Old 07-24-2006, 04:38 PM   #1
serpentpro28's Avatar
Default charging receiver battery with ice charger
Hi' guys i have a 5AAA with 900mah of 1.2v,can you guys tell me what is going to be the set up on my charger im new with this ice charger with duratrax,
what is the peak sensitivity?
do i need to set up the discharge volts,never use this on my old charger?
Here is the current setting on the charger;
NIMH 5 cell = 900mah
dchg current=0.9A
peak sensitivity=9mv/c
dchg volts=0.9v/c
tricle curr=off
cut of temp=120'F
no.of cycle=1 time
cycle delay=5 minutes
cycle mode=D>C
max chg capa=150%
peak delay=5 minutes
top-off chg=OFF
it won't charge my receiver battery on this set up'
I really appreciate if someone can help me up'
Team bilis racing
serpentpro28 is offline   Reply With Quote
Old 07-24-2006, 11:16 PM   #2
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
you don't have your charge current listed. I would start at something low to gain "runtime" and to avoid damaging your batteries. Its not like you are going to benefit from any extra voltage. Try charging at .5 amps and lower your delta peak to .05
|◤ReflexRacing.net◢|◤Gravity R/C◢|◤HWNA◢|◤AVID R/C◢|
Battery charging with new Swallow EQ charger KyoshoKid Rookie Zone 7 09-09-2008 04:34 PM
Receiver Battery Charger Suggestion kmaheartless Nitro Off-Road 6 07-31-2007 09:00 AM
Airtronics MX-3S, Receiver, Battery, Charger & Case SKOT R/C Items: For Sale/Trade 6 04-27-2007 08:06 PM
Revo Receiver battery pack charger JEXTEL R/C Items: For Sale/Trade 2 12-17-2005 08:30 AM
Snapon battery charger AVR charging system tester crazymechmow Other Items: For Sale/Trade or Wanted to Buy 0 01-11-2005 07:55 AM
SEO by vBSEO 3.5.0
