Australia For Sale/Trade 0 12-31-2005 03:07 PM
Xray FK04 RTR xanthan R/C Items: For Sale/Trade 0 07-09-2005 08:13 PM
XRAY fk04 Superkidracer82 R/C Items: Wanted to Buy 8 06-27-2005 08:08 PM
XRAY FK04 w/BMI NVisible R/C Items: For Sale/Trade 25 06-01-2005 12:01 PM
SEO by vBSEO 3.5.0
