what's the best clipon heatsink?
#16
You can buy a integy heatsink which has a strip of aluminium attached which points the fan at the endbell to cool.
might pick one up
might pick one up
#17
Originally Posted by R40Victim
Hopefully, these will come out soon, at least for those of us running brushless systems...
or for brush motors:
They don't look like they'd take much of an impact though...
#18
might pick one up
might pick one up
#20
One last question: Is it better to have a fan facing the heatsink or the endbell? Or both.
Good feedback, big help.
#23
you are talking about different types of fans, heatsinks...
But think about: Where does there air go in the motor? Where does it leave the motor?
I think, the air goes in at the endbell and leaves the motor at the can. Am I right?
So than you should blow air in the endbell and help them escape from the can...
I think, 2x40mm fan will be the best...
The heatsinks made of alu are not the best. Is there any heatsink of copper?
#24
#25
Yes the GTB fans are a joke, but I think the Novak ones we're talking about ehre are the black plastic ones. Slightly smaller diameter but thicker. They are heaps better than the GTB ones.
The AE one looks the same, but it comes with the Rx connector already fitted. They're nice.
Mike
Mike
Originally Posted by or8ital
If those Novak fans are the same as the one on the GTB they are pretty terrible. Ive broken lots of those and they are expensive. If those are a lot better then the 3racing ones then those must be bad!!
#27
Originally Posted by Jochim_18
Now I use a 40mm cooling fan and boy this baby can blow some air. I used a 3-racing heat sink take those crappy fan out and just use one screw to hold the 40mm cooling FAN works like charm.
