Old 07-29-2006, 10:03 PM   #1
Default Transmitter/Reciever has no Range
I just went to a race and couldn't drive my car more than 30 feet away before it started glitching. I tried changing recievers, crystals, and radios. Not sure what is happening as it used to drive just fine at this track. It happened no matter what speed I was going once I got more than 30 feet away.
Could the ESC be the cause?
I am driving an Xray Fk-05, MX-3 tx/rx, and GTX ESC.
It is driving me crazy. I would just like some opinions before I buy a new radio system if my radio might not be the only cause.
Johnny9s is offline   Reply With Quote
Old 07-29-2006, 10:06 PM   #2
Michael P's Avatar
Hello Johnny9s I have had this happen to me before make sure that the antenna from the receiver if not touching the chassis.
Michael P is offline   Reply With Quote
Old 07-30-2006, 10:11 AM   #3
Is the antenna length stock or has it been shortened. I have seen many racers cut their rx antennas (to make the car look better) and then have range issues. If you did cut the rx antenna, get a new one. If you did not cut the rx antenna, make sure it is not touching any graphite or metal. BTW, how is the radio antenna? Make sure it is secure in the antenna well. Hope you fix your issue soon.
llamont is offline   Reply With Quote
Old 07-30-2006, 10:43 AM   #4
The rx antenna is stock length and does not touch any metal or graphite. The radio antenna is also fine. I tried unscrewing and reseating it in the radio.
The thing I don't understand is that it ran fine last week and now it won't stop glitching.
I might just buy a Spektrum system and hopefully that will solve it.
Old 07-30-2006, 10:51 AM   #5
Trader Rating: 44 (100%+)
Have you tried a different motor? Sometimes the capacitors go bad and can cause interference. You might also try a different servo if you have one available.
The Spektrum system may help, but it's not guaranteed.
M03R, M04L, TT-01R Type E, Midnight Pumpkin,
Lunch Box, CC-01 Wrangler, SC10.2FT,
SC10B, Traxxas Slash
minimadman2003 is offline   Reply With Quote
Old 07-31-2006, 03:19 AM   #6
Drewdc90's Avatar
If it ran fine last week then something must have changed since then. Try moving your RX further away from your speedy and make sure no wires from RX or speedy are touching carbon fiber. A spektrum most likely will fix it but you may not need one. Just keep trying things.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 07-31-2006, 03:35 AM   #7
nikoskar's Avatar
-Sorry for the Off-Topic-
I have a Sanwa M11 40 Mhz and the antenna wire cuts out. Do you know how can i find the exact length of the antenna wire?
Thanks in advance
nikoskar is offline   Reply With Quote
Transmitter and Reciever El Pedro Australia Wanted to Buy 2 06-13-2007 05:49 PM
**WTB** Transmitter and reciever 4u2nv R/C Items: Wanted to Buy 9 02-22-2007 10:25 PM
transmitter reciever what is BEST streetstock Electric Off-Road 9 06-26-2005 09:15 PM
Transmitter + reciever batteries TS_Mick Rookie Zone 8 03-18-2003 04:42 PM
Increasing radio range? Or which radios have longer range if any? VN-TEC Nitro On-Road 23 12-13-2001 08:29 AM
SEO by vBSEO 3.5.0
